Hp 250 g5 LA-D703P Schematic
    Anyone having a schematic for HP 250 G5
    Re: Hp 250 g5
    need schematics
    la-d703p
      Re: Hp 250 g5
      Hello. Has anyone yet found a schematic for this laptop motherboard BDL50 LA-D703P REV:1 as i need to find out what is the exact number for this IC 8A 3G B59 please.
      Thanks.
        Re: Hp 250 g5
        Finally I found it myself (but no the laptop diagram/schematic) and I can confirm 100% that 8A 3G B59 IC is RT8243A and any of this sub-models will work:
        RT8243AZ RT8243A RT8243AZQ 8A=EC 8A=ED 8A=EF 8A=xx RT8243AZQW QFN20
        If your chip is overheating and the 3.3V and 5V coils are not in short circuit then check the output pins 15 and 14 (LDO3/LDO5) respectively 3.3V and 5V ALWAYS ON. Most common problem will be the KB9022Q D Embedded Controller that is in short circuit due to faulty (broken plastic) DC Socket/Power Socket that short the middle info pin to the positive +19V.
        The link of the Stand-By Voltage IC RT8243A is here
        https://cdn.badcaps-static.com/pdfs/...6efd1981b0.pdf
          Re: Hp 250 g5
          Thanks for informing this Chipset to all us. All works well but the WiFi is not sensing at all. I updated the WiFi latest drives, updated the BIOS & even reloaded Windows 10 again. Still the same. I think something is wrong with the PCIe slot on the man motherboard. Does anyone know what chipset is controlling this WiFi. Anyway help would be appreciated. Thanks
            Re: Hp 250 g5
            need schematic plz
              Re: Hp 250 g5
              hello everyone, does anyone say what mosfet was there?
              I found a wire in place,
              Mb.BDL50 LA - D703P Rev;3.0
              thank you in advance
              click here
                Re: Hp 250 g5
                mb.bdl50 la - d703p rev;3.0
                aon6426
                  Re: Hp 250 g5
                  Thank you so much
                    Re: Hp 250 g5 LA-D703P Schematic
                    there are 2 bios in bdl50 la-d703p i could not f on ind the on bios can anybody please help me for the location of on bios thx
                      try this
                        on my motherboard the mosfet is a tpca 8059-h
                          Thankd-zzzzzz
                            i need a schematic for hp 250 g5 LA-D703P
