Old programmer
  • Mbw1a
    • Nov 2018
    • 29
    • Europa
    Old programmer
    Hello does any one know what this programmer is for?
    • 21700
    Re: Old programmer
    Some info after a bit of googling
    http://www.retrotechnology.com/herbs_stuff/testeq.html
    "I have a InLab Inc. model 28A Universal Progammer. It's a PROM and PAL programmer from about 1989. I got manuals and software, but no power supply for it. The power supply is a wall-wart of some sort with a DB-9 female connector to the programmer. Anyone who needs, or has, information on this MOdel 28 or 28A programmer - please contact me! "
    EDIT: https://avaluer.com/to/7186839-inlab...e__manuel.html
      • 31219
      Re: Old programmer
      try here - this guy has a lot of programmer info
      http://matthieu.benoit.free.fr/tech.htm
      • Mbw1a
        • Nov 2018
        • 29
        • Europa
        Re: Old programmer
        Okey thanks for the info. 😊
        okay can you do something else fun with it? for example programming pic? or is it just junk?
          • 31219
          Re: Old programmer
          it's not junk,
          old programmers can read and write stuff the modern ones cant - people doing retro-repair use these type of things.
          i use 2 old programmers myself - the modern usb junk wont read pal's or old microcontrollers!
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Re: Old programmer
            Yep, as stj says, I sure could have used one a year ago right before Christmas.
            In the end I had to wire up a crazy contraption on a breadboard that got me through it.
            I actually found a picture of it and attached it here for your amusement.
            More details in this eevblog thread, might give you an idea what it is useful for...
            https://www.eevblog.com/forum/microc...00/#msg2113300
            • R_J
              • Jun 2012
              • 9594
              Re: Old programmer
              I still have my Needhams, PB-10 with microprocessor adaptor, I keep a pc with isa bus just for that programmer, and I used it last year.
              • Mbw1a
                • Nov 2018
                • 29
                • Europa
                Re: Old programmer
                thanks for all the info. Iwill try to sell it, if that doesn't work. I'll save it😊
                • Curious.George
                  • Nov 2011
                  • 2305
                  • Unknown
                  Re: Old programmer
                  Originally posted by stj
                  it's not junk,
                  You have to really know how the programmer was designed to sort out what it *might* be capable of. I use a really crude device to real masked ROMs because my Unisite toasts them (i.e., tries to query the device to identify it and fries it in the process).
                  Bipolar PROMs are also a challenge for many modern programmers. No doubt the designers figured they are too "old" to bother supporting...
                    • 31219
                    Re: Old programmer
                    the unisite should only use the 13v trick if it's sure the chip is cmos,
                    cant you disable the i.d. check?
                    • Curious.George
                      • Nov 2011
                      • 2305
                      • Unknown
                      Re: Old programmer
                      I don't believe so. It's been ages since I've tried a PROM in the Unisite; I can read bytewide devices using one of my in-circuit emulators so have always relied on that for simple, legacy components.
                      (Most of the devices that I use now are either FLASH-based or use slushware)
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8702
                        Re: Old programmer
                        Interesting, thought there was some sort of embargo on GAL/PAL programming algorithms?
                        I still have a few 22V10/16V8/20V8's and the 20V8s are causing me problems - can't reprogram them. The 22V10 and I think the 16V8s seem okay. These are mostly AMD PALCE20V8 devices that I have trouble with, the Atmel/Lattice devices generally are fine IIRC.
                        BTW, anyone still have a programmer that will do 1702 EPROMs? 2708s/(TMS2716/TMS2732s)?
                        • Curious.George
                          • Nov 2011
                          • 2305
                          • Unknown
                          Re: Old programmer
                          TI's 2716 was a 3-supply part; the TMS2516 is what the rest of the world thinks of as a "2716" (ditto 2532).
                          The 1702 was a PMOS device and used wacky supply voltages -- both in normal use and when programming (Vpp was something like -45V in contrast with 12-25V for later NMOS & CMOS devices). You likely won't find a (modern) "universal" programmer that can support them.
                          [I have a small stash of white/gold CERDIPs that I use to maintain legacy devices -- one of my first products used 1702s before riding the wave up to higher capacity devices. For the true history buff, I've also got a couple of WAROMs collecting dust ]
                            • 31219
                            Re: Old programmer
                            i gave away my 1702/2708 programmer - it was a bulky standalone unit.
                            i can read them with an adapter, and write the TMS parts though.
                            although i prefer to substitute cmos 27c16 when i replace the 08's
                            they run cool and the power consumption of the nmos parts is shocking!
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8702
                              Re: Old programmer
                              Yeah I figure as much, specifically singled out the 1702 (256x8) 2708 (1Kx8) TMS2716 (2kx8) and TMS2732 (4kx8) because they all need a lot of supply voltages to even run normally, something that "modern" programmers simply won't do. It's a wonder some modern programmers even get the 21V or 25V VPP for "normal" eproms.
                              The tricky thing is that you'd have to also mod the socket to replace with a standard 2716/2732 too... but perhaps just cutting traces or leaving the pin outside is sufficient, it's been ages since I looked at the TMS2716/TMS2732 chip data, bleah ...
                              (Oh, no... I was looking at my eprom stash and what did I find? Two TI TMS2716-45s and a MOTOROLA TMS2716C ... why did motorola want to second source braindeadness when they had MCM2716's...
                              At least I have two TMS2532 single supply units, at least during read.)
                              • Curious.George
                                • Nov 2011
                                • 2305
                                • Unknown
                                Re: Old programmer
                                Many "modern" programmers just target the devices they THINK folks will want to use. Having been designed relatively recently would suggest they will target (only) newer devices: "Who could possibly want to program one of those OLD chips???!"
                                [When was the last time you saw a 7603?]
                                If you wanted to support both, you'd put solder switches in the artwork (or jumpers).
                                In the late 70's, early 80's, EVERYTHING was about having second sources. E.g., the 68K was sourced by *8* vendors as leverage to get it into big designs. Sole source parts (like the 6809E) usually left the customer at the mercy of the vendor in terms of pricing AND availability. (Nothing worse than a part that you need going "on allocation" and wondering how you were going to get ANY of them, regardless of price!)
                                Note that you can emulate 2732's by deadbugging 2716's. The beauty of the 27xx pinout was that you could design to support successor devices without making many changes to the site's layout. (which is why TI's parts were so annoying!)
                                • megaraider
                                  • Jul 2015
                                  • 307
                                  • Portugal
                                  Re: Old programmer
                                  For those i've always used the Labtool-48UXP without any problems whatsoever (any GAL/PAL brand).
                                  (Bargain from someone who didn't really what to bother with LPT port)
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8702
                                    Re: Old programmer
                                    I have a few 74S287s lying around somewhere... now where can I get a programmer for these
                                    • Curious.George
                                      • Nov 2011
                                      • 2305
                                      • Unknown
                                      Re: Old programmer
                                      The UniSite will program them. But, that's a helluvalot of programmer to buy just for the occasional oddball part! (OTOH, you can probably pick one up on fleabay for a few hundred dollars, nowadays. Shipping will eat your lunch, though!)
                                        • 31219
                                        Re: Old programmer
                                        i can program bipolar roms with my micromaster1000
                                        • STKR123
                                          The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                          by STKR123
                                          Greetings badcaps community,
                                          I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                          So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                          Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                          I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                          These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                          I learned that desoldering...
                                          10-29-2024, 06:03 AM
                                        • Teeheeze
                                          RT809H Programmer Firmware Corrupted
                                          by Teeheeze
                                          This is a shot in the dark, but I was just using my RT809H programmer and it got stuck in a certain state so I power cycled it. Now, the device LED just flashes quickly and does not connect to the software. I've tried to update the BIOS of it and it fails. I went so far as to remove the ROM from the programmer itself but it's some weird chip (I believe ATMEL, but I can't find any datasheet on it) so I've been unable to read the BIN from it w/ my other programmer. Chip has ATMLHC4C56BM CN written on it (I think). I'll upload an image. I have the programmer's BIN ready to program it manually. Anyone...
                                          02-13-2025, 04:51 PM
                                        • H34TO
                                          ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                          by H34TO
                                          Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                          06-17-2025, 07:17 AM
                                        • vinceroger69
                                          TL866CS MiniPro EPROM programmer software
                                          by vinceroger69
                                          Hi has anyone got the latest software for the TL866CS MiniPro EPROM programmer version 03.2.86 is installed now i have tried the update site in the programmer software but it wont connect to their website i am running windows 10
                                          Edit found this site programmer works now http://www.xgecu.com/EN/Index.html
                                          09-03-2024, 06:21 AM
                                        • EazyBone
                                          EMMC programmer questions
                                          by EazyBone
                                          Looking to up my game a little bit, but these programmers seem a bit daunting.
                                          Trying to get a device for EMMC repair, and it's very difficult to lookup all the words to find if I'm on the right track lol.
                                          Trying to reprogram EMMC on Sony/Hisense mainly but would like to hit a few other brands.
                                          My question is would either of these work? And is there a specific card reader I need for TV emmc? There is like 10-40 additional pieces that I can get but not sure what I actually need for my application only.
                                          I may do eeprom as well. Can someone point...
                                          04-21-2024, 08:18 AM
