Recovery Options for JVC LT-49C890 - Vestel 17mb130 Firmware Bricked
  • legacy3010
    • Jan 2020
    • 8
    • United Kingdom
    Please can someone help me?
    I flashed a v3 firmware (17mb130 v3.62.73 https://files.fm/u/vdteeuch) for Vestel 17mb130 and now my TV is stuck in standby mode.
    The correct firmware I need was 17mb130 Full V.5.7.20.0
    I only found out after using translating some Turkish websites that I could not do this. Is there any hope for my TV?
    The mode and serial are:
    LT-49C890(A)
    The software I flashed was: 17MB130 full V3.62.73
    The Software I needed to flash was 17MB130 Full V.5.7.20.0
    Then will not boot after. Only flashing standby light.
    I have all these files backed up but nothing more.
    Is this reparable?
  • legacy3010
    • Jan 2020
    • 8
    • United Kingdom
    Re: Recovery Options for JVC LT-49C890 - Vestel 17mb130 Firmware Bricked
    I have been on the forums again in Turkey and they say I can service it by changing flash?
    Is that the process of changing the eeprom chip on the 17mb130?
    https://www.youtube.com/watch?v=98arrgTwnws&t=164s
    I will also have a replacement board but I have purchased it for the wrong panel... I am such a rookie it's laughable.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8297
      see if you can find a firmware dump for your board. Take the eeprom off the board, program the IC with a programmer (like a TL866), then put it back on.
      • arizanotlari
        • Nov 2014
        • 158
        • Turkiye
        Try this : https://yadi.sk/d/dh7aWXlQybD5Hw
        https://www.badcaps.net
        • legacy3010
          • Jan 2020
          • 8
          • United Kingdom
          Originally posted by arizanotlari
          Thank you, I tried this file but I get an error when flashing at about %37.
          I am using a different board I purchased now. So I just need to get the TV to recognize my Panel.
          I have the same board but for panel VES 40 UHD. SO some how I need to fix that?
          Can I do it witht he files I show in my uploaded image?
          • yokoono
            • Apr 2010
            • 502
            "Thank you, I tried this file but I get an error when flashing at about %37."
            How did you proceed? When updated with this software does not show the percentage.
            • legacy3010
              • Jan 2020
              • 8
              • United Kingdom
              I purchased a new 17mb130 board but the panels do not match :-(
              So now I need to somehow get my panel to display in 492 4k uhd. But it's split the JVC logo, and the menu does not fit on the screen correctly.
              From my files in the image I uploaded and I fix this board? I think I just need the original firmware but I don't have that.
              • yokoono
                • Apr 2010
                • 502
                Unplug the eeprom / flash memories from the old board and reload the new board.
                The soft full update is done with the OK key pressed.
                • legacy3010
                  • Jan 2020
                  • 8
                  • United Kingdom
                  I have tools but I am only capable of soldering larger components.
                  This is what it looks like now,
                  • yokoono
                    • Apr 2010
                    • 502
                    Have you tried the above software?
                    1. Unzip
                    2. Put the 4 files on the stick with FAT32
                    3. Insert the stick into the TV
                    4. Press and hold the OK key on the remote control (towards TV)
                    5. Plug the TV into the socket
                    6 The stb LED blinks slowly then quickly
                    7 Release OK
                    8. Wait for it to finish. It can take up to 5-10 minutes.
                    • legacy3010
                      • Jan 2020
                      • 8
                      • United Kingdom
                      1. Unzip
                      7 Release OK
                      This one Bricked the second board I purchased :-(
                      No worries, I purchased another one and it's all working except I have a message on my display preventing me from accessing the menu without entering an activation code.
                      Do you know if there is a way to bypass this?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        in hotel mode?
                        https://quuq.org/forum/index.php?topic=6170.0
                        • aissasat36
                          • Jul 2021
                          • 1
                          • 1mail
                          charger 130mb panel
                          • Tommes
                            Telefunken D43F287N4CWII - Vestel 17MB110S - Recovery Firmware
                            by Tommes
                            Hey Folks,
                            I'm searching for a Full Flash Recovery Software
                            for my Telefunken D43F287N4CWII
                            Mainboard Vestel 17MB110S
                            Panel: VES430UNDB-2D-N12
                            Productcode: 10119394
                            Does anyone know, where I can get it ?
                            Or is it possible, to extract it from a working mainboard ?
                            The Support Telefunken/Vestel GER couldn't help me.
                            The Vestel TR Support didn't answer my email.
                            History:
                            The main problem with my Telefunken D43F287N4CWII was,
                            it just goes out after a while, sometimes after a...
                            01-04-2022, 09:56 AM
                          • Bazilwrc164
                            Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                            by Bazilwrc164
                            I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                            The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                            I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                            If anyone can provide:
                            • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                            • Or a compatible EEPROM dump
                            07-23-2025, 12:15 PM
                          • codernov
                            soundboks 3 bricked firmware ($600 bluetooth speaker)
                            by codernov
                            https://i.ibb.co/Z1hKTkwW/0001.jpg
                            https://i.ibb.co/BK7YmhHx/2025-06-06-16-14-IMG-5818.jpg
                            This thing is pretty expensive. More than an average notebook.
                            Anyway. I got this job over facebook market place. Customer said he bought it used and it was working fine, then he decided to upgrade firmware and somewhere along the way the battery died or whatever we don't know, it got bricked. That's his story and he's sticking with it.
                            If we connect power supply to it, we are getting 21 milliamps and nothing is happening. Pressing buttons does nothing....
                            06-06-2025, 07:05 PM
                          • massimomax
                            Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                            by massimomax
                            Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                            spero che qualcuno può averlo per riprogrammare eprom. grazie
                            Post in English !!!
                            I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                            02-28-2025, 07:27 AM
                          • anlu
                            Vestel Firmware - Toshiba 32W133DN
                            by anlu
                            Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                            Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                            02-04-2023, 12:59 AM
