Dell INSPIRION 15 7567 BSOD
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Seems only with windows OS, when I try to install win10 appears the BSOD
    ACPI BIOS ERROR.
    I have read that this error could be connected to a ram insertion in a hibernation state.
    Furthermore it seems that it is not directly connected to ACPI.
    Anyway, has anyone already had a similar experience?
    I tried everything possible without taking it apart but without results.
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Dell INSPIRION 15 7567 BSOD
    which Win10 installation step does the error appear at?
    • jasko_jacker
      • Oct 2014
      • 1140
      • italy
      I choose the USB pen from the menu, press enter, the installation begins and 2 sec after appear that error .
      Just before it starts turning the wheel to wait
      • petehall347
        • Jan 2015
        • 4445
        • United Kingdom
        https://windowsreport.com/acpi_bios_error-windows-10/
        this looked good info but my adblocker stopped me looking , https://www.thewindowsclub.com/acpi_bios_error_windows
        • jasko_jacker
          • Oct 2014
          • 1140
          • italy
          I was sure, but I hoped not, that it was just a bios problem. I disassembled the notebook and on the motherboard I saw a burnt inductance, fortunately the right and left values are 9.5 ohm and 10 ohm, is it possible that there are no other problems? It's strange that the motherboard turn on and that all hardware test in bios are passed
          Anyone have experience with this LA-D993P card?
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            the schematics file is required to check.
            • jasko_jacker
              • Oct 2014
              • 1140
              • italy
              unvailable
                • 21969
                Can you trace where each pad goes to from pl900 .
                • jasko_jacker
                  • Oct 2014
                  • 1140
                  • italy
                  I have an idea, if I put a fuse in series with a new inductance, I can prevent the situation from getting worse. However, I don't know how many amps the fuse must be.
                  I try to trace, I think it is the power of the video card because otherwise the card would not start
                    • 21969
                    If the traces go to one of the IC`s you can get its datasheet and see what the recommended part is or find another compal schematic with the same IC layout.
                    • caspian
                      • Oct 2015
                      • 1591
                      • Laptop
                      I found that LA-D991P is a mainboard similar to LA-D993P. But I did not find its schematics neither.
                      It seems that the burned inductor is connected to PQ900 and PL1505.
                      • peste
                        • Dec 2016
                        • 13655
                        • ROMANIA
                        https://cdn.badcaps-static.com/pdfs/...8b4aa33e57.pdf
                        check if the inductor is on the power supply of the P900, what voltage is on the green but blue point?
                        • jasko_jacker
                          • Oct 2014
                          • 1140
                          • italy
                          I have traced the component under check and after cleaning the card the previous values are wrong.
                          (LA-D991P schematic is unvailable)
                          The burnerd inductor receives the 19V and sends it to a double mosfet (siz980dt). This mosfet is driven by an ampec (APW8828).
                          I expected a short on S1 / D2 but the Ohm value is high (G1 and G2 -> 0V with motherboard ON).
                          What I would like to understand is if the circuit of this board page 73 LA-D751P schematic is similar. (it seems that on the alienware LA-D751P both the ram and the GPU are powered by the same 1.35VS_VGAP-> 1.35VS_VGA line but I could be wrong)
                          However it seems that PL901 is the voltage for VRAM.
                          Following the track that goes under one of the ram and which has an Ohm value of 0.50 compared to PL901 (therefore they are connected) I do not detect any short compared to GND. I don't know if it is appropriate to inject the 1.35V on PL901.
                          • chorumluum
                            • Dec 2019
                            • 10
                            • Türkiye
                            i need to near to pl-500 coil resistance can you take a makro picture this part and if you make write to value of resistance?
                            • jasko_jacker
                              • Oct 2014
                              • 1140
                              • italy
                              I hope I understand well your request
                              PL500 should be the 19V input for the controller power supply related to the ddr4
                              • chorumluum
                                • Dec 2019
                                • 10
                                • Türkiye
                                i need to this area compoment type, value and code. Because my technician need this for replacement. Thank you for helping.
                                • jasko_jacker
                                  • Oct 2014
                                  • 1140
                                  • italy
                                  To obtain an accurate measurement, the components must be desoldered, the values in the photo are not accurate but could be useful anyway. I was unable to find information on the A0S70S controller, open a thread to get help about this component.
                                  • chorumluum
                                    • Dec 2019
                                    • 10
                                    • Türkiye
                                    My technian measure that top side 2 resistor and said me top side value will be differet horizontal wll be 49 k ohm and pl-500 will be 0m. That is possible? Sorry for my english.
                                    • jasko_jacker
                                      • Oct 2014
                                      • 1140
                                      • italy
                                      PL-500 is the input voltage line so if the value in Ohm is near 0 there is a short. To localize that short, remove PL500 (1 in pic) and desoldered PJP500 and PJP501. If you have 0 Ohm on:
                                      point a -> short on main B+ 19V line (the problem is in another location)
                                      point b -> remove capacitors 1 2 3 4 if the short persist probably PU500 is broken.
                                      There are probably other components that concern PU500 but without the scheme I cannot help you.
                                      • jasko_jacker
                                        • Oct 2014
                                        • 1140
                                        • italy
                                        I soldered a new dual mosfet , changed the burnt coil and replace the inductor. Now at the end of PL901 there is 1.4V . all that remains is to replace the capacitor (19V to GND) with an appropriate value, which value do you recommend?
                                          DELL Inspiron 7567 Notebook 7000 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 7567 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7567 boardview and 7567 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 7567...
                                          09-06-2024, 08:01 AM
