Failing to programing V850ES/JG3 with UART
  • Sojke
    • Apr 2017
    • 131
    • Serbia
    Hello , I am having problems sending code that was given to me, in binary format, to this microcomputer via UART0.
    I have connected UART0 directly to my UART USB interface onto header of FTDI232 USB adapter , and the microcomputer responds to some given instructions, like erase, blank check, checksum, read (dumps perfectly valid HEX file that corresponds to given BIN file when converted, exactly the same data in original from chi and spare file), but it wont program. - I have been given an BIN file to work with, but either way an read HEX file wont program either.
    When it fails writing I have to reset the micro computer and the visual led diode clearly shows when it failed, the microcomputer simply never responds again. Depending on the file I try it always fails at the same spot.
    • 31144
    Re: Failing to programing V850ES/JG3 with UART
    have you got a datasheet to share?
    if it's an ARM cpu you may have to erase any sector protection before you can program it.
    • Sojke
      • Apr 2017
      • 131
      • Serbia
      Yes, this is the datasheet.
      I have tried complete erase and block erase but it always fails. I am not sure why, as when it reads the chip it reads the complete thing, from start to finish, correctly. When the read file is compared to the one I am about to program it is identical.
      The reason why I am trying to program a new chip is because the in-circuit one has been damaged by lightning and has no function on certain pins (0ohm ground within the chip).
      I have only used chips, salvaged from other boards with different damage on each board, to work with.
        • 21444
        Have you read the programming notes:
          • 31144
          what about the 2 flash-control pins?
          one must be grounded and the other toggled to enable writing.
          • truclacicr
            • Apr 2019
            • 331
            • australia
            Don't you need to erase the uC before reprogramming it? If you can't erase it, then what's the point of trying to write to it?
            Have you checked the status of the security bit?
            • Sojke
              • Apr 2017
              • 131
              • Serbia
              Sorry for misleading information, erase always completes with blank check confirmation.
              The chip erases, blank checks, reads and status reports. Also has some security bit exists , this is it:
              ------ Start(Signature Read) ------
              Device name: UPD70FXXXX
              Device data: 10 7F 04 EC 7F
              Security Flag: 007F
              Boot Block Number: 01F
              Firmware Version: 1.11
              Signature Read PASS
              ------ End(Signature Read) ------
              The flash control pins were set as FLMD0 to Ground via 10kohm like in schematic and FLMD1 to VCC via direct wire connection.
              I have read flash programming notes, thanks for the snippet, they are also present in the complete manual I linked.
              - EDIT -
              From what I see from all this, 007F corresponds to binary 1111111 meaning that every possible security feature was enabled on this chip (which is kinda weird knowing that I managed to read it). I believe now this is where my problem is at (thanks truclacicr).
              • m1ch43lzm
                Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                by m1ch43lzm
                Hi everyone
                I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                There's also an extra OTP Secu.R...
                09-06-2025, 05:47 PM
              • Forest79
                Lenovo ThinkStation P520 BIOS file needed
                by Forest79
                I got a Lenovo ThinkStation P520 (Type 30BF) from a friend, asking me for a repair. Windows 11 offered a firmware upgrade as an optional update, and it failed.
                The emergency flash procedure from the hardware manual has also failed. So, I asked an acquaintance with better skills to flash the BIOS directly.
                However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                07-23-2023, 07:39 AM
              • Citymin
                NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                by Citymin
                My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                The charging red LED lights up, but the charging screen doesn't show any indication.
                When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                (I've tried removing the battery and resetting the device, but the issue persists.)
                NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • iZakre
                HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                by iZakre
                Hello everybody!
                To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                The thing is that I had installed TeamViewer and could log into the computer...
                02-19-2023, 02:27 PM
              • hazem3636
                need Bios Bin file Dell server 220
                by hazem3636
                hi everyone
                i need dump file for dell server r220
                i have download Flash BIOS executable file but i dont know how to conver it to Bin file
                i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
                if anyone has this method please need his supporting .
                all the best
                EXE file is attched and Original Bin file from the Bios Chip is attached also
                and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
                11-05-2022, 06:20 AM
