Wireless Headphones with Hum sound?
  • ivtec
    • Dec 2008
    • 1967
    Hi guys i bought this wireless head phones,it works ok with batteries but it also has a input for 4.5 v dc power supply but it did not come with it,i have a few dc power supply i connect any of them and sound coming from the TV has a background ground hum ,is there anything i can do to over come this annoying hum riding with sound,it also has a few radio FM channels that don't do that only with audio source? also with batteries only in the
    set doesn't do it,but it eats batteries real fast , thanks in advance and have a marry Christmas
    https://www.walmart.com/ip/Professio...phone/39461871
    Re: Wireless Headphones with Hum sound?
    Are you using 4.5V regulated power supply?
    Does it use three 1.5V batteries?
    • R_J
      • Jun 2012
      • 9628
      Not knowing what type of power supply you tried makes it hard to tell whats wrong, Was it one of those adaptors with the voltage switch? what was the current rating of the adaptors you tried?
      Link points to the PYLE model: PHPW5
      I believe the fm radio receiver is in the headset and not in the base. You could also dissconnect the tv input to the base and see if the hum is still there, if the humis still there but not there while on batteries, the hum must be from the adaptor
      • ivtec
        • Dec 2008
        • 1967
        Thanks guys; the set uses 2 1,5 volts small batteries and it has power supply input of 4.5 vdc, i tried a few of good dc power supplies, and one of them is a great power supply that has 1.5 to 12v dc with switch that i've got when Radio Shack was still opened and it's the best power regulated supply that i ever have, i suspect that i used a different power outlet of the TV, maybe that's the issue ,i'll check after christmas, i have it wrapped up to give wife for Christmas,
        • ivtec
          • Dec 2008
          • 1967
          Hi guys i open gift box again to try to connect it same outlet of the TV and it make no difference no matter what regulated power supply or search protector power outlet i use it's same annoying hum ridding with tv sound,i found out the thing doesn't have to be connected to the audio output source to do the hum,any more ideas before i try to return it,which probably they wont refund me,the wallmart site is just like amazon where these people sell this junk,i should used Amazon cause i always had good luck with returns and refunds.
          • R_J
            • Jun 2012
            • 9628
            Those cheap supplies usually use a small transformer, bridge and output cap, so the ripple willbe 60 or 120 hz. Try and use a smps adaptor, If it can handle 4.5vdc, I would think a 5vdc one would also work which are quite common these days.
            • ivtec
              • Dec 2008
              • 1967
              Thanks R_J ,i tried a few of great power supp and no avail,here 2 good ones https://www.google.com/search?q=supp...kmOl3hM:&vet=1
              • ivtec
                • Dec 2008
                • 1967
                Originally posted by ivtec
                Thanks R_J ,i tried a few of great power supp and no avail,here a 2 of many i tried https://www.google.com/search?q=supp...kmOl3hM:&vet=1
                https://www.google.com/search?q=ac+a...HJ7dKVTrOwHuM:
                • madan1
                  • Nov 2016
                  • 726
                  • Bulgaria
                  Sorry, I'm lil bit confused.
                  Could you explain again your setup?
                  So you have wireless headphones and base.
                  Where do you connect the power supply - to the base or the headphones?
                  You said it can run on batteries.. is this the headphones, the base or both?
                  If "it" runs or batteries is there any hum?
                  • ivtec
                    • Dec 2008
                    • 1967
                    Thanks madan1,appreciate your input and help; the wireless set is this;https://www.walmart.com/ip/Pyle-Pro-...ll&athena=true
                    and it runs both the Base and headset on 2-3v AAA batteries and with those batteries on the base and on headset it sounds good no hum,but it also has on the base a input for 4.5v dc power supply and it's with this power supply it does the hum on input on any source like TV sound,they did not supply the regulated power supply ,i have many great regulated power supply's, i have to use a external power supply cause the base just eats butteries like hell, i already complained to the dealer and requested a return and refund, i already received reply from them and they say they are going to refund me and i don't even need to return the headphones ,they said i can keep it or donate it,that's great news,i'm good with repair electronics ,if i can fix this hum that will be great,that's why i ask you experts if you have an easy fix ,i know i can do it,now since i don't have to return it maybe i can open it and put a filter cap somewhere in the circuit, or maybe the issue is because this set has also microphone and that might be the cause? maybe i can get now wireless Bluetooth headphones?,what you think about those;thanks and you all have a Merry Christmas
                      I wonder if it is ground loop problem. Do you hear the hum if the base audio input is not connected the TV audio line out?
                      • petehall347
                        • Jan 2015
                        • 4451
                        • United Kingdom
                        you could try plugging the power supply into a different outlet .plus you could also try an isolation transformer on the signal inputs
                        • ivtec
                          • Dec 2008
                          • 1967
                          Thanks guys;budem i can hear the hum when it's not connected to the tv output also ,
                          petehall347; how i build an isolation transformer circuit?
                          • madan1
                            • Nov 2016
                            • 726
                            • Bulgaria
                            Try connecting it to a phone or mp3 player... anything that runs on batteries and has no connection to the mains... or you can just connect the left and right channel inputs to the unit's ground.
                            • petehall347
                              • Jan 2015
                              • 4451
                              • United Kingdom
                              i have a ready made one with rca connectors .like this
                                Then it is not ground loop or isolation problem since it still hums as stand alone.
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  if you can open up the base station and look at how the microphone circuit has been implemented, you might consider trying to disconnect it or at least part of it to see if it has any impact... might be an issue of "ground isolation" to the microphone such that noise coming thru the adapter's "negative" is providing a "hum cycle" in the microphone's preamp stage.
                                  It appears from the manual that the microphone circuit is always on (ie. it can't be "not selected").
                                  • ivtec
                                    • Dec 2008
                                    • 1967
                                    thanks budwichh ;i'll give it a try after christmas,there is also some options on line to build an isolation audio transformer ,if i find any audio transformers similar to these in my scrap; i just don't want to spend any money on this; https://www.youtube.com/watch?v=6Gc8nZG_-F8https://www.aliexpress.com/item/32814995677.html
                                    • ivtec
                                      • Dec 2008
                                      • 1967
                                      hi guys , new update on this hum issue ,i had an old PC power supply in my scrap and connected it to the 5 v dc line and much better,not perfect but it's usable , but it's kinda expensive on electricity to have a PC power supply for this,but if i have no alternative will use it and turn it off when it's not in use ,have an happy Christmas
                                      Quote
                                      • R_J
                                        • Jun 2012
                                        • 9628
                                        You can find 5v adaptors all over the place, many cheap routers etc. use them, you could also make a usb to 5v cable and use that if the tv has a usb port.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                          RCA WHP141 wireless headphones wired up
                                          by momaka
                                          OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
                                          Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
                                          As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
                                          02-22-2023, 06:28 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • carrzkiss
                                          Cyberpower cps1500avr not charging batteries
                                          by carrzkiss
                                          Hello, all.
                                          Cyberpower Battery Backup Unit.
                                          I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                          When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                          In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                          Checking the voltage, it was down to 22v.
                                          I quickly removed everything...
                                          06-15-2024, 02:10 PM
                                        • Akuanka
                                          Sony SLV-E780 Power Supply Issue – Clicking Sound, Need Help Identifying Faulty Component
                                          by Akuanka
                                          Hi everyone,
                                          I'm troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn't power up completely. I've already replaced five capacitors, but the problem persists.
                                          Here's a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78​ showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
                                          Thanks in advance for your help!
                                          11-23-2024, 01:12 PM
