Intel DH61Cr
  • Aliencomputres
    • Aug 2019
    • 210
    • România
    Intel DH61Cr
    DH61CR, after bios update, fails to boot.
    Need BIOS version 48.please.
    Intel dont offer support for this mainboard.
    Thx in advance!
  • Aliencomputres
    • Aug 2019
    • 210
    • România
    Re: Intel DH61Cr
    nobody?
      • 21403
      Re: Intel DH61Cr
      Just google Intel DH61Cr recovery ,you`ll find lots of posts about the issue.
      • Aliencomputres
        • Aug 2019
        • 210
        • România
        Re: Intel DH61Cr
        Problem solved.
        Here's some additional guidance that will (hopefully) help:
        Use a USB 2.0 flash disk; not a USB 3.0 flash disk.
        On a separate, Windows-based (not Linux- or MacOS-based) PC, reformat the USB flash disk, using the FAT32 file system, with the Quick Format option disabled. If the FAT32 option is not available. use a smaller USB flash disk.
        Copy the BIOS file (BE0099.BIO) into the root folder of the USB flash disk. Do not place any other content on this USB flash disk.
        Properly eject the USB flash disk using the right-click Eject option in Windows Explorer or the Safely Remove Hardware and Eject Media applet in the System Tray. Do not just yank out the USB flash disk.
        Power off your DH61CR-based system and disconnect from A/C power.
        Remove (yellow/orange) BIOS Configuration jumper from board.
        Remove CR2032 battery from board.
        Wait 10 minutes.
        Install battery back onto board.
        Plug the USB flash disk into a (black) USB 2.0 port on the rear panel of the board. Do not use (blue or yellow) USB 3.0 ports and do not use front panel USB ports.
        Restore A/C power.
        Power on system.
        If you do not see the BIOS Recovery progress screens appear on your monitor, wait at least 10 minutes before powering back off.
        • Aliencomputres
          • Aug 2019
          • 210
          • România
          Re: Intel DH61Cr
          Originally posted by Aliencomputres
          Problem solved.
          Wait 10 minutes.
          Restore A/C power.
          Power on system.
          STONE-Intel DH61CR recovery
