ACER A314-32 bios needed
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need a working bios on ACER A314-32 DA0Z8GMB8D0 REV MODEL: Z8G please! the problem stuck on acer logo then shuts down and restart. go to bios menu there is no option can enable UEFI AND LEGACY option.I have attached the original corrupted bios, can someone fix this please
  • peste
    • Dec 2016
    • 13768
    • ROMANIA
    Re: ACER A314-32 bios needed
    try...
    • String2016
      • Nov 2015
      • 2238
      • philippines
      @peste i try your bios but still the same issue acer logo shows up then shuts off and restart, when i go to bios menu still no option to change uefi to legacy
      • String2016
        • Nov 2015
        • 2238
        • philippines
        need help please
          • 22127
          try this one,your win key included.
          W 385000h
          • String2016
            • Nov 2015
            • 2238
            • philippines
            still the same issue secureboot on the bios menu cannot change
            • String2016
              • Nov 2015
              • 2238
              • philippines
              anyone have a working bios on this the problem is turns on boots fine on acer logo then shuts off and restart but when i go to bios menu i cannot change the options on uefi to legacy it just disabled. here it is only showing
                • 22127
                The bios i posted was extracted from acer bios update. There shouldn`t be any problem. Try bios setting with and without the hard drive
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  already tried that without hard drive above picture showing
                    • 22127
                    Post your EC backup .
                    • piernov
                      • Jan 2016
                      • 4439
                      • France
                      If you want to disable SecureBoot you may need to set a supervisor password and reboot. Or just leave it enabled and boot on an official Windows (7, 8 or 10 64-bit) media in UEFI mode.
                      • Vesko356
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        True, on some Acer models including this one if you want to change SecureBoot option, supervisor password must be enabled first.
                        Become a Badcaps supporter
                        Thanks to all supporters.​
                        • String2016
                          • Nov 2015
                          • 2238
                          • philippines
                          problem solved burning uefi flash drive thanks all for the help
                          • joeycuadr
                            • Jul 2016
                            • 4
                            • phillipines
                            EC backup A314-32 password problem
                            • aprilbg087
                              • Feb 2018
                              • 30
                              • Philippines
                              W 385000h
                              this works perfect
                              thank you
                              • technician37
                                • Aug 2018
                                • 30
                                • philippines
                                verywell said sir..
                                • tribalcore20
                                  • Jun 2020
                                  • 66
                                  • Philippines
                                  Looking for bios bin acer 3 a314-32
                                  Acer aspire 3 a314-32
                                  Model no: N17Q4
                                  Motherboard: DA0Z8GMB8F0 REV: F
                                  • piszpunta
                                    • Jan 2019
                                    • 260
                                    • poland
                                    Re: Looking for bios bin acer 3 a314-32
                                    try
                                    • tribalcore20
                                      • Jun 2020
                                      • 66
                                      • Philippines
                                      Did not much id sir.
                                      • rudi.ssc
                                        • Feb 2019
                                        • 2
                                        • Indonesia
                                        is it work?
