P8H61 Plus died - any suggestions?
  • Jooo
    • Oct 2011
    • 222
    • Finland
    Hello, I just got this motherboard used.
    It worked fine for the first few boots, got to BIOS etc. However, first time first time I tried to boot it to OS - Linux live CD in this case - I got to the desktop, but the mouse or keyboard was not functioning.
    The system was not frozen though, the clock did run. But pressing any button on the keyboard only made the num lock light flash, and nothing else.
    So, I figure it's a compatibility issue or something, and I shut the system down with the power button.
    And that's it. The motherboard is now completely dead.
    Fans spin, but that's it, there's no post, not even any beeps. Even if I take the RAM out completely, still no beeps.
    CPU warms up slightly, but not like it's hot to touch. I have tested all the other parts and they still work.
    Any ideas what happened? Was the num lock flashing a symptom of something?
    I don't really have any experience repairing motherboards, other than replacing caps, so I would appreciate any tips to help me get started repairing this motherboard.
  • Aliencomputres
    • Aug 2019
    • 220
    • România
    Re: P8H61 Plus died - any suggestions?
    Hi.
    Try to reflash bios chip first.
    • Jooo
      • Oct 2011
      • 222
      • Finland
      Originally posted by Aliencomputres
      Hi.
      Alright, I have ordered a USB programmer. Anything I should check while waiting for that to arrive?
      • Aliencomputres
        • Aug 2019
        • 220
        • România
        Check about short circuit before 12v and gnd in cpu power plug.
        • retrorepair2
          HP Z820 Workstation 4 beeps (sometimes)
          by retrorepair2
          I've got an issue with my Z820 that I'm having trouble working out the root cause of.
          More often than not it'll turn onand fans will blast for a moment before stopping and I'll get 4 beeps that will repeat forever (at least the power light will keep flashing).
          What I can't understand is sometimes it'll just work and I can use it all day but other times it'll boot then reboot then reboot and 4 beeps for the rest of the day. Sometimes it'll work fine from cold for hours, sometimes it'll do the 4 beeps from cold.
          Another oddity is the fans. Before the 4 beeps...
          09-24-2025, 08:05 AM
        • ktmmotocross
          Old hp compaq nc6320 weird beeps after low bios battery
          by ktmmotocross
          Hello.
          Have this old hp compaq nc6320 that came with one long and one short beep + backlight on. bios battery have only 0.5V. I remove it, but now it start beep some weird way. I think it is bios /one long + two short beeps+ baklight on/, but when i flash new bios from hp, no beeps and no backlight.
          i attach record of beeps...
          04-27-2025, 12:48 AM
        • KappaDev
          HP ENVY x360 15m-dr0011dx 8 Beeps
          by KappaDev
          I have an HP Envy x360 15m-dr laptop which sometimes beeps 8 times on startup and sometimes gets no beeps at all (both with no picture).
          Power button light comes on, fans spin and stop after a few seconds, then screen stays black with no picture. If the machine decides to beep 8 times, it shuts off immediately after. According to what I could find, 8 beeps was corrupted BIOS.
          Made backup of original BIOS (attached). Attempted to flash BIOS with extracted bin file from HP BIOS update. Screen showed "Updating boot block", rebooted and immediately back to 8 beeps and...
          01-09-2023, 11:18 AM
        • CG2
          Meaco Arete One / Deye Dehumidifier not working
          by CG2
          I've got a dehumidifier that has stopped working. Plug it in, press the power switch, and it beeps 5 times. Nothing showing in the display (which is just two 7 segment displays) apart from the two decimal points flashing. The model is a MeacoDry Arete One 18L, which seems to be a rebadged Deye (all the boards are marked Deye). Here's what I've got so far (details in case anyone else in future should need them).
          Starting with the power board. Mains power comes in at the red connector top left. The compressor is powered by the orange connector to the right of that and is switched by...
          08-17-2024, 07:47 AM
        • tahirkhan1983
          Hp prodesk 400 g5 3 long beeps and 2 short beeps
          by tahirkhan1983
          My Hp prodest 400 g5 having no display with or without ram 3 long beeps and 2 short beeps. many bios tried but the problem is same. please help thanks in advance.
          07-26-2023, 06:43 AM
