Possible to run Win7 on a Lenovo IdeaPad 330-15IKB, i3 gen8 & UHD 620
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    A client bought this stupidly......and very quickly discovered that w10 isnt what he wanted.......well I've got everything to work in win7 except the GPU, which is an Intel UHD 620.... I can not for the life of me find or force an older driver to work.... For Intel HD GPU's that claimed no support older than 8/8.1 or 10, I've always been able to do some trickery to make them work....but the UHD seems to be a different animal.... Any input would be appreciated!!
    CPU is an i3 8th gen, 4gb ram, and a 1tb spinner....
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Possible to run Win7 on a Lenovo IdeaPad 330-15IKB, i3 gen8 & UHD 620
    https://forum.videohelp.com/threads/...%28no-crash%29
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      If you were a sexy blonde Swedish lady, I'd give you a great big sloppy kiss!! ...but instead, beer on me! It worked like a charm! Apparently the UHD's require a little more modding than the older HD's do...
      Team : 49813
      Join in!!
      Team Stats
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3264
        • Singapore
        topcat, would u mind uploading the hacked .inf and .dll files here on the forum? i imagine this would be useful to others too. thanks.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          Certainly.
          Team : 49813
          Join in!!
          Team Stats
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            Last but not least with this piece of shit.....doing the setup, I used a normal keyboard & mouse.....well come to find out the touchpad doesn't want to work. I believe it to be a Synaptics clickpad (it doesn't appear in the device manager, so guessing based on system specs)....tried about a dozen drivers, nada. Of all the stupid BS....
            Team : 49813
            Join in!!
            Team Stats
            • sofTest
              • Aug 2008
              • 361
              Might be an Elan touchpad. Try this combo Synaptics & Elan package, should work for W7 also.
              https://pcsupport.lenovo.com/no/en/p...loads/ds121520
              Edit: You might also need the serial IO driver installed first.
              Be a mensch
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                No go. This is bizarre....of all the kooky things to not work, the fucking touchpad....
                Team : 49813
                Join in!!
                Team Stats
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  https://manjaro.org/
                  Problem solved
                  (It's to Arch linux as Ubuntu is to Debian, only far less bloated and junky. The Cinnamon edition is probably the best for former windows users who are new to linux).
                  Sorry, somebody had to...
                  sigpic
                  (Insert witty quote here)
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    should have gone with nvidia graphics.
                    it might be a touchpad connected to USB, and with 8th gen chipsets, USB 3.0 drivers are here
                    https://downloadcenter.intel.com/dow...Chipset-Family
                    you might have to find some way to install it automatically. With PC's it's usually easy to hook up a PS/2 keyboard. Laptops, different story. Slipstreaming them is the best way usually
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      Problem solved
                      no, that would just create more problems. The owner of this thing is a 69yr old man with zero tech skills.
                      USB is working, I have the intel usb3 drivers slipstreamed into the win7 installer, this thing has no usb2....so without, you'd likely get the 'missing media' error during the install.
                      The keyboard works though. I'd definitely have gone with nvidia graphics if I had a choice.
                      Team : 49813
                      Join in!!
                      Team Stats
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        Well, it depends on what model it is, DC, DE or FD.
                        There seems to be three different touchpads available for it: Alps, Synaptics or Elan.
                        Should be possible to figure out by looking at the device ID in device manager.
                        The Win7 version you used: is it the one I have slipstreamed with USB3 & NMVE support?
                        Just thinking out loud that maybe it does not have the latest USB3 drivers for such a new system.
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16958
                          this is the USB driver I have slipstreamed: Intel(R)_USB_3.0_eXtensible_Host_Controller_Driver_5.0.4.43_v2
                          I have no idea which touchpad it is....but I think it's the synaptics 'clickpad', as you can press just about anywhere on it, and it clicks....synonymous with the clickpad....but I have no HWID's to verify that. The label on the bottom says '81DE'
                          Team : 49813
                          Join in!!
                          Team Stats
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            look up the service express number and see what software they have for you for win10 for the touchpad. If it's synapitics, I know they released a unified generic driver from their website but last I looked was some time ago and I don't know it it covers win7 anymore
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5042
                              • US
                              heres an idea I thought of last night...did you fn+key to enable/disable the touchpad? see if it's enabled in the bios?
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16958
                                If there's a setting in the BIOS for it, they've hidden it good....I couldn't find it.
                                Team : 49813
                                Join in!!
                                Team Stats
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5042
                                  • US
                                  what fn+fx function + f-key with the touchpad symbol?
                                  is there a device for it in the dev manager?
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16958
                                    As I said earlier, no.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5042
                                      • US
                                      are there any question mark unknown devices?
                                      try fn+f6 (just looked at a manual)
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16958
                                        No
                                        I tried that too, one of the first things I did...no go.
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                          Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-07-2024, 05:20 AM
                                          Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          Lenovo IdeaPad IdeaPad 3 17ITL6 Ultrabook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 05:00 AM
                                          Lenovo IdeaPad IdeaPad 3 15IML05 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 15IML05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IML05 boardview and IdeaPad 3 15IML05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
