Help HP Z440 workstation bios
  • Fabbrone
    • Jun 2015
    • 158
    • italy
    Good morning, the pc only turns on the front led and the fans but not from acoustic signals or other. I have already tried to change the video card to the RAM and the CPU but nothing. Could it be the bios?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5008
    • New Zealand
    Re: Help HP Z440 workstation
    I assume it worked before?
    Have you tried a known good power supply?
    -David VanHorn
    • Fabbrone
      • Jun 2015
      • 158
      • italy
      yes I have already tried another power supply but nothing
      • Agent24
        I see dead caps
        • Oct 2007
        • 5008
        • New Zealand
        Check BIOS battery is not low, if it is, replace the battery and reset BIOS settings with hardware button or jumper?
        -David VanHorn
        • Fabbrone
          • Jun 2015
          • 158
          • italy
          The battery is ok
          what do you mean to reset the BIOS settings with the hardware button or the jumper?
          I moved the jumper for the reset but nothing
          • Fabbrone
            • Jun 2015
            • 158
            • italy
            someone has available source of bios ?
            • Agent24
              I see dead caps
              • Oct 2007
              • 5008
              • New Zealand
              Yes, that's what I mean. Move the BIOS reset jumper. Make sure you move it back afterwards.
              Can you get the BIOS from HP? Typically they don't go bad by themselves though...
              -David VanHorn
                • 21441
                There`s only a bios update on hp .What is the serial number,to get to the correct support page, and can you post your bios backup .
                • Fabbrone
                  • Jun 2015
                  • 158
                  • italy
                  is this the first time I disassembled this machine, to remove the main one you also need to remove the screws under the heat sink?
                    • 21441
                    Service manual http://h10032.www1.hp.com/ctg/Manual/c04823811 .Did you try a bios recovery disk.
                    • Fabbrone
                      • Jun 2015
                      • 158
                      • italy
                      Ok removed, here is the original source
                      • Fabbrone
                        • Jun 2015
                        • 158
                        • italy
                        no I have not tried with recovery disk
                          • 21441
                          Two different bios to try,the bios backup had errors decompiling with Flash Image Toolkit, meaning the ME was corrupt.
                            • 21441
                            The 2 bios posted above aren`t working. Here`s 2 new ones to try.
                            • Fabbrone
                              • Jun 2015
                              • 158
                              • italy
                              even with this version fans and LEDs light up but nothing is displayed
                              • dj_ricoh
                                • 2073
                                • uk
                                My hp z400 beeps if it doesn't post.
                                If the power button it's blue the it passes the cpu ram then GPU
                                If there is no display with blue power button the it's GPU.
                                That series it's heretic with beep sounds if something it's wrong.
                                • ant3202
                                  • Jun 2006
                                  • 275
                                  • Singapore
                                  just checking if you had tried with the same power supply?
                                  Not sure if the power supply is standard...
                                  the last time I had worked with Z400 ... PSU pin layout is a little different.
                                  • PRIME
                                    • Jun 2016
                                    • 3
                                    • Ghana
                                    your old file works fine for me
                                    • digitalpc
                                      • Jun 2016
                                      • 305
                                      • .DLL
                                      Hi my friend, do you fix this problem I have one Z440 with same problem, I try Bios from here nothing different.
                                      • ClickCLK
                                        • Oct 2017
                                        • 3
                                        • Russia
                                        Sorry for posting in an old thread, but I was trying to fix this computer and flashed "Z440 PRD_EXT_ME M60_0247.zip" by @SMDFlea. With this bios motherboard shows no post codes (and it was showing some of them with original bios), so this bios file isn't working. I built one myself using update from hp support and clean me region. After flasing this bios system booted ok.
                                          HP Z440 Workstation E5-1620V4 Specification for Upgrade or Repair
                                          This specification for the HP Z440 Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z440 Workstation boardview and Z440 Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-12-2024, 03:44 PM
                                          09-12-2024, 03:36 PM
                                          HP Z440 Workstation E5-1620V3 Specification for Upgrade or Repair
