Lexmark 654dn power supply dead fans on part # 40x4355
  • Jluxster
    • Jun 2019
    • 17
    Hey all,
    Working on another failed Lexmark LVPS power supply. The printer gradually had more and more trouble making it to the post screen until finally no power on at all. I'm replacing the two large caps, and the one small 100uf 35V cap that shows a small bulge. That is the only visible cap issue, but I hear a faint fast clicking that tells me caps are probably the issue.
    Have a look at this board and let's make predictions about what's wrong with it, I'll post my repair results and we can see what the issue was.
    Thanks!
    Re: Lexmark 654dn power supply dead fans on part # 40x4355
    Bad caps may show no sign of bulging but they can have high ESR. It sounds like you have bad startup/running caps (typical small value 47 ~ 56 uF 50V) in the HOT side, they are for filtering the Voltage for the VCC pin of the SMPS IC's.
    • Jluxster
      • Jun 2019
      • 17
      Hmmm, OK, this board has a ton of 35V and 50V caps on it. Perhaps one of them is the culprit.
        ton of Lytics cap?
        https://www.badcaps.net/forum/attach...2&d=1564777195
        I see C501, C801, but the third one I cannot see in that picture.
        • R_J
          • Jun 2012
          • 9622
          I see that one bulged cap and would bet C106 is also bad
            Good eyes!
            https://www.badcaps.net/forum/attach...0&d=1564777195
            Time to recap as a set.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8351
              replace all caps that are near a heat source. big or small, doesn't matter much.
              • Jluxster
                • Jun 2019
                • 17
                Well, last night I replaced the bulged cap and the two large caps, and the unit now functions with no problems. Startup and post.
                Good prediction in naming the small cap as the likely culprit.
                • Jluxster
                  • Jun 2019
                  • 17
                  Here are the images after repair.
                  Thanks for all the posts.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8351
                    glad to hear that you got it going again!
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                    • Andreas_de
                      Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                      by Andreas_de
                      Hello!
                      i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                      Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                      Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                      04-12-2025, 10:38 AM
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
                    • JimBanville
                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                      by JimBanville
                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                      09-13-2023, 07:21 AM
