Hakko FR301 and FX600 decent for motherboard recapping?
  • cmr-informatik
    • Jun 2019
    • 5
    Hey all,
    It's been a long time since I last worked with any motherboard-type PCB (original XBOXs), but I am looking at a stack of DFI nF4s I'd like to recap.
    My most recent soldering has just been mechanical keyboards and PC fan-controllers with a cheapo soldering iron (UY CHAN TS100). I'm wondering if a Hakko FX600 is a better choice?
    I also need a desoldering gun, the Hakko FR301 looks pretty decent - does anyone have experience with that model and motherboards here?
    Any other suggestions (preferably <$500 for both, but there's some wiggle room)?
    Thanks!
    • Jul 2011
    • 6070
    Re: Hakko FR301 and FX600 decent for motherboard recapping?
    I personally do have this brand of Desoldiering Gun so I can not comment on this unit
    Here is my two cents worth on this question
    I have a few of these and for most part they work good for about half the price
    https://www.mpja.com/Desoldering-Sta...info/19034+TL/
    But I do have a few suggestions for you if you buy one of these units
    First one is to recap the switching power supply unknown brand of capacitors used
    Second get a spare gun ( if heating or temperature sensor goes bad ) you do get long life from them
    Third get spare tips ( do not last very long if you pry with the tip )
    Forth get spare filters for the gun ( get dirty very quickly )
    One very important note clean soldering gun tubing often this is a must or you can have the flux clog the tubing and then you have to take a 1/16” drill bit to drill it open again this is a pain in the a** to do with out damaging the tubing
    I have a unit that is very similar to this unit and for most part it works very well
    but do buy a spare heater element for it they will just stop working all sudden
    https://www.mpja.com/Temperature-Con...info/32580+TL/
    I will add one more comment to what STJ has below if you are going to this type of work you will need to also get a temperature controlled hot air gun this will come in very handy
    https://www.mpja.com/Hot-Air-Rework-...tinfo/34737+TL
    This unit works very well it has very nice air flow and the control for the the pump is very smooth
    The temperature controller works very well
    I do have one complaint about it and it is that it does not have a cool down mode meaning that it does not turn off the heater and just blow cool air
    You can fix this problem if you want to and it just find the temperature sensor wires and put a switch on it and that solves this problem
      • 31265
      i actually doubt any desoldering station will work for a motherboard without extra heat from an air-station, the hollow tips cant transfer enough heat to the board.
        • Jul 2011
        • 6070
        There is a correction in what I had said earlier
        “You can fix this problem if you want to and it just find the temperature sensor wires and put a switch on it and that solves this problem”
        It should have said the following
        You have find the temperature sensor controller output to the optic sensor input
        If you buy one and you do the modification let know and I will take mine apart to show you which wire that you put the switch on
        • llonen
          • Sep 2014
          • 495
          • hampshire
          If you have a budget of around $500 plus a little wiggle room, then I would choose second hand Pace over Hakko every single day. When I was originally setting up my workshop my choices were between Metcal, Pace and Weller I got lucky on a couple of clearance sales and ended up going with Pace.
          • cmr-informatik
            • Jun 2019
            • 5
            Thanks for the recommendations guys!
            I am a little hesitant about potentially modifying my own equipment, but I guess it's no different from any other electronics work I suppose.
            Which particular Pace station/iron would you choose over the Hakko gun?
            This video led me to believe I may not need to pre-heat/heat the motherboard:
            https://www.youtube.com/watch?v=0vY3DgUbtSM
            I guess the only way to find out is to try... good thing I have plenty of busted boards to practice on.
            • llonen
              • Sep 2014
              • 495
              • hampshire
              Something along the lines of a Sensa-temp MBT 250 soldering station and Pace SX 80 Endura de-soldering hand-piece. The MBT 250 soldering station is three channel which gives you plenty of scope for expansion later.
              • glovecaps
                Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                by glovecaps
                I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                11-25-2024, 04:23 PM
              • Docus
                Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                by Docus
                Hi everyone 😀,
                I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                1. I already own the exact same model, but its plastic chassis is badly damaged.
                06-10-2025, 04:24 PM
              • Archimedes
                HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                by Archimedes
                Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                Fans are spinning. Blindly could install windows11 and got the device manager...
                07-30-2024, 05:14 PM
              • dragon3x
                After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                by dragon3x
                Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                power on.
                Here are some examples :
                (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                switching supply area).
                (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                than 6.3 V.)
                1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                I replaced capacitors with aluminum-polymer.
                3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                03-21-2025, 02:46 PM
                ASUS P5GC-MX motherboard recap
                by momaka
                Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                So here is what the motherboard looked like with its original caps:
                CPU VRM area up close…...
                01-27-2021, 11:59 PM
