Nintendo Switch component identification
  • pintglass
    • Jul 2019
    • 79
    • United Kingdom
    Hello
    Could anyone identify the component in the attached image, i believe it to be a dual P-channel mosfet in a udfn package 2.0 x 2.0 the marking on the device is J03
    I've searched alot of manufacturers without success.
    Thanks Pintglass
  • R_J
    • Jun 2012
    • 9635
    Re: Nintendo Switch component identification
    Seems to be a ROHM UT6J3
    • pintglass
      • Jul 2019
      • 79
      • United Kingdom
      Thanks for that i had been searching for ages for 6 pin mosfets not thinking about the pads underneath.
      As you probably guessed I'm trying to repair a nintendo switch.
      I've attached a pdf of the circuit that the switch uses to charge the battery & to provide power when the battery is dead.
      At the moment the battery is dead only reading 2.7V but on inserting power via the usb cable the system won't boot and the battery will not charge.
      The BM92 power delivery controller has been changed but im seeing the same issue.
      I have numbered the mosfets on the pdf from 1-4
      Mosfets 1 & 2 are SSM6K504NU single channel n type
      Mosfet 3 is a dual channel n type AON2812
      Mosfet 4 is the one that i had been searching for which is a dual p type UT6J3
      Mosfets 1,2,3 are controlled from the BM92 using an internal charge pump
      Mosfet 4 i believe is part of a buck boost converter circuit to provide 5V to the system if the input voltage from usb C is above system voltage.
      At the moment when i connect the device to power via usb I'm getting the correct voltage coming in to mosfet 1 but on the drain of mosfet 2 im getting a fluctuating voltage with a peak of 1.8v should this not be higher I'm also getting the same fluctuating voltage on the gate of mosfet 1 should that not be higher than Vbus to turn the mosfet on?
      If anyone can tell me roughly what the mosfets should be doing i would be very grateful
      • pintglass
        • Jul 2019
        • 79
        • United Kingdom
        I thought it was a long shot that anyone would be able to help with figuring this out.
        I'm about 80% there now, but again I'm struggling to find a datasheet for the component in the attached image.
        The component is as far as i can tell a buck controller in a bga package, pretty certain its 20 pin, size is approx 2.3 x 1.8 and it has the markings EN6L on it.
        Thanks Pintglass
        • SheriffBuck
          • Jan 2020
          • 3
          • United Kingdom
          Hey PintGlass.
          Did you solve this in the end? I've got a couple of switches exhibiting the same issue. I've been focusing on the ALERT/GPIO pin which appears to be signalling a failure condition. Might be a common issue if you're still working on your Switch repair?
          • RethoricalCheese
            • Mar 2013
            • 1519
            • Estonia
            Not sure about Nintendo switches but some devices wont boot without a battery or with an empty battery. So try charging the battery to 3.7-4.2V using a power supply.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              maybe join this facebook group too as they have some very good information regarding switch repairs https://www.facebook.com/groups/ps4r...?ref=bookmarks
              • jikonik
                Nintendo switch Help about Component identification
                by jikonik
                Hello I have a nintendo switch HAD-CPU-10 and the component in the red circle is knocked... any help to identify it will be highly appreciated!
                03-25-2024, 01:05 PM
              • kotel studios
                Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                by kotel studios
                Finally got time to fix this board up.
                At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                04-22-2025, 05:08 AM
                Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-06-2024, 05:30 AM
              • r12x2
                Mosfet identification on hp pavilion 16-ag0052wm
                by r12x2
                Looking for an exact ID or fully compatible replacement for a dual N‑channel MOSFET used as a synchronous buck pair in a laptop charging stage. The package is the compact ~ 3×3 mm “dual” type where high‑side and low‑side FETs are integrated with a common SW node. The part sits right next to the buck inductor on the charger section. marked as 3840C 35039E. With these thermal pads, it looks like an onsemi NTTFD4D0N04HL or a part from AOS’s AONE family (DFN 3.3×3.3, 8‑pin options such as AONE36132, AONE36182, AONE36196, or AONE38132), but they are not pin‑to‑pin compatible....
                09-25-2025, 04:31 PM
              • Jane
                How do you test MOSFET in laptops ?
                by Jane
                I tried to use this method:
                Testing an N-channel MOSFET:
                Step 1: Discharge the Gate (turn off the MOSFET)
                Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                Step 2: Charge the Gate (turn on the MOSFET)
                Now, place the red probe on the Gate (G) and the black probe on the
                09-27-2024, 03:31 AM
