Dell F177FPE monitor, won't power on
  • bfordz
    • Aug 2011
    • 81
    I've got a Dell F177FPE that went dead, it won't power on.
    There's no power "on" light or anything.
    I took it apart and the caps all 'look' good but they're all cheap Su'scon's or Teapo's.
    While doing some basic tests of the board I found a Ceramic capacitor that shows open with the ohm meter, so I'm hoping that's the cause of my no power up problems. I included pics of the failed cap and it's location on the board.
    My question / problem is I've never replaced or dealt with these type of capacitors so I want to know if I'm reading it correctly and my choice of replacement is correct. (based on what I've read)
    The original is a JNC JN332M 250v and I'm not sure what the 440 x1 and 250 x2 means.
    I've picked out a Murata Electronics DE1E3KX332MA4BN01F replacement.
    I'm also going to replace all the Alum Elect Caps while I'm in there.
    If there is anything else you notice, I'm open to suggestions.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Dell F177FPE monitor, won't power on
    That is a snubber cap is supposed to read open. If it would have failed, you would see it. Since you don’t even have a stby led, probably the stby power rail that is always on is not working, or there is no AC going to the bridge rectifier. So check if you have about 170VDC on that main filter cap. Also the PFC needs to work (roughly 380VDC on the main filter cap) in order for the backlights to work.
    • bfordz
      • Aug 2011
      • 81
      Well, that shows how much I know! Very little when it comes down to the real nitty gritty.
      Most of my boards have all shown the issues, when it comes down to the actual 'what needs to be tested and the results' is where I get a bit lost.
      When you say 'main filter cap' which one are you referring to?
      • R_J
        • Jun 2012
        • 9633
        Why don't you start by checking if the fuse is good or if you have any voltage across the main filter C854 (the blue 100µf/450v) capacitor. If you have 160vdc across the main filter, check the resistance of R852, it should be 0.2Ω
        That cap you have circled has nothing to do with the operation of the power supply, it is a safety cap that connects the hot and cold grounds.
        • bfordz
          • Aug 2011
          • 81
          The fuse is good and the R852 is 0.2ohms. I'll check voltage now.
          • bfordz
            • Aug 2011
            • 81
            Main filter - 171.2vdc
            R852 - 0.4ohms
            • R_J
              • Jun 2012
              • 9633
              D854 is the secondary dual diode, check the voltage across C862
              If you have your +12 volts then the primary circuit is working, Check the voltage on U801 and U802, I don't know what there voltage should be, you may need to post the part numbers, I suspect one should output either +5v or +3.3v
              Near the LVDS cable is a fet Q501, check if there is voltage on S and D, You also check the voltage on the Gate and see if changes when the power button is pressed.
              You can also follow the wire from the power switch and see if there is any voltage on it and does it change when the button is pushed? If the microprocessor and eeprom U402 are getting VCC voltage you may have a corrupt eeprom causing the monitor to not turn on.
              • bfordz
                • Aug 2011
                • 81
                12.07vdc
                • bfordz
                  • Aug 2011
                  • 81
                  U802
                  1 - 0.0v
                  2 - .433v
                  3 - 1.25v
                  4 - .433
                  U801 (no numbers but using same as 802)
                  1 - 0.0v
                  2 - not connected
                  3 - 5.20v
                  4 - 1.25v
                  that's checking voltage at each terminal not across terminals.
                  • R_J
                    • Jun 2012
                    • 9633
                    You can use some alcohol to clean the top of the ic so you can readthe numbers, or try looking at an angle, you may be able to read them, but the voltages don't look good.
                    The microprocessor operates from 3.3 volts, one of those regulators should be a 3.3 volt regulator
                    Without the regulator ic numbers it is hard to tell what the input and ouput voltages should be. I can see numbers on the ic's in your picture, what are the numbers?
                    • bfordz
                      • Aug 2011
                      • 81
                      here's a diagram
                      • bfordz
                        • Aug 2011
                        • 81
                        U801
                        a1
                        asiii7r-33
                        bo635 26
                        u802
                        ac 6i8l
                        17-18l
                        • R_J
                          • Jun 2012
                          • 9633
                          Those numbers can't be correct, Could it be a AS1117-33 If it is, it will be a 3.3 volt regulator
                          IC801 has +5volts on its input and only 1.25v on its output (it should be 3.3v) so something is loading it down
                          Also are you sure your model number is correct? I can't find it listed anywhere
                          • bfordz
                            • Aug 2011
                            • 81
                            It is AS1117-33 can't tell if they're 1's or I's.
                            • bfordz
                              • Aug 2011
                              • 81
                              Long week...E177FPf (sorry)
                              • R_J
                                • Jun 2012
                                • 9633
                                It looks like U851 is a 5 volt buck regulator, pin 1 is the input (12v), pin 2 is the output (5v), It feeds U801 3.3 volt regulator, pin 3 is the input (5v) pin 2 is the output which is low.
                                I suspect U802 is a 1.8volt regulator so something could be shorted on its output which is also loading down its input.
                                I suspect the number could be ams1117-18
                                • CapLeaker
                                  Leaking Member
                                  • Dec 2014
                                  • 8352
                                  ah, so there is power to the main filter...
                                  Looks like that U801 is feeding U802 power. So U801 must be bad or getting loaded down.
                                  • bfordz
                                    • Aug 2011
                                    • 81
                                    I included a better pic of U801 for reference.
                                    For U851 here are the actual v readings:
                                    1 - 12.0vdc
                                    2 - 5.2vdc
                                    3 - 0.0vdc
                                    4 - 1.25vdc
                                    5 - 0.0vdc
                                    sorry for the delay, I was away from my computer this weekend.
                                    • bfordz
                                      • Aug 2011
                                      • 81
                                      RJ, thank you for your help and input. Also, the regulator lessons and how they function.
                                      It also encouraged me to look a little further to learn some more besides just replacing "caps".
                                      Capleaker, thank you for the 'snubber cap' information, I would have replaced it but then that's why I inquired here first. I actually 'thought' I had something when it tested open. Live and learn!
                                      • CapLeaker
                                        Leaking Member
                                        • Dec 2014
                                        • 8352
                                        I’d replace that 3.3v regulator and see what happens.
                                        • keepread
                                          Dell monitor PSU vs Dell laptop PSU
                                          by keepread
                                          Hi there!
                                          Someone gave me their old monitor, it's Dell S2715ht.
                                          The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                          Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                          10-30-2025, 04:45 PM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • Borse2008
                                          Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                          by Borse2008
                                          Hi everyone,
                                          Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                          I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                          • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                          • There’s
                                          07-15-2025, 04:55 AM
                                        • Mark01
                                          Dell Optiplex 7490 AIO - red power led after flash
                                          by Mark01
                                          Hi guys,
                                          This is my first post! 🚀
                                          I have no idea what I’m doing, but I’m learning by trial and error.
                                          I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                                          07-04-2025, 12:54 PM
