Whirlpool Refrigerator LED lights flickering
  • bluto
    • Oct 2007
    • 560
    I have a Whirlpool side by side fridge that is not even 2.5 years old. Recently the LED lights inside the fridge and freezer started acting up. Instead of fading on when the door was opened, the lights would just flicker slightly. Closing the door and re-opening would seemingly fix the problem. The problem was intermittent, but I figured it was only going to get worse so I decided to do something about it.
    After some Internet searches, I determined that I was not the only with with this problem. There were dozens of reports of the problems with the same light module as what is in my fridge (W10515058). There were people that said they light failed when the fridge was just 19 months old. Some folks said they replaced the flickering module (spending between $75-$150) and it failed again in a year or two. There were some helpful videos on removing the module that also had some dubious fix suggestions.
    To start with, I removed the module following the instructions in this video: https://www.youtube.com/watch?v=pCY2iaOFgN8
    The module has two connectors. The first provides 120v to the board to power the lights when either the fridge or freezer door is opened. The second connector provides DC power to the other lights in the bottom of the fridge and freezer. Once this module is removed, all lights in the fridge will not function.
    Upon examining the module, the first thing that strikes me is how well it is made. It is a multi layer board with mainly SMD components. It also has a conformal coating over the board and all components. There is no fancy control logic chip, so I would surmise that the the fade-in effect is orchestrated by a simple resistor-capacitor timing circuit. And this board operates in a nice, constantly chilly environment for 15 to 20 seconds at a time... So what excuse does it have for not lasting 10+ years?
    I am going to take a stab at this and say that the problem is with one of the electrolytic capacitors on the board. There are a total of three of these capacitors present, a 3.3uf 400v (C6) and 2x 100uf 50v (C7 + C8). The first one appears to be the primary side filtering capacitor as it is near the 120v connector and in between the 4 diodes that seem to be the rectifier. The issue that I see is that the brand of this capacitor is 'Lelon' which happens to be on our bad capacitor list here. The other two caps are 'Nichicon' which are on our good list.
    EDIT: Replacing C6 did not solve the problem! I am still working to find a permanent fix and will update the thread when a solution is found.
    EDIT: September 2021:
    port443 seems to have found the solution to fix these boards:
    Originally posted by port443
    Confirmed and solved.
    My board had burnt-looking R15 with board lacquer damaged on top of it.
    Board needs 320+ degrees Celsius of iron temperature to melt the lacquer.
    Soldered 150 Ohm 1/2 W huge resistor in place of that bugger: there's a lot of space available around.
    Looking at all discussion, it looks like a design mistake: the wattage of resistor was not calculated right.
    slim_jim also fixed his light and noted:
    Originally posted by slim jim
    I repaired mine this way also. My original R15 chip resistor was scorched but not blown. One end had broken free. The old resistor checked 135 ohms.
    The light fade-on effect is absent, possibly because I used a 150 ohm resistor instead of 135.
    Thanks port443.
    Last edited by Per Hansson; 09-27-2021, 10:17 AM. Reason: Add: Edit September 2021
    • 31262
    Re: Whirlpool Refrigerator LED lights flickering
    it's probably a bad led, i see the board is designed to take 2 different styles.
    • bluto
      • Oct 2007
      • 560
      Oh noes, the flickering is back today! Arrgh... I don't know what to do next.
      Maybe isolate the fade in bit and just tie the gate voltage of that transistor to Vcc? I might have to buy another one so I can experiment on the original.
      This thing really shouldn't fail en-mass like what I have seen online as described above.
      @stj, I don't think it is a bad LED because all 4 along with the other two LED modules connected to the output port are all acting up at the same time (intermittently).
        • 31262
        are the led's in series though??
        • redwire
          • Dec 2010
          • 3912
          I kinda thought an LED is to blame, see all four have the "black dot of death" in pics?
          Maybe the primary cap failed and then it hiccuped and killed the LEDs. It's not like they run for very long or get hot (in a fridge), unless Whirlpool overdrives them.
          It looks like the PCB uses SMD 5630 LED's with 4-pin package and thermal pad, around 1/2W ea. Also has footprints to take SMD 5050 6-pin LED with thermal pad. I'd order a bunch of new LEDs.
          All that electronics to light up four LEDs with fade effect. 38 testpoints
          • Kenmore
            • Apr 2019
            • 1
            Bluto -
            I'm facing the exact same problem on a Kenmore fridge; apparently many domestic fridges used the same set of three Whirlpool LED PCBAs.
            However, on my control board, R15 (LED side of the board) is obviously toasted. Since your R15 appears to re unaffected, could you tell me the value marked on your R15?
            The adjacent R17 is unaffected, and is marked 910 ohms. I've done a lot of research on this problem, and others have reported both R15 and R17 as having been grossly overheated, enough to obliterate the markings. I have not been able to locate a schematic.
            I'll take some photomicrographs of the toasted R15 on Monday, and post them here.
              • Jul 2011
              • 6070
              If you replace LEDs modules
              I would recommend that you look at the specifications of the type LED that you will be using
              and make sure that they are not being over driven by too much current and voltage you will need to know how these LEDs are wired this is going to be very important to know
              • bluto
                • Oct 2007
                • 560
                My R15 reads just under 138 ohms. It looks like the number is starting to blacken, I think the code number is 1370 which would be 137 ohm +/-1%
                • Dave125
                  • Aug 2019
                  • 10
                  Bluto -
                  did replacing R15 fix the problem?
                  • Dave125
                    • Aug 2019
                    • 10
                    a guy at work soldered on a 1.8kOhm resistor to replace the R15 resistor and the lights came on! I'll test it out in the fridge tonight
                    • hoonigan_elec_engineer_04
                      • Aug 2019
                      • 4
                      I replaced the R15 resistor with a 1.8k ohm resistor 1/4 watt. I was able to put resistor in its place without interfering with putting the lens cover back on. I touched up some suspect solder connections that may be cold solder joints hence the burnt marks on PCB board. I had to melt off the rubber coating until I could get some solder to roll on the connections.
                      Bluto -
                        • Aug 2019
                        • 4
                        Bluto -
                          • Aug 2019
                          • 4
                          R15 is a 1.9k ohm resistor. I replaced it with a 1/4W 1.8k ohm resistor in its place and lights are working. See my recent post with pictures. I also touched up some possible cold solder connections too.
                            • Aug 2019
                            • 4
                            Try replacing R15 with a 1/4 Watt 1.8k ohm resistor and touch up some solder connections that look a little suspect for a cold solder joint. See my recent post with pics.
                              • Jul 2011
                              • 6070
                              I am confused about this if the resistor has a marking that say 1370
                              and you get 137 ohms how do come up with 1.8k ohm that makes the LEDs start working again
                              • Dave125
                                • Aug 2019
                                • 10
                                unfortunately when I tested the light in the fridge it flickers off and on, so I have a strobe light now. I may go with a homemade LED light strip
                                • R_J
                                  • Jun 2012
                                  • 9610
                                  Try replacing the resistor R15 with the correct value of 137Ω. You can't use a 1.8k which is 10x what it should be and expect it to work.
                                  • bluto
                                    • Oct 2007
                                    • 560
                                    I'm still following this thread.. I still get the intermittent flicker occasionally when opening the fridge. Cycling the door light switch plunger will quickly clear the problem. I have left the light cover off so the light is hanging by the wires. Once when it flickered I tried unplugging the output side connector and all the lights went out. So that pretty much confirms that the LEDs are in series.
                                    Other than that, the problem is not bothering me enough to do anything else about it right now.
                                    • fanplant
                                      • Aug 2019
                                      • 3
                                      I'm repairing one of these boards for a friend. My R17 is completely burnt and R15 is illegible. I'm going to search what I have laying around and scratch off some off the conformal coating and solder on new resistors but before I do I'd like to get the values correct. From what I know the markings of SMD vary so this is what I know:
                                      R17 has a 3 digit code of 910 that equals 91ohms
                                      http://kiloohm.info/smd3-resistor/910
                                      R15 has a 4 digit code of 1370 that equals 137ohms
                                      http://kiloohm.info/smd4-resistor/1370
                                      Now I would love to know the purpose of these so I could maybe change the values to provide less light for the advantage of the LED and driver circuit lasting longer. By the way does anyone know what kind of driver this is? Constant current or constant voltage? There are cheap aftermarket drivers out there.
                                      • R_J
                                        • Jun 2012
                                        • 9610
                                        The circuit does'nt look that complicated, what are the markings on Q2 & Q3? You have the board so draw out the schematic and post it if you can. I don't think you will find a schematic anywhere.
                                        • reessi
                                          ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                          by reessi
                                          The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                          They are black on the right and gradually fade to nothing on the far left.
                                          They start either after 5 mins or up to 2 hours after so annoying for testing.
                                          They flicker continuously very fast! With a slight pause milli-second every second.
                                          Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                          I tested each half by removing the first the left flex from...
                                          06-03-2025, 09:58 AM
                                        • wnlewis
                                          Whirlpool RDE3340W electric Range needs On-Off-On rocker switch, McGill 0801-1059, FSP 686605, Whirlpool p/n 865745
                                          by wnlewis
                                          I am trying to track down a replacement rocker switch for a Whirlpool RDE3340W electric range.
                                          The rocker switch was made by McGill under their part number 0801-1059 and supplied to Whirlpool by FSP under their part number 686605. Whirlpool's original part number was 865745.
                                          The switch is an On-Off-On type (SPDT) designed for use with either 115 VAC or 230 VAC. It is not lighted.
                                          Are there any current switches that could be substituted for this switch?
                                          01-04-2025, 09:32 PM
                                        • DrvLikHell
                                          Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
                                          by DrvLikHell
                                          Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
                                          The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
                                          07-05-2024, 02:54 AM
                                        • mikey5791
                                          Help repair Panasonic fridge not cooling
                                          by mikey5791
                                          Hi all forum members,
                                          Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
                                          After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
                                          07-16-2025, 02:01 AM
                                        • Jaysean
                                          Acer VN7-591G-70RT Display Flickering
                                          by Jaysean
                                          Hello Badcaps coummunity hope you all are having a bless day,
                                          Hope I didn't post it wrong kinda new at forum site rules and tradition
                                          So I'm dealing with screen flickering problem on my laptop.
                                          I'm not quite sure if it's the display cable or the screen itself that's causing the issue,
                                          so I'm turning to you all wonderful expert on Badcaps for some guidance. Your help is much appreciated!
                                          [Screen Flickering](https://i.imgur.com/xK9vHqc.mp4)
                                          [HDMI port to external display seem to work be working](https://i.imgur.com/snSC24e...
                                          10-27-2023, 10:22 AM
