Samsung UE40D5520rkxxu lines on screen
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    Just a quick one, what would cause the lines on screen on this in the pics? T-con? Connection/cable? Or is the LCD panel shot??
    Apologies for the poor pics, its all thats available
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    Re: Samsung UE40D5520rkxxu lines on screen
    Ok, so actually now have the TV in my possession, so have more info, the pics above were how it was, I have since unplugged Tcon, cleaned connections, plugged back in, and now its worse lol.
    Here are the pics as it is now, including pics of it opened up
    • Bloopeta
      • Jun 2018
      • 526
      • United Kingdom
      Turned off, disconnected tcon again, reconnected and turned back on n now looks like this
      • Bloopeta
        • Jun 2018
        • 526
        • United Kingdom
        Constantly changes all the time, very hard to picture
        • nomoresonys
          • 12331
          • U.S.
          Need to start somewhere, maybe test the tcon, I see lots of test points.
          • Bloopeta
            • Jun 2018
            • 526
            • United Kingdom
            Where would I saart with that please?
            • nomoresonys
              • 12331
              • U.S.
              Maybe try this first: https://www.youtube.com/watch?v=GcBwTums_mI
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                Do these suffer from tab bond issues ?
                • nomoresonys
                  • 12331
                  • U.S.
                  HVIN_12V
                  VCC_3.3V
                  VCC_1.8V
                  VCC_1.2V
                  VCC_1.1V some there, I don't usually test tcons much so not sure if these voltages are standard from tv to tv or not, you could test those gamma points? but it really doesn't look like a gamma issue to me.
                  • Bloopeta
                    • Jun 2018
                    • 526
                    • United Kingdom
                    Just watched the video, disconnected 1 side at a time, heres the pics.
                    Also tried wiggling and tapping the bonded tabs, that did nothing.
                      https://www.badcaps.net/forum/attach...7&d=1574437580
                      It looks like main board issue.
                      Did you try heating/cooling the maim board yet?
                      • Bloopeta
                        • Jun 2018
                        • 526
                        • United Kingdom
                        No not yet, been focusing on Tcon, I will try that now
                        • nomoresonys
                          • 12331
                          • U.S.
                          I don't know if it's dangerous, as in might short something BUT I've seen some get a better or clear picture by adjusting one of the ribbon cables while in the diagnostic mode you are in on the picture, with tv running.
                          • Bloopeta
                            • Jun 2018
                            • 526
                            • United Kingdom
                            Tried heating then cooling board, also tried playing with ribbon cables whilst switched on picture test screen.
                            Pic 1 is how the screen looks with nainboard unplugged, pic 2 is how it now looks all connected after trying the above mentioned things
                            • nomoresonys
                              • 12331
                              • U.S.
                              So it seems to be changing somewhat, that makes me think it's the tcon.
                              • Bloopeta
                                • Jun 2018
                                • 526
                                • United Kingdom
                                It changes everytime I do something, rarely the same twice
                                • nomoresonys
                                  • 12331
                                  • U.S.
                                  Wonder if that's a match, there's a make offer option also, might want to test your tcon more: https://www.ebay.co.uk/itm/Samsung-4...YAAOSwcrdcv1Gw
                                  • Bloopeta
                                    • Jun 2018
                                    • 526
                                    • United Kingdom
                                    Theres quite a few for sale locally, but since moving the ribbons with it switched on, the picture is terrible and no longer changes, so think Tcon is goosed now, and possibly main board, so not prepared to put any money into it.
                                    • nomoresonys
                                      • 12331
                                      • U.S.
                                      Yep 6-7 years old only 40 inch. not much meat on bone for resale and hard to tell just what's wrong with it.
                                      • Bloopeta
                                        • Jun 2018
                                        • 526
                                        • United Kingdom
                                        Precisely, better using for spares
                                        • jeyoung12
                                          Samsung QN50Q60t lines on screen
                                          by jeyoung12
                                          Hi all
                                          I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                                          My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                                          This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                                          It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                                          So....i don't know what end of the C ribbon to work with...
                                          02-26-2024, 10:38 AM
                                        • Stanley1843
                                          Screen Display Vertical Multicolor Lines
                                          by Stanley1843
                                          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                                          06-29-2024, 11:54 AM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • Runlinc
                                          Samsung QE50Q60TAU - Horizontal screen lines
                                          by Runlinc
                                          Hi everyone, the tv was in a continuous reboot cycle. To get the best screen image i can I taped the VGH and VSS pins on the left side buffer board joining ribbon.
                                          I am left with a good image apart from the black horizontal lines that I cannot get rid of.
                                          I cannot find anything on the buffer boards that has shorted.
                                          Do you think there is anything i can do to eliminate the lines, or are they caused by an internal panel short and the image cannot be impoved.
                                          Many thanks for your assistance
                                          05-14-2024, 07:40 AM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
