Panasonic Viera / 17IPS20 / Backlight or Driver?
  • essele
    • Mar 2019
    • 4
    I've just got hold of a Panasonic Viera 49” screen that seems to have a backlight issue.
    The screen turns on fine and runs for a few minutes and then appears to turn off, however it looks like it's just the backlight that goes off, everything else seems ok (sound is still there if I have enough time to get iPlayer started.)
    I've done a bit of initial investigation and I suspect the LED driver (MP3349S) on the 17IPS20 power board, as it appears to get really quite hot … pushing 60degrees when measured from the other side of the board, so it's going to be significantly hotter than this, therefore I'm thinking it's some kind of thermal shutdown.
    The time to turn-off does also seem to be impacted by how recently it's been on, so it does support being thermally related.
    But … in this forum people with similar behaviour seem to be pointed at LED failures in the backlight.
    In this TV these seem to be two separately powered strings of LED's, I've run each string independently for a good half an hour each using a current source, I've only gone to 8mA (because I'm paranoid) and this is achieved with a fairly constant 86V, no changes with time, no flickering, no indication of any problem. (Although I do acknowledge I'm not driving it very hard.)
    The other thing to mention is that the connector where the backlight cable joins the power board is quite deformed and has some small indications of charring. My guess is that there was some kind of poor connection, leading to arcing, leading to damage to the driver.
    Does this all sound reasonable? Or am I missing something?
    I'm really trying to avoid dismantling the panel, so I might be clutching at straws, but the LED's do all seem to be ok, and swapping the driver chip is pretty simple in comparison.
    Thanks for any help!
    Lee.
  • Maveriksam
    • Feb 2019
    • 3
    • United Kingdom
    Re: Panasonic Viera / 17IPS20 / Backlight or Driver?
    Hi essele
    I have the exact same problem but all my connectors look ok.
    I have striped my TV down and I have one LED that does not work. I am currently in the process to replace it.
    I will watch this thread with interest and I will post back if this fixed my issue.
    Do you have time to turn down the backlights to see if they last longer?
    • sintv
      • Feb 2015
      • 37
      • scotland
      Ive got the same problem. All leds light up and go off after a few minutes. Ive tried a couple of 17IPS20 boards but it looks like Ill have to get the correct board for the set. Must be a stock fault
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8342
        all you can do is to turn the back lights in the menu waaaay down, like to 10 or 20 %. See if the back lights stay on longer. If they do stay on longer, my bet is a bad LED in one of the strings.
        • essele
          • Mar 2019
          • 4
          Sorry to be so slow responding to this ... a combination of waiting for parts and being away.
          Anyway, like a fool I didn't listen to everyone's advice and I changed the driver ... at first I thought it had worked, but sadly no.
          So I dismantled the whole thing and discovered 2 faulty leds ... one was off all the time, the other was off when I was using my constant current source, but often came on (although sometimes with a delay) when using the TV supply.
          I've just replaced both of them and initial testing seems good. The driver still gets quite warm, but seems to be around 50 degrees now rather than 60, which I'm taking as a good sign, and I've yet to be able to get it to fail.
          So I'm going to see if I can remember how to put the thing back together now.
          • budwich
            • Jul 2015
            • 3097
            remember to turn down the backlight otherwise you will be doing more replacements.
            • essele
              • Mar 2019
              • 4
              Thanks.
              So it all seems to be ok from a backlight perspective!
              But unfortunately the panel seems to have an issue with a small band of slightly dimmer horizontal lines, I'm pretty sure these were there before I fixed the backlight ... it was an eBay punt!
              Anyway, I assume this is a panel issue so not fixable?
              Picture attached.
              Even if it's a write off, it was a great learning experience doing the backlight.
              Cheers,
              Lee.
              • budwich
                • Jul 2015
                • 3097
                not so fast on the "write off"... there are ways to potentially get rid of the "lines"... depending on the design of the panel... if it has side driver edge boards or not. IF not, a "tape cutoff" method may be used to block the signal to certain pins at the tcon that results in the drivers on the side associated with the lines to not be driven any more... clearing the picture. If there are side edge boards, then potentially there are ways of dealing with those. Read up some more on the forum about these issues and techniques and you might get a "fully working" display and learn some more things.
                • howardc64
                  Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                  by howardc64
                  Problem
                  Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                  Model & Board Pics
                  Conflicting Spec
                  Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                  https://www.shopjimmy.com/vizio-gj-2k1...
                  10-10-2024, 01:16 PM
                • signal.quest
                  Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                  by signal.quest
                  I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                  03-17-2024, 10:14 AM
                • triplefour
                  by triplefour
                  09-13-2023, 10:43 PM
                • osrex
                  LED DRIVER KEEPS DYING
                  by osrex
                  Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                  i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                  i have no datasheet at all for the LED lights, all i have is its length.
                  long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                  as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                  05-05-2025, 03:36 PM
                • DanPoka
                  Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                  by DanPoka
                  I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                  Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                  This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                  02-15-2025, 05:05 AM
