Improving CRT geometry by upgrading capacitors
  • Hitto
    • Apr 2019
    • 95
    • Italy
    I'm trying to improve the geometry of a CRT monitor by upgrading capacitors.
    Compared to the original ones, I've upgraded by 15-20% the capacitance of each capacitor around the flyback trafo and used components with higher current capabilities.
    Howewer, the scan capacitor (the big 3.3uF bipolar capacitor in the horizontal section) is what is giving me trouble.
    Do you guys know if going higher with the capacitance will make possible to obtain a better geometry or will it only affect the horizontal width of the picture?
    Is a polyester capacitor limited in current capabilities, giving that this capacitor will have to handle more than 8A of current? A parallel will be very hard to perform since the space is restricted by nearby components and polyester capacitors already have quite large lead spacing.
    I've seen CRTs using 3.3uF, 4.7uF and even 10uF. This CRT has a 3.3uF capacitor and I'm currently thinking of using a 6.8uF capacitor.
    Once the board will be assembled it will be quite troublesome to resolder a new one due to lack of space, so I would like to know more informations about the choice of this (critical) component.
    • 31131
    Re: Improving CRT geometry by upgrading capacitors
    that cap is selected for a reason,
    the only caps worth upgrading are the smoothing caps on the outputs of the transformer.
    even then, most people wont need it - a full white screen can sometimes shrink the image because it draws more current - but a white field is unusual except in some games.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      This web page is pretty much a full white screen?
      • R_J
        • Jun 2012
        • 9578
        If you change this capacitor value the horizontal linearity will be effected and the geometry will look like shit. Like it was stated, the values are picked for a reason.
        • Hitto
          • Apr 2019
          • 95
          • Italy
          Thank you all.
          Do you think a polyester capacitor, let's say a 3.3uF 100V one, is alone able to withstand 8-9A of current?
          That is true. It also caused whining on that CRT. Would this effect be toned down by upgrading of capacitor filters on 160V line? The board has by default design 22, 33 and 10uF of decoupling near the pins of the trafo.
          I assume that the 160V line is quite crude in terms of ripple.
            • 31131
            if B+ is 160v which sounds high, you can use a 100v polyester - a 250v would be o.k.
            • Hitto
              • Apr 2019
              • 95
              • Italy
              I meant the scan capacitor, which will have to sustain 8-10A of current. Is a standard MKP capacitor able to sustain that much current or do you think that a parallel (2.2+1uF or 2.2uF+2.2uF) will be necessary?
                • 31131
                pulse current.
                some polyesters and polypropylene caps wont be happy so read the datasheets.
                • Hitto
                  • Apr 2019
                  • 95
                  • Italy
                  Thank you.
                  Found some capacitors which should be able to sustain the required current, which will be not less than 8A. They are the B32774P TDK film capacitors.
                  In case anyone will find it useful, these are the full specifications:
                  https://cdn.badcaps-static.com/pdfs/...61730aa80a.pdf
                  The 6,8uF 630V capacitor is able to sustain 10.4A of current while the the 3,0uF 630V capacitor is able to sustain 6.0A. I'm going to try the 6,8uF 630V and see if this difference (3,3uF>6,8uF) is going to alter the geometry or not (I guess yes, but the 3,0uF 630V may be not enough to carry the required current and, if I'm not mistaken, that scan capacitor is a critic component that cannot fail for the sake of nearby components).
                  Another serie with high ripple capability is the MKP1848H manufactured by Vishay.
                  • Hitto
                    • Apr 2019
                    • 95
                    • Italy
                    Other informations found while searching that I wanted to share.
                    In case you want an exact-fit replacement the electrolytic capacitor is the Nichicon UHA1H3R3KHD (3,3uF 50VDC rated at 6A).
                    The most capable component in this path, if we do not want to use a film capacitor, seems to be the UHA1H4R7KHD (10uF 50VDC rated at 10A).
                    I am going to test, in the following order:
                    6,8uF 630V (MKP)
                    10uF 50V (Electrolytic)
                    3,3uF 50V (Electrolytic)
                    Other stuff:
                    https://cdn.badcaps-static.com/pdfs/...96564c4d75.pdf
                      • 31131
                      you may want to think about how low the current handling of the old electrolytics was.
                      use the 3uf
                      • Hitto
                        • Apr 2019
                        • 95
                        • Italy
                        I've used a 3.3uF/50V electrolytic capacitor (made for horizontal deflection) and paralleled it with a small 0.1uF/50V MKP/Film capacitor (it should help with very high frequencies which the electrolytic is fisically unable to smooth).
                        It works okay.
                        Do you guys think that any MKP capacitor will be good, considering that it will only filter a small percentage of the total current, or should I replace it with something beefer?
                        I ask this because a lot of datasheets warn about using Film/MKP/MKT capacitors "with other types of waveforms".. and horizontal deflection on CRTs is a sawtooth.
                        Should I derate the MKP/Film capacitor in order to avoid problems?
                        • Hitto
                          • Apr 2019
                          • 95
                          • Italy
                          I've used a 0.1uF/250V MKP capacitor and called it a day.
                          • Hitto
                            • Apr 2019
                            • 95
                            • Italy
                            Other useful informations for the members of the forum and whoever arrives here with the same question:
                            1) Higher capacitance made no differences to geometry. Tried 6.8uF, 10uF, 12uF, 22uF, 22uF+12uF with zero changes to geometry. No overheating of the transistor by using higher capacitance but I cannot say if it causes problems on the long run. Not advised going higher than 15uF has I've seen monitors with such capacitance but never more.
                            2) Any electro capacitor, even a beefy crossover capacitor rated at 100V and able to sutain 900mA of alternate current, which is quite high, failed in a matter of minutes. The test was made while keeping a 3.3uF MKT capacitor in circuit to prevent failures of the horizontal transistor so we can assume that the electro capacitor was even not sustaing the whole current (!).
                            3) Installing 6.8uF capacitor (MKP/MKT) made the monitor more silent at 100Hz. Same obviously happened with higher capacitances.
                            4) If the original capacitor in this area measure much more than its rating (when I opened the monitor for the first time checking for faults the capacitor was a 3.3uF measuring 3.8uF with other parameters perfect but the screen was somewhat noisy) then you have to replace it. Producers back in the day used very cheap capacitors despite knowing that this component is vital for the working of the entire monitor.
                            Even if the replacement is a MKP capacitor, use at least two identical capacitors in parallel. Better if you use three in case of cheap/no-name MKP capacitors.
                            • Hitto
                              • Apr 2019
                              • 95
                              • Italy
                              Other informations for the readers and the members of the forum.
                              Found a very old CRT monitor which effectively uses MKP capacitors for this exact section. It parallels four MKPs: 820nF+820nF+1uF+1uF. They are 250V parts despite the voltage being no more than 60V (quickly measured with a cheap multi-meter in DC).
                              • R_J
                                • Jun 2012
                                • 9578
                                You are forgetting about the high frequency pulse that is on that cap, I suspect it is greater than 60v peak
                                • Hitto
                                  • Apr 2019
                                  • 95
                                  • Italy
                                  I suspect it as well. My multi-meter is quite cheap though so I take its reading with a grain of salt and derate. Not that I would not derate nevertheless when it comes to delicate circuitry with almost-irreplaceable transistors.
                                  • R_J
                                    • Jun 2012
                                    • 9578
                                    The B+ that supplies the horizontal output transistor is usually around 130vdc, but the transistor is usually rated for 1500v or more and disc capacitors in the horizontal circuit can be rated 2~3KV it has is due to the high frequency ac peak voltage not the dc voltage.
                                    • clearchris
                                      • Dec 2013
                                      • 687
                                      So what's the use case for keeping a CRT running? I'm sure anyone who hangs here can find a broken LCD and make it work.
                                      Are you running old school nintendo and want to play "duck hunt" with the orignal zapper?
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        It runs... save the environment: use till it breaks, then fix it, and use it some more until the cathode is contaminated and the heater burns out...
                                        • chth96
                                          If I replace with inferior capacitor, Is it No harm to other IC components at all?
                                          by chth96
                                          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                                          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                                          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                                          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                                          I know that these capacitor will not last as long as nichicon capacitor...
                                          12-22-2023, 04:34 AM
                                        • chth96
                                          How can I test non-polarized capacitor?
                                          by chth96
                                          I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                                          I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                                          And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                                          I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                                          06-02-2024, 07:31 PM
                                        • dragon3x
                                          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                          by dragon3x
                                          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                          power on.
                                          Here are some examples :
                                          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                          switching supply area).
                                          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                          than 6.3 V.)
                                          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                          I replaced capacitors with aluminum-polymer.
                                          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                          03-21-2025, 02:46 PM
                                        • chth96
                                          Is it no harm to replace with capacitor without ripple current rating?
                                          by chth96
                                          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                          Rubycon YK DataSheet (b...
                                          04-19-2024, 05:19 AM
                                        • chth96
                                          Should I replace polymer capacitor?
                                          by chth96
                                          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                                          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                                          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                                          Is this ESR value of polymer capacitor correct?...
                                          11-18-2022, 04:22 AM
