HpFeature update to Windows 10, version 1903 - Error 0x80244018
  • ivtec
    • Dec 2008
    • 1967
    Hi guys; i'm trying to update my HP DV6 P7350 to version 1903 and i get bellow fail error ,is this PC not compatible with this version of Win 10? thanks
  • R_J
    • Jun 2012
    • 9622
    Re: HpFeature update to Windows 10, version 1903 - Error 0x80244018
    How are you doing the update? I usually download the iso to do the update.
    Have you tried the solutions available? here is just one site https://ugetfix.com/ask/how-to-fix-w...on-windows-10/
    • ivtec
      • Dec 2008
      • 1967
      Thanks; R_J , i was able to install Version 1903 after using a couple times the Updates Troubleshooting tool,thanks
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        The TV does not turn on, the standby indicator is on. All voltages are present.
        Emms is dead. Not readable, not detected.
        Replaced emmc.
        But with another dump there is no launch
        Terminal log
        UART
        AC_ON
        RPMB key is not yet programmed
        HASH1_VERSION=0x00000000 64bit
        E-B
        FDE enabled
        layout pattern onebin by SAR7,0...
        06-01-2025, 02:11 AM
      • sikocan
        Lenovo X1 Carbon 9th Gen Black Screen
        by sikocan
        I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
        SN: PF3G1REP
        MODEL: 20KW-00J1AU
        PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
        Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
        06-24-2025, 09:01 PM
      • TheUser
        Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
        by TheUser
        Hello to everyone ,
        This is my first post here, and i would like to share with you a small story in case you can help me.
        Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
        All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
        I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
        02-10-2024, 02:07 PM
      • unick
        Laptop HP 850 G2 Keyboard error after Windows 11 update
        by unick
        Hello
        i have following problems on HP 850 G2 laptop and 840 G2 laptop. After win11 update 24H2 the keyboard and touchpad stop working. I delete the keyboard from device manager and restart : work. If i shut down the laptop and restart after 5 min the problem apear again: no keyboard and no touchpad active. I have used also hp driver from oficial sit but no luck. I have modified with regedit " i8042prt Start REG_DWORD with 1, but no suscces. Any ideea?
        09-15-2025, 07:47 AM
      • ahmedtou
        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
        by ahmedtou
        Hi everyone,
        help me please
        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
        I will share all the details with you, including the disc information.
        Code:
        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
        Current Profile: BD-R
        Disc Information:
        Status: Empty
        State of Last Session: Empty
        Erasable: No
        Free Sectors: 12,219,392
        Free Space: 25,025,314,816 bytes
        Free Time: 2715:27:17 (MM:SS:FF)
        Next
        08-27-2025, 08:49 AM
