ASRock > B75 Pro3-bios bin
  • Aliencomputres
    • Aug 2019
    • 220
    • România
    Hi all !
    Need ASRock > B75 Pro3-bios bin please!
    Thx in advance!
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: ASRock > B75 Pro3-bios bin
    why not directly for their website
    Im Back... sort of...
    • Aliencomputres
      • Aug 2019
      • 220
      • România
      Problem solved.
      Thx.
      • atzimpourdakas
        • Jul 2020
        • 1
        • Greece
        Need ASRock fm2a78m pro4+ bin please
          • 22216
          see the thread title - ASRock > B75 Pro3-bios bin . start your own thread .
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • pkslowk
            Debug Card Error Code and Solution
            by pkslowk
            Sr. Motherboard Debug Error Code Solution
            1 Intel 845 E9 Bios Related Problem
            2 Intel 845 D4 CPU Socket Related problem
            3 Intel 845 37 Bios Related Problem
            4 Intel 845 7C Bios Related Problem
            5 Intel 945GCPE 34 Bios Related Problem
            6 Gigabyte 845 2 Ram Related Problem
            7 IBM Server A6 A7 Ram Mismatch Problem
            8 Asus 845 29 CPU Related Problem
            9 Lenovo I946 97 C-Mos Jumper related
            10 Gigabyte 845 A0 CPU Related Problem
            11 Asrock G31M-VS D7 Bios Related Problem
            12 Compaq 845 BD-70G B0 CPU Socket Related problem...
            01-28-2021, 12:51 PM
          • Stunt
            Hp Laptop Stuck on Hp protected by hp sure start screen
            by Stunt
            Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
            I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
            I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
            Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
            screen that's it and stuck there. I left it until the following day and i still...
            09-02-2025, 01:51 PM
          • GardevoirForEver
            Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
            by GardevoirForEver
            I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
            Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
            The motherboard of my ASUS...
            11-15-2025, 04:30 PM
          • Zeonalbasta
            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
            by Zeonalbasta
            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
            09-13-2024, 01:17 PM
