need bios on biostar A58MD desktop motherboard
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need bios on this biostar A58MD Ver. 6.8 please. Ill try downloading on the site but it is exe file can someone help
  • peste
    • Dec 2016
    • 13121
    • ROMANIA
    Re: need bios on biostar desktop motherboard
    try...
    https://drivers.softpedia.com/get/BI...BIOS-B05.shtml
    • String2016
      • Nov 2015
      • 2238
      • philippines
      thanks i already done flash the bios at first it turns on and display comes after i shut it down , it cannot turn on again unless i removed the cmos battery but if i plugged the cmos battery it cannot turn on please help on this
      • Aliencomputres
        • Aug 2019
        • 210
        • România
        Re: need bios on biostar A58MD desktop motherboard
        Assuming the CMOS battery is indeed 'good' - a couple possibilities come to mind:
        - Corrupted BIOS - Clear CMOS via 'JUMPER' method; failure = Re-Flash BIOS
        - Above fails - Possible bad PSU; try different PSU.
        • glovecaps
          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
          by glovecaps
          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
          11-25-2024, 04:23 PM
        • hotcrossedbuns999
          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
          by hotcrossedbuns999
          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
          3. I could only locate two chips that look like bios chips. Could someone verify this
          01-03-2025, 12:32 PM
        • ReeferMadness
          Bios for Gigabyte GA-MA74GM-S2 desktop motherboard
          by ReeferMadness
          Can anyone post a complete bios dump for a Gigabyte GA-MA74GM-S2 Rev 1.0 desktop motherboard please?
          I have a dead motherboard - with no obvious signs of damage which I would like to save from scrap
          Many thanks for any help
          01-17-2025, 10:55 AM
        • dnytwaryors
          ASUS PRIME B365M-A DESKTOP MOTHERBOARD BIOS HELP
          by dnytwaryors
          Hello Everyone, Can you help me clean this bios backup I have? It won't display. I'll try everything related to display and my last option is bios, Thank you.
          This is my backup bios...
          08-23-2024, 12:58 AM
        • oragano
          ASUS ex-b250-V7 motherboard bios corrupted - by me
          by oragano
          hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
          So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
          i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
          10-17-2024, 02:53 AM
