I'm getting windows 10
  • junktv
    • Nov 2010
    • 3065
    Well I now have two pc's with windblows 10 home and never used it. What do I need to shut off and not do? The one will be used by an old lady and the I3 by me and will probably end up dual booting with a flavor of linux.
    HP Slimline 270-p013wb intel G4560T
    https://support.hp.com/us-en/document/c05492124
    HP Slimline 270-p043w I3-7100
    https://support.hp.com/us-en/document/c05591683
    • 31249
    Re: I'm getting windows 10
    you cant shut it off,
    it's not added spyware, it's spyware that happens to run wondows software (to a degree)
    • sofTest
      • Aug 2008
      • 361
      There are guides out there for what to disable manually, but its cumbersome. I prefer to use a tool that gives me the controls speedier at one place. This page gives a list of some tools. Personally I've used the Spyboot one for some of my own stuff, without any problems. As always with these kind of tools, use with care. At least create a restore point before making changes. And it would be unwise to use more than one of the tools on the same PC.
      Be a mensch
      • junktv
        • Nov 2010
        • 3065
        Kinda leery using 3rd party tools on the one but i'll check em out. She will be banking with it. I'm just going to be screwing around on the other. Figure better learn 10 since 7 EOL is soon.
          • 31249
          well your screwed then!
          • showmelee
            • Sep 2018
            • 5
            • sofTest
              • Aug 2008
              • 361
              So am I, but I selected the Spyboot program, as they are well known for their other garbage clean-up software. The program can also do some tweaks that normally are only available in the Enterprise-version.
              If such a company cannot be trusted, on par with other well known software manufacturers, you would be best advised to stay away from most readily available software. You would then be best advised to use open source code, examining the code and compile it yourself. That is, if you got a trustworthy compiler.
              You best select your own level of paranoia.
              Be a mensch
              • RJARRRPCGP
                • Jul 2004
                • 6304
                But, 8.1 shouldn't be EOL for a good while!
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16959
                  2023. S2K12 R2 is the same interface and doesnt phone home....The standard edition with some mods, classic shell, and tweaking, its a hell of a good workstation OS....but probably not something a little old lady would be able to deal with.
                  <--- Badcaps.net Founder
                  Badcaps.net Services:
                  Motherboard Repair Services
                  http://folding.stanford.edu/
                  Team : 49813
                  Join in!!
                  Team Stats
                  • junktv
                    • Nov 2010
                    • 3065
                    Nope not even. Why do they kill the good and keep the crap.
                    • BigTroll
                      • Sep 2010
                      • 1317
                      • LAMBDA SOND
                      make sure you turn off activity history it was introduced in version 1803, you can find it in the settings then privacy menu, there are lots of other options in there you can turn off too.
                      It took me awhile but I came around to 10 mainly after my boss scolded me for all the windows 7 computers having viruses which is because the overlords that be turn off the WSUS server so they never get updates and thus viruses. That said I am the last person in our tech group to be running Windows 7 on my main work machine.
                      My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
                      • Stefan Payne
                        • 1267
                        You can't even get Drivers for 8.1 these days for some important things...
                        • ChaosLegionnaire
                          HC Overclocker
                          • Jul 2012
                          • 3266
                          • Singapore
                          Originally posted by BigTroll
                          my boss scolded me for all the windows 7 computers having viruses.
                          u should scold your boss back and tell him that isnt your fault or problem. its a pebkac issue with whomever is using the computer who isnt computer literate. most probably surfing pr0n on the work computers which is the main source of picking up viruses.
                          i mean u said u run win7 on your machine. so if others get viruses on their win7 machine but u DONT, then what does that prove?!
                          • junktv
                            • Nov 2010
                            • 3065
                            I tried to introduce her to android on a 8" tablet and it didn't go well. Then again I'm fairly android illiterate myself but getting better since I picked up a couple tablets and don't mind breaking them. Although the 10" lenovo seems decent and perfect for mobile computing, movies/music at camp and maps etc..
                            She used a pc every day for 30 years but didn't get how they work. She started with punch cards and ended on win7 or 8. She brought home backups of programs she wanted to keep one time on a floppy. Yup backed up the desktop icons perfectly. Good job momma lol.
                            • RJARRRPCGP
                              • Jul 2004
                              • 6304
                              Even the non-Windows Server version, is much less frustrating than 10!
                              8.1 by default lets me keep stubborn Windows Defender turned off and I haven't recalled a storahci.sys issue (or its ilk) yet. I was happily using 8.1 in 2015!
                              10 by default, will keep installing a video driver without your permission!
                              Arc A770 16 GB
                              • junktv
                                • Nov 2010
                                • 3065
                                Well I fired one up. Microsoft needs to line up and be beat with a rubber hose.
                                  • 31249
                                  i hate that.
                                  i remember long ago - win3.11 time.
                                  i walked into a university computer room,
                                  sat down and proceded to locate and copy all the different dictionary files from a special version of Word on the network server onto about 30 floppies.
                                  the other students(i wasnt one) sat in silence watching me, thinking i was some super-hacker or something! lol.
                                  • captainKKK
                                    • Sep 2018
                                    • 287
                                    • junktv
                                      • Nov 2010
                                      • 3065
                                      Added a new one to the mix. HP 570-p013wb i3-7100, 8gb ddr4 2400,1tb WD blue and mid case. I'm setting it up for me so playing around more.
                                      Is there anyway to upgrade from 10 home to 10 pro free? It's what came on it and the xp pro are the only ones I have keys for. My 7 pro is of iffy origin and uses a oem key that I couldn't even download a copy of 7 pro with when I tried years ago.
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        i wont use 10 myself.
                                        if i get a machine that cant run 7 or linux it gets sold.
                                        that tends to be those craptastic convertible tablet things mainly.
                                        when micro$oft was giving free 10 "upgrades" i figured it was not for the benefit of users!
                                          HP Slimline Slimline Desktop - 260-p025il (ENERGY STAR) Slimline i5-6400T Specification for Upgrade or Repair
                                          This specification for the HP Slimline Slimline Desktop - 260-p025il (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slimline Slimline Desktop - 260-p025il (ENERGY STAR) boardview and Slimline Slimline Desktop - 260-p025il (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          09-12-2024, 03:44 PM
                                          HP Slimline Slimline Desktop - 290-p0003ur Slimline 290 i5-8400 Specification for Upgrade or Repair
                                          This specification for the HP Slimline Slimline Desktop - 290-p0003ur can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slimline Slimline Desktop - 290-p0003ur boardview and Slimline Slimline Desktop - 290-p0003ur schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-12-2024, 02:15 PM
                                        • japlytic
                                          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                                          by japlytic
                                          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                                          Tried (only with keyboard/mouse connected):
                                          • BIOS + database update
                                          • Using latest Windows 11 image built with official image creation tool
                                          • Previous setup version for Windows 11 installer
                                          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                                          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                                          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                                          06-19-2025, 04:59 PM
                                          HP Slimline 260-p026l Slimline i5-6400T Specification for Upgrade or Repair
                                          This specification for the HP Slimline 260-p026l can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slimline 260-p026l boardview and Slimline 260-p026l schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          HP Slimline 290-a0001nw Slimline 290 A6-9225 Specification for Upgrade or Repair
                                          This specification for the HP Slimline 290-a0001nw can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slimline 290-a0001nw boardview and Slimline 290-a0001nw schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-12-2024, 02:30 PM
