Do switches have different output distance capabilities?
  • captainKKK
    • Sep 2018
    • 287
    I have an older 5 Port Cisco switch that works on all five ports connecting computers that are within 10 m but cannot reach a computer at 50 m, on any port. After switching to a different 5 Port switch it has no trouble reaching the 50m computer. Is this normal?
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: Do switches have different output distance capabilities?
    Assuming 10/100/1000Base, maximum "guaranteed" cable length is 100m.
    Switches go bad. As do cables. Verify your connection is actually performing in FDX, etc. before casting a verdict. E.g., swap cable is an easy test.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      I have noticed differences too, I have a link that is significantly too long at around 170m.
      With my laptops built in Intel NIC I get a solid 10Mbps connections that I can saturate.
      However with an Asus RT-N66U router I can only achieve ca 2Mbps in the same throughput test.
      I have been meaning to test some different switches on that link but have not gotten around to it yet...
      Of course it could just be bad caps too: https://www.badcaps.net/forum/showpo...38&postcount=6
      • Curious.George
        • Nov 2011
        • 2305
        • Unknown
        Are you pushing UDP packets or trying to benchmark a TCP connection?
        You can query the interface to see what sort of errors it thinks are happening.
        But, unless you have a look at the actual signal on the pairs, it's hard to know how much to blame, each device. Could even be kinked cables, etc.
        The "easy" solution is a media converter (or even throwing another switch at the midspan).
        [I convert to fiber for any longer links -- or anything between buildings, across the yard, etc.]
        • retiredcaps
          • Apr 2010
          • 9271
          What is the model number?
          Is this a Linksys switch (a division of Cisco)?
          --- begin sig file ---
          --- end sig file ---
          • Curious.George
            • Nov 2011
            • 2305
            • Unknown
            Performance issues are often a sign of misconfiguration (PEBKaC) -- duplex mismatching being one of the most common. (e.g., "auto" doesn't always mean "auto"!)
            So, swapping (active) EQUIPMENT could make the problem "go away" -- simply because the new piece of kit is serendipitously configured compatibly. OTOH, cables have no configuration information stored in them so swapping a cable will not fix a configuration problem.
            I had "issues" with some of the "green" switches when they were first introduced -- much the same as with the "5V only" RS232 transceivers. But, I think most of those problems have evolved their way into obscurity.
            • captainKKK
              • Sep 2018
              • 287
              Cisco Small Business SG110D-05
              • Agent24
                I see dead caps
                • Oct 2007
                • 5076
                • New Zealand
                Doesn't seem right to me. 50 meters should be fine unless you have some heavy interference near to that specific cable, or it's damaged.
                -David VanHorn
                  • 31255
                  check the voltdrop/resistance of the cable against known good stuff.
                  or scope it for external interference - if you see some them maybe switch to STP cable.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    According to Cisco's website, that is a 5 port unmanaged 10/100 switch.
                    https://www.cisco.com/c/en/us/produc...omparison.html
                    50 meters should be no problem for this switch. Or any ethernet switch.
                    Did this switch work before and just die now? Or did you get this used from someone in some unknown state?
                    And when you say "cannot reach a computer at 50 m", I assume you see no link light on the switch?
                    • redwire
                      • Dec 2010
                      • 3912
                      Some switches can tolerate imbalance in the Ethernet cable better than others.
                      Ethernet cables can get damaged, if the pulls were rough it stretches the cable, or stepped on flat, and ruins the twisted pairs. If the end connections are sloppy, for jacks or wallplates etc. this can also cause problems.
                      It's important to keep the twisted pairs in tact, no splices in the middle of the run etc. which can cause reflections.
                      I know IT guys that flip out if you wind up excess Ethernet cable in a loop. It would make a loop antenna adding common-mode noise, but Ethernet shouldn't mind because it can take a lot of common-mode noise assuming the pairs are intact.
                      • captainKKK
                        • Sep 2018
                        • 287
                        Ok, smoking gun found. The Cat6 was run through the attic. That wire checked 3 times good. Both end wall plate connectors checked good but replace anyway. Problem remained intermittent, random. ISP modem showed 81 faults in last 40 days, replaced. Problem remained intermittent, random. Ping logs made 24/7. Problem remained intermittent, random. One night, as I was pinging the 50 meter AP, the issue arose......at just the time I heard the A/C come on. Next day, inspection in the attic revealed the Cat6 wire ran right next to the A/C air handler and when it vibrated, the insulation was damaged and grounded by touching the air handler temporarily. Lesson learned, needles in haystacks are hard to find and expensive.
                        • Curious.George
                          • Nov 2011
                          • 2305
                          • Unknown
                          I had a PSTN cable that rested on the exhaust plenum of the furnace. Winter heating would cause the phone to periodically go dead.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Been there and will be there again in the future.
                            You do learn A LOT though in the process.
                            Good job finding the problem.
                            • flibidy
                              Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                              by flibidy
                              I have here a Magnum IA.100 which belongs to my parents.
                              The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                              Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                              What Ive done........
                              01-01-2025, 01:26 PM
                            • FrancescoV
                              Onkyo HT-R390 no sound output, video output ok
                              by FrancescoV
                              Good morning everyone,
                              I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                              The firmware reported is the following:
                              M:1.00/11107BLP
                              D:?.??/????????
                              O:1.00/11107AL
                              The DSP firmware given the question marks seems corrupt.
                              On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                              05-11-2025, 02:59 AM
                            • MrCreosote
                              2 Belkin KVM switches have dim VGA output
                              by MrCreosote
                              When compared to a direct VGA connection, these 2 switches both output a darker image. The switches are:
                              4-port Omniview Pro2 f1dz104t
                              8-port Omniview either f1da108t OR f1dz108t (look and function same, OSD may be only difference.)
                              The 4 is dimmer, the 8 is massively dimmer - both with same AC adapter and cabling.
                              AD ADAPTER:
                              There were issues with previous AC adapter, it failed during lightning strike that blew up TV and other stuff and tripped a 15 amp breaker in the main panel which also had a whole house Cutler Hammer surge...
                              08-15-2023, 08:26 PM
                              NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                              by sam_sam_sam
                              I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                              I bought this from an eBay seller but unfortunately they only had one
                              I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                              I bought three of from them to also make battery packs with this output power limit in mind
                              I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                              04-23-2025, 05:50 AM
                              Corsair CX750M [Model 75-002019] - burned output toroid inductor
                              by momaka
                              Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                              So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                              09-19-2021, 08:44 PM
