Need Schematic MSI B75MA-P45
  • spintop
    • Feb 2011
    • 132
    Anyone has Schematic MSI B75MA-p45 ?
    Thanks in advance
    • 22415
    Re: Need Schematic MSI B75MA-P45
    Schematic and boardview .
    • spintop
      • Feb 2011
      • 132
      Thank u for the files.
      after reflash bios with the bios file (v19) from MSI website, problem still same.
      No display, fan is spinning.
      anyone can advice ?
      • Aliencomputres
        • Aug 2019
        • 220
        • România
        and the issue is...........?
        • idepv
          • Feb 2022
          • 12
          • CS
          Thank u very much!
          • anikin73
            • Mar 2022
            • 112
            • singapore
            anyone can advice ?
            I had repaired this board many times. what you need is to measure the voltage of motherboard. likely is one of the voltage did not appear.
            • TinkerTron
              Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
              by TinkerTron
              Hey everyone,
              I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
              Instead, here's what's been bugging me so far:
              The schematic...
              03-06-2025, 02:03 PM
            • andrhouseolly
              Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
              by andrhouseolly
              Hi.
              I kindly ask you to help me solve the problem.
              Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
              The board turns on, there is no image.
              Read more. When the power supply is connected, the front panel indicators light up briefly.
              When you press the power button, the button indicator lights up. The board works
              there is no image, there is no matrix initialization, there is no image on HDMI.
              When turned on, the fans do not spin, but when they warm up they start spinning.
              When you turn off the button, the fans spin up to full speed for a short...
              05-11-2024, 03:14 PM
            • Sdhjm
              Schematic with element ratings hp victus 15 dag3pmb18b0 rev:b g3p
              by Sdhjm
              I'm asking if anyone has a schematic for the dag3pmb18b0 rev:b g3p board. I found a schematic of the board, but I don't have the component numbers. If anyone needs a schematic, I can send it to you, but I don't have the numbers....
              11-26-2025, 03:43 AM
            • Thetechdude
              MSI Ventus RTX 4080 16G Broadview schematic needed
              by Thetechdude
              Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
              I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
              Thanks.
              07-15-2025, 11:15 AM
            • ianpoultonknights
              Zenbook Flip 15 UX562AI schematic
              by ianpoultonknights
              Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
              06-26-2025, 02:41 PM
