Hp650 problem power with ic tps51225
  • moateez
    • Jun 2014
    • 119
    • algeria
    hello Friends
    Hp650 not power On i found just 3.3 v on ic TPS 51225 and no 5V
    please ineed equivalent for this ic idont have original ic in my lab
    thnx
  • moateez
    • Jun 2014
    • 119
    • algeria
    Re: Hp650 problem power with ic tps51225
    i found TPS51225C = APW8822C but same probleme also dont have this ic
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3630
      • slovakia
      why do u think this ic is bad when u not check it
      check all pins for voltage and resistance to ground
      • moateez
        • Jun 2014
        • 119
        • algeria
        ihave chek it bro
        Vin + Ldo3 +Ldo5
        the ic dont make 5v out
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3630
          • slovakia
          did u check pins on that 5V side like if u dont have shorted mosfets, ENTRIP...
          • moateez
            • Jun 2014
            • 119
            • algeria
            yes bro all ok
            • theone111
              by theone111
              3. Problem: TV shuts down
              07-22-2024, 10:36 AM
            • Duranitron
              Asus x512dk rev 2.1 power on problem
              by Duranitron
              When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
              Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
              11-26-2024, 10:22 PM
            • EazyBone
              LG OLED55C9PUA power problem
              by EazyBone
              Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
              Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
              I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
              The power supply to t con is different story.
              This...
              06-23-2023, 07:43 AM
            • Dr.d
              Help please..Lenovo ideapad 5 14itl05 power and charging problem
              by Dr.d
              I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
              Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
              04-05-2024, 11:48 AM
              by sam_sam_sam
              03-31-2024, 02:12 PM
