Macbook Mid 2012 NO Keyboard + Trackpad after GPU Change
  • Richi_el
    • Nov 2013
    • 95
    • Koln
    somebody know what could happen ?
    After Change the GPU with Rework station (BD82HM77 - SLJ8C) on pcb the keyboard + Trackpad + 1 of the usb ports are no more working.
    (the second usb directly beside is working)
    The device starting fine and all other functions are ok(wlan,ect.)
    By soldering process the BD82HM77 make a little bubble on the top (i think the ic wasnt dehumidified enoght). is it possible that is the reason`?
    thnx for help
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3630
    • slovakia
    Re: Macbook Mid 2012 NO Keyboard + Trackpad after GPU Change
    its called popcorn and yes its a bad thing
    • piernov
      • Jan 2016
      • 4439
      • France
      Obviously with a popcorned PCH it's not gonna work well…
      • Vliegenier04
        Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
        by Vliegenier04
        Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
        I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
        Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
        06-16-2025, 12:03 PM
      • mitchw
        MacBook Pro M4 Pro - no keyboard / trackpad / lid sensor
        by mitchw
        Hello
        I got this MacBook Pro M4 Pro to have a look at.
        It was tiny bit liquid damaged, just the edge of the board got 1 small 10x10 mm area wet. I've seen much worse that still worked fine to be honest.
        Since it was liquid damaged, warranty does not apply anymore.
        Anyways it was checked at an local Apple Store and they discovered that it needs new trackpad, new top case, etc. Also it needed a new lid angle sensor which they replaced.
        The main issue was that the screen remained black.
        Anyways I cleaned the liquid damaged area, put the machine back...
        09-06-2025, 07:19 AM
      • biosdi
        MacBook Pro A1989 trackpad and keyboard not working
        by biosdi
        Hi guys.
        I Just replaced battery on my MacBook Pro A1989. Unfortunately doing that, I’ve broken the trackpad flex cable (821-01701-a), and I’ve already ordered a spare one. At the same moment I’ve noticed that also the keyboard it’s not working anymore and I’ve found an SMD chip unsoldered and moving freely inside the backplate. I can read L20L on the chip. Is something could explain the keyboard not working or the keyboard doesn’t work due the unconnected trackpad?
        thanks...
        04-17-2025, 09:42 AM
      • iMuhtaseb
        A2681 Keyboard, trackpad and sleep?!
        by iMuhtaseb
        Wow it's been a while since I posted!
        This is a weird case, it has a history of liquid spill a year ago but customer did not want to replace neither trackpad or keyboard.. fast forward for today:
        A2681 turns on but not trackpad or keyboard feedback (or external keyboard and mouse) and then after a minute or so the Mac sleeps..
        It's a NOT a sleep sensor or trackpad or keyboard or daughterboard or anything else (I replaced all those); it's the logic board..
        Tested another locked logic board on customer's top case and it posted with keyboard and...
        05-22-2025, 09:59 AM
      • oemelectronic
        Macbook M1 820-02016 Keyboard -Trackpad stop working after a while
        by oemelectronic
        Hi friends.
        This model has a very weird fault.
        Macbook Air M1 A2337 - 820-02016
        it works for a while and after a few minutes the TRACKPAD AND KEYBOARD stops working
        I already formatted, I already changed flex and trackpad. The error continues, I tried with another keyboard and the same error happens.
        works for a while and then stops working trackpad and keyboard
        (i rebooted and it works again, after a few minutes the failure returns)
        THE BOARD LOOKS VERY CLEAN and IMPECCABLE
        09-30-2022, 08:37 PM
