Macbook 2018 above firmware password
  • Siddig
    • Jun 2017
    • 264
    • Sudan
    what kind of security for Macbook 2018 above.
    its not EFI type !!!!
    I have try with hex edit but I didn't find it $SVS .
    how I can clear password from dump.
    and
    tell me whats good connector for it.
    need help
    clean dump attach
  • KvnTM
    • May 2018
    • 434
    Re: Macbook 2018 above firmware password
    You may take a look at this:
    About Activation Lock on your Mac
    • ibo
      • Oct 2019
      • 107
      • Turkiye
      is this your serial number C02XM3HSJHC9
      • Siddig
        • Jun 2017
        • 264
        • Sudan
        Pro this dump for example.
        I want know how to remove frimware from bios dump or T2 chip.
        • KvnTM
          • May 2018
          • 434
          Does it have EFI Password or Activation Lock?
          Activation Lock is the same as iCloud Lock on iPhones. Not sure if you could get around that.
          • Siddig
            • Jun 2017
            • 264
            • Sudan
            I get it that. It's been like iphone activate on line.
            But
            I am ask about soultion
            • ibo
              • Oct 2019
              • 107
              • Turkiye
              there is no solution yet what i know, only SCBO file from apple
              • azanwaqas771
                • Feb 2019
                • 50
                • Pakistan
                how to read t2 chip
                • lobz
                  • Jul 2020
                  • 3
                  • Andorra
                  macOS Catalina allows you to block the firmware from showing the seed that Apple needs in order to remove the password. Type this in Terminal: sudo firmwarepasswd -disable-reset-capability.
                  • MughalG
                    • Aug 2012
                    • 9
                    • Pakistan
                    and
                    need help
                    clean dump attach
                    $SVS will not work for T2
                    • 5chematic
                      • Jun 2019
                      • 77
                      Hey Siddig, can I ask where or how you managed to find the uson chip on your model? I cannot find it any where on my board. it supposed to be a 4mb chip. my board is: A2141 820-01700-A
                      • 5chematic
                        • Jun 2019
                        • 77
                        Hey Siddig, BTW, do not try unlocking it via the image. I unlocked mine using another mac. just link them both and then you can unlock them. now the reason I want to dump the image is because I want to modify it.
                        • RethoricalCheese
                          • Mar 2013
                          • 1519
                          • Estonia
                          Could you tell a bit more about that?
                          • Marc97
                            • Jan 2016
                            • 189
                            • Phillipines
                            and
                            need help
                            clean dump attach
                            . Do you have pict where efi IC was located
                            • piernov
                              • Jan 2016
                              • 4439
                              • France
                              EFI is stored on the encrypted NAND chips and fed to the PCH by the T2.
                              • Nico Latour
                                Banned
                                • Sep 2019
                                • 52
                                • france
                                wrong wrong wrong! the 4mb bin its only thing you can do is change serial no unlock!
                                4mb bin you can read and manage with neo, if you have a good macbook and copy efi free bin to the same locked macbook dont work, also read locked mac and after unlock read again and compare and change is not working! activation lock is not only linked in serial!
                                ps the chip is a wson 2x3 1,8 volt
                                • imranromi
                                  • Jan 2015
                                  • 1290
                                  • Pakistan
                                  What about Mdm after change Serial number?
                                  • fatguy1121
                                    • Jan 2021
                                    • 3
                                    Have you guys considered hijacking the iCloud dns and pointing it to a local server that is emulating the correct response to report that it is not locked just long enough to unlock it to disable secure boot?
                                    • levi12345
                                      • Mar 2021
                                      • 4
                                      • city
                                      Hi I need your help.Anyone of you have the original 4mb .bin file for a2141 820-01700 without serial number which you can read and manage ?
                                      • Stephen
                                        Meow Meow MEOW!
                                        • Apr 2020
                                        • 674
                                        How does one go about this? I have a 16” in inventory and it be a blessing to learn how to do this!
                                        sigpic
                                        MEOWING IN THE IMPOSSIBLE UNIVERSE!
                                        • mferna14
                                          Password removal on MacBook Pro A2159
                                          by mferna14
                                          Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
                                          05-13-2025, 04:16 PM
                                        • ritalo
                                          MacBook Air 13 2014 - Remove EFI password
                                          by ritalo
                                          I have a MacBook Air 13 inches 2014.
                                          I have set a EFI password and I can't remember it : now I want to reinstall macOS and I can't because the MacBook is asking for the password.
                                          I know how to remove the password with a usb programmer.
                                          I plug the usb programmer to the motherboard and to my pc with usb, I read the EFI and I save it to a file.
                                          Then I have to find this value in the file : $SVS because it indicate where is the password.
                                          But I can't find the value.
                                          I have attached the file​
                                          Thank...
                                          05-14-2024, 12:10 PM
                                        • cyber16
                                          late 2013 13" Macbook pro firmware password HELP
                                          by cyber16
                                          I have done many of these over several years, But its been some time since the last time.
                                          Normally I dump the rom 3-5 times and compare before anything else
                                          Which I do have clean dumps, then I would search for $SVS and ff ff out every thing that follows that including the $SVS all the way down to the next large series of ff ff
                                          Upon 1st boot I will zap pram a few times, Password IS GONE
                                          yet the laptop is acting strange, powers off all of a sudden for no apparent reason.
                                          Besides that, the trackpad clicker does not work in internet recovery and other odd...
                                          01-31-2023, 07:14 PM
                                        • envym
                                          MacBook Pro 2018 with Activation Lock
                                          by envym
                                          Hi everyone!
                                          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                          06-27-2025, 08:54 AM
                                        • robka
                                          MacBook Pro 2018 - A1990 Dead - not charging - only 5V
                                          by robka
                                          my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
                                          I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
                                          The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
                                          After that the Macbook was dead. It isn't charging anymore.
                                          The USB-C Port where the charger was plugged is burned. Also The Cable and the...
                                          03-02-2024, 02:58 PM
