LG 32LE5500 bad video
  • angelos
    • Dec 2012
    • 573
    • South Africa
    HI guys, i have this set with bad video, stripy jittery as best i can explain it.
    A youtube video is here below
    https://youtu.be/dqxnZPAzo-U
    I have attached some pics of the boards.
    The PSU voltages seem fine with no ripple
    There are two voltage regulators on the main board and measure 1.5V and 1.8V
    I suspect the main or tcon but might be wrong since i dont have a schematic for them.
    Is there any way i can prove its not the main so that i can focus on the tcon?
    Regards
    Angelos
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 32LE5500 bad video
    Looks like a bad T-CON Bd. to me.
    • angelos
      • Dec 2012
      • 573
      • South Africa
      Hi Andrew. Is there any way i can prove it?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        There a voltages test points on the T-CON Bd. to measure. However, you could disconnect one of the Ribbon cables connecting the T-CON Bd. to the Long Panel Bds. on the Screen. Do left side then right side and see if either half picture shows good or not.
        • angelos
          • Dec 2012
          • 573
          • South Africa
          I had done this test and it did not help. The side disconnected was white and the other side was making those same stripes. It did this to both sides. What does this mean? Panel or Tcon or main?
          Regards
          Angelos
            It looks like main board issue.
            Did you try heating or cooling the main board to see if it has any effect? Try that on T-CON too.
            • angelos
              • Dec 2012
              • 573
              • South Africa
              Hi Budm,
              I heated the main board and when focusing heat on the processor the fault went away completely. This is a BGA type chip. There is no way i could resolder this chip. This one's going to the landfill.
              Funny enough it is working fine now, and i did not apply much heat either.
              • nomoresonys
                • 12212
                • U.S.
                Maybe do a reflow, lots of tutorials on youtube about what temperatures to get to and so forth, sounds like it might respond favorably.
                • advant
                  by advant
                  02-03-2020, 12:25 AM
                  HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                  This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                  09-12-2024, 02:00 PM
                • iizik
                  P15 Gen 1 (type 20ST, 20SU) Laptop (ThinkPad) - Type 20ST need main and video BIOS
                  by iizik
                  P15 Gen 1 (type 20ST, 20SU) Laptop (ThinkPad) - Type 20ST needs the main BIOS and video. The client says that after the Windows updates there was a firmware update and after that the device makes the sound of music when there is no screen. Moreover, if you turn it on several times then the picture sometimes appears and it works and passes all tests (wonder)
                  and may even reboot normally a couple of times
                  Now he doesn't want it anymore, no matter what I tried
                  It helped to change the video cable a couple of times, I ordered a new cable, it didn't help
                  Of course I checked the...
                  07-17-2024, 09:58 AM
                • Hakuu
                  by Hakuu
                  Hi There,
                  More Details
                  TV Model - LG OLED77G1PUA
                  07-12-2023, 02:37 PM
                • kca
                  by kca
                  Hello all ~
                  08-31-2025, 06:38 AM
