tire car balancer
  • tonytiger
    • Jan 2010
    • 163
    • canada
    tire car balancer
    hi guys,a client just brought me this power board,and since the ceramic capacitor is all burn im not sur what i could install there to replace it.....any ideal out there....it is red and big like a 5 cents and there is nothing written on it(burn and gone) i know it is on a 230vac and it is j2.any help will be very appreciated,thank you
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    Re: tire car balancer
    That is a Metal Oxide Varistor, not a capacitor. It is used for transient surge suppression.
    • R_J
      • Jun 2012
      • 9607
      I agree, it is a MOV, likely 275vac 20mm something like a littlefuse V20E275P or V20H275P I would check the transistors on that board (mounted to the heatsinks) The circuit should work (without protection of course) with the mov out of circuit.
      • PeteS in CA
        • Aug 2005
        • 3582
        • USA, Unsure of Planet
        An MOV is normally across the AC line to absorb transient surges. Two things I noticed are the reasons for my comments that follow: that device is over 15 years old; that RJ-45 socket and the nearby PCB show heat damage that probably occurred over some time, not quickly.
        MOVs are fast, can absorb a lot of surge energy, and are cheap. All good characteristics. What is less good is that every time it clamps a surge, a little bit of damage is done. Over time and lots of surges, the voltage at which it will clamp deteriorates until it starts conducting at normal line voltage. The device then starts to overheat and self-destruct.
        I think it is possible that is what happened, a known wear-out mechanism failure. IOW, there is a good chance that if you replace the MOV and any fuse that might have blown, that tire balancer might work OK. You could simply remove it to test it, but leaving it off permanently is probably not a good idea in a repair shop light industrial environment.
        PeteS in CA
        • redwire
          • Dec 2010
          • 3912
          Crydom PF480D25 SSR is rated 660VAC operating and 1200V transients. PCB is labelled 230VAC.
          So that burned MOV should protect just below that, it looks like a 20mm dia. size.
          I would put in EPCOS S20K250 for a 250VAC nominal line.
          Put in a new RJ-45 jack and maybe the green connectors because carbon and soot from the flames are conductive and the board has high voltage present.
          • tonytiger
            • Jan 2010
            • 163
            • canada
            thank you very much for all these info,will check all of this and let you guys know.very good info you gave me,thank you very much all of you.
              • 31256
              dont use a 250v rated part - it will fail very fast!
              • redwire
                • Dec 2010
                • 3912
                What do you suggest for mains in Europe?
                B72220S0251K101 (250) starts to turn on at min. 350V-390V typ.-429V max. (1mA) so 250VRMS min. I thought the data said operating voltage.
                If mains is higher than that then go up to say 300VAC (470VDC) ?
                  • 31256
                  275v parts are commonly used
                    +1
                      • Jul 2011
                      • 6070
                      If you can check these Crydom PF480D25 SSR individually it is rare that they fail but they fail at least DC volts in DC volts out version in our magnets fail and when they it will parlay still work but not correctly
                      But they are easily checked but you have to remove them from the board
                      • R_J
                        • Jun 2012
                        • 9607
                        I did'nt look at all the pictures, and missed the fact they were ss relays.
                        • Grouickman
                          Hofmann geodyna 6300 Wheel balancer
                          by Grouickman
                          Hi there,
                          First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
                          Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
                          I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
                          I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
                          03-31-2025, 05:29 AM
                        • Dannyx
                          Li-Ion battery pack balancer board hack/mod
                          by Dannyx
                          Good day folks. A colleague of mine gave me a little brain teaser today. He likes tinkering with batteries and create all sorts of packs for various battery operated systems we have set up out in the field and he's currently working on a large 40-something cell pack for use in some traffic monitoring system or something, doesn't really matter, a sh!t ton of 18650s there
                          For a higher capacity, he's stacked like 10 cells in parallel and then wired these sets in series to one another get 18v or 12v, can't remember for sure which one, though I think it 18v, so 4 sets. While he was...
                          05-03-2019, 12:24 PM
                        • A Man
                          John Bean VIP II Tire Balanceer No Power
                          by A Man
                          I have a power/control board for a John Bean tire balancer made my Snap On. the numbers on the board are:
                          PWB EAP0167G30A
                          ASSY EAP0167G31A
                          I bought this unit after watching it in operation yet when I brought it home and plugged it into 120V, it was completely dead. The switch and fuse were good so I removed the board from the machine for further analysis. When I did, VR3 fell from inside the cover. I resoldered this resistor but it still will not power up. Further inspection showed that VR2 was about to break off as well, so I removed it and...
                          11-01-2017, 10:51 AM
                        • ranchhandbumper
                          1992 Toyota Truck Speedometer
                          by ranchhandbumper
                          I am working on a 1992 Toyota pickup that has an electric speedometer. It is an analog needle speedometer and is driven by electricity.There is no cable. The transmission has a reed switch that sends a 12 volt pulse to the speedo 4 times per tire rotation.
                          According to GPS, the speedo is showing speed progressively slower below 50mph and progressively faster above 50mph. This also affects the odometer.
                          I've included a photo of the findings. The "control" is information I found on the net that correlates expected MPH based on a given hertz.
                          I removed...
                          11-12-2022, 08:12 PM
                        • Thomasraud
                          Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                          by Thomasraud
                          i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                          QUOTED
                          -It works on charger (without battery connected-only charger)
                          -It works on battery (without charger connected-only battery)
                          -& it also works when plugged in battery & charger, but it's not charging the battery
                          //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                          and..
                          QUOTE
                          The IC cannot maintain the input current level
                          06-28-2022, 06:47 PM
