dell vostro 3559 la-d071p does not turn on
  • poweron
    • May 2019
    • 371
    • italy
    hello everyone, as soon as I plug in the power supply the power led turns on and turns off after 2 seconds, fan stopped, how do you check the power sequence
    thank you
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: dell vostro 3559 la-d071p does not turn on
    Try disconnecting the AC adapter & battery. Remove RAM & CPU put back it again,Press and hold the power button for 30 seconds. Reconnect power and try starting the Mob again.
    • imranromi
      • Jan 2015
      • 1288
      • Pakistan
      CPU onboard this model i think 7thgen
      • poweron
        • May 2019
        • 371
        • italy
        the CPU is welded not removable, I will do this test
        thank you
        • poweron
          • May 2019
          • 371
          • italy
          is an i5 of the sixth generation
          • poweron
            • May 2019
            • 371
            • italy
            after doing this test now when I connect the power, the power led turns on and at the same time the fan all for 2 seconds then everything turns off, and if I press the on button nothing comes on
            • Techtiger
              • Oct 2014
              • 1602
              • france
              ok test you BIOS battery for +3.3V, test the power button for +3.3V
              +3VS is enabled by SLP_S3# so check if SLP_S3# is present? and check if +5VS is present as well they if the fan is spinning you should get SLP_S3#, if your MOB AAL15-la-d071p i have uplode the Schematic check out page 37 G6101 is your power button , page 22 is Bios battrey +RTC CELL , for SLP_S3# pin 70 SIO page 29
              • poweron
                • May 2019
                • 371
                • italy
                SLP_S3 # is present for 2 sec as the + 3VS and + 5VS, the power button is ok and battery bios is ok 2.98v, if power button is pressed the + 3VS and the + 5VS is present for 2 sec
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  now check SIO pin 126 RTC VCC 122 VBAT and page 11 of schematic
                  • poweron
                    • May 2019
                    • 371
                    • italy
                    pin 122 VBAT = 3.1v pin 126 RTC VCC = 3.1v the voltages with the question mark I can't measure them, where can I take them?
                    • poweron
                      • May 2019
                      • 371
                      • italy
                      + RTC_CELL = 3.1v
                      • poweron
                        • May 2019
                        • 371
                        • italy
                        the battery charges regularly
                        • Techtiger
                          • Oct 2014
                          • 1602
                          • france
                          now test pin 67 of SIO SLP S4, if the Voltage is not stable remove the RZ1701 and see , have you flashed BIOS in past ?
                          • poweron
                            • May 2019
                            • 371
                            • italy
                            meanwhile, thanks for the patience you have, on pin 67 SIO SLP S4 I measure 3.2v only for 2 sec when I connect power then back to 0v, and if I press the power button it goes back to 3.2v for 2 sec. I reprogrammed the bios many times because I couldn't find the right one, now I think it's the right one because it behaves as it did at the beginning
                            • Techtiger
                              • Oct 2014
                              • 1602
                              • france
                              Well can you test all the Coil resistance to GND , PL1102/3 is your VGA supply remove one Leg each coil and see for any changes, as soon you power the mob try to find out which coil is not outputting power, page 55 is your power sequence follow it up
                              • poweron
                                • May 2019
                                • 371
                                • italy
                                these coils are not present, this card does not have a graphics chip, it is integrated in the cpu
                                • Techtiger
                                  • Oct 2014
                                  • 1602
                                  • france
                                  • poweron
                                    • May 2019
                                    • 371
                                    • italy
                                    I measure as I am or have to lift a terminal
                                    • Techtiger
                                      • Oct 2014
                                      • 1602
                                      • france
                                      Without Lifting the coils , as soon you power the mob try to find out which coil is not outputting power
                                      • poweron
                                        • May 2019
                                        • 371
                                        • italy
                                        PL605 (VCC_GT) and PL603 (VCC_CORE) = 0v
                                        PL601 (VCC_SA) = 1.0v only for 1 sec, pressing power buton is present for 1 sec
                                        PL301 (+ 1VALWP) = 1.0v only for 1 sec, pressing power buton is present for 1 sec
                                        PL200 (+ 1.35VP) = 1.35v only for 1 sec, pressing power buton is present for 1 sec
                                        PL100 (+ 3VALWP) = 3.3v always present
                                        PL101 (+ 5VALWP) = 5.0v always present
                                        PL700 (+ 17.4V_BATT) = 17.4v battery charging voltage always present
                                          DELL Vostro 3559 Notebook 3000 Specification for Upgrade or Repair
                                          This specification for the DELL Vostro 3559 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3559 boardview and 3559 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 3559 Notebook...
                                          09-06-2024, 06:11 AM
                                          DELL Vostro 3470 Vostro 3400 i3-8100 Specification for Upgrade or Repair
                                          This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                          09-12-2024, 03:44 PM
                                          DELL Vostro 3471 Vostro 3400 i3-9100 Specification for Upgrade or Repair
                                          This specification for the DELL Vostro 3471 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3471 boardview and Vostro 3471 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                                          DELL Vostro 3671 Vostro 3600 i5-9400 Specification for Upgrade or Repair
                                          This specification for the DELL Vostro 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3671 boardview and Vostro 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
