Identify solder joints Looks bad to me
  • Bishop
    • Apr 2009
    • 99
    I just took apart the window control switchpack from my 98 SUV.
    Two days ago the windows worked fine yesterday none will go down or up. Several solder joints or spots have an orange or gold corrosion on the solder.
    Is there anything I can do? Resolder?
    This unit cost $385 to replace. I'm 71 and retired and can't spend that much to roll the windows down.
    What would do?
  • petehall347
    • Jan 2015
    • 4440
    • United Kingdom
    Re: Identify solder joints Looks bad to me
    just flux .you could clean it off .
    • petehall347
      • Jan 2015
      • 4440
      • United Kingdom
      is the module getting power ?
      any chance of pics of both sides of the board ?
      • Bishop
        • Apr 2009
        • 99
        Board is clean on both sides. I tested all the switches back to the module and got a good short.
        I cleaned the circuit board this afternoon and reinstalled it, no change.
        None of the windows will roll and down the window lock is off.
        The only thing that shows sign of life on the switch pack is the power light comes on when the headlight are on, so there is power to the pack.
        I unplugged the C626 plug under the passenger seat several tims to get a good connection and pulled the carpet up on bothsides looking for a faulty Purple/blue wire but all is clean and dry. The 98 RR has been a good vehicle up to now, and for the last three years.
        When I put the RR in reverse the side mirrors drop as they use too. I did not try to adjust the mirror switch on the switch pack. They work and that's oK.
        The sunroof is dead also.
        Help
          • 31214
          if the sunroof has a seperate controller then i would say the problem is actually the main system not enabling them.
          • sofTest
            • Aug 2008
            • 361
            Just because the light comes on on the switch, doesn't mean that you got good power or ground. If you're lucky, you could have a (partially) blown fuse. It's an easy fix if you're lucky. You can have a bad connection, i.e. corrosion (the green crusty) on the hot side or the ground side. Not always easy to diagnose; the connection could be good enough for showing voltage on a multimeter or test light, but not carrying enough current to drive the motors. Any 55W halogen headlight test bulb might be helpful here.
            My advice would be to find the wiring diagrams for the car. BBB Industries might be a free site to start with:
            http://www.bbbind.com/tsb-and-wiring-diagrams-login/
            When you got a wiring diagram, you can find what the problematic circuits have in common, making it easier to narrow down the diagnostic. For instance, if they don't share ground, hot is probably the problem. Try to split up your diagnostics; ie. from connector to connector if possible.
            If you haven't diagnosed electrical problems in cars before, look up the following channels on Youtube:
            - Pine Hollow Auto Diagnostics
            - New Level Auto
            - South Main Auto Repair
            I've seen more than one video involving diagnosing window regulator problems in those channels.
            I'm not much around here any more, so I may not be doing any follow up if questions.
            RR=Range Rover?
            Be a mensch
            • jm1234
              Solder joints on heat sinks matter?
              by jm1234
              solder joints on heat sinks - how much do they matter? Could poor joints on heat sink cause issues if they are not properly joining to hot ground?
              I'm looking at power source module of Panasonic plasma TV and I see many of these having visually poor quality, but could they matter? In general I would guess no, but I saw a video where someone was stressing out the importance of tightening the screws when fastening the power source board specifically for the ground to be connected properly.
              04-28-2024, 04:38 AM
            • abajor
              x1 Carbon Gen 9 HYG60\HX4B0 NM-D341 Rev: 1.0, CSD87501L Failed solder Joints.
              by abajor
              I had a x1 Carbon Gen 9 come in with a no charge and no USB C power up problem (the machine would turn on with a new battery until it lost charge).
              I noticed lifting the protective black membrane near the USB jacks that two little BGA chips were stuck to the adhesive and had fully released from the mother board, one of them looking fully scorched. Q261 and Q263 power MOSFETS.
              I found the schematic and diagram for the board here.
              https://www.badcaps.net/forum/troubl...e-devices/sche...
              07-20-2024, 04:46 PM
            • corrize
              Best way to solder LVDS connector for beginner (and qfn) ?
              by corrize
              Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
              I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
              I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
              See the test :
              https://youtu.be/bNAzC-EvqHs?t=1767
              With hot air from bellow the board, that's...
              03-09-2023, 02:57 AM
            • petemanuk
              BGA solder balls not connecting - help pls
              by petemanuk
              So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
              I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
              I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
              11-16-2022, 05:21 AM
            • myth77
              UV solder mask - high temp resistent, recomendation?
              by myth77
              Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
              Is there any solder mask...
              03-28-2022, 04:04 AM
