Asus ROG gl752v dead touchpad
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. Just thought I'd open up this discussion mostly out of curiosity to see if anyone else had this issue on Asus ROG laptops...or any other laptop for that matter.
    The problem is the touchpad is completely dead and I'm suspecting it's a hardware failure: it's not showing up in Device Manager in any way, it doesn't work under Hirens and no amount of restarts and driver reinstalls got it going again. The touchpad has a 4 pin ribbon connector, so I think it's an I2C connection (SDA,SCL,GND,VCC). The ribbon cable looks fine (though this could be misleading and it could STILL be bad) and the laptop had no liquid damage, so the touchpad somehow failed. It's worth mentioning the laptop was booked in as dead and it was reballed by one of our guys here and that brought it back to life indeed, except it's still got this issue....maybe the heat upset something else...
    Anyone else had this issue before and if so, have you managed to solve it ? Thank you.
    Wattevah...
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Asus ROG gl752v dead touchpad
    OS version?
    Did you installed:
    1.ATK Package V1.0.0020 or later
    2.ASUS Smart Gesture (Touchpad Driver)?
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Originally posted by Vesko356
      OS version?
      Did you installed:
      It's currently on Win 10. Yes, I mentioned that: they tried multiple software routes but none worked
      Wattevah...
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        OK, read this:
        >>>Troubleshoot problems that occur with ASUS Smart Gesture after upgrading to Windows 10<<<
        • piernov
          • Jan 2016
          • 4439
          • France
          Try with a Linux LiveUSB to try to exclude a Windows software issue.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            I believe Hirens counts as one of those non-Windows platforms which should load the touchpad by default just like a regular mouse.
            Also upgraded BIOS to the latest version, forgot to mention that...
            Wattevah...
              • 22002
              Have you installed the Intel Serial IO I2C Driver
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                Hmm....not sure what these guys installed on it since it wasn't technically my project, so it could be a driver issue after all, though I don't recall an instance where the touchpad wasn't working even under an alternate OS because of a driver issue.....does it happen on ROGs ? :|
                Wattevah...
                • myth77
                  • Feb 2017
                  • 380
                  • Croatia
                  I had similar model gl552vw with not working touchpad...although all readings seemed to be fine. I borrowed two touchpads from similar models but they didnt work...i also checked ribbon cable, tried linux, atk, another bios.....but nothing....so i was thinking probably pch or ITE failure...But finally i received another gl552vw laptop that had some other issues...and tried to use that touchpad and it was working fine
                  So in the end the touchpad was broken with no shorts or any signs of failure that i could find. And interesting that all similar models didnt work on this laptop...
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    That's why I decided to ask if others encountered this problem...turns out touchpads CAN fail...
                    Wattevah...
                    • rheyntau
                      ASUS C202SA CHROMEBOOK TOUCHPAD NOT WORKING AFTER INSTALL WINDOWS 10
                      by rheyntau
                      CAN ANY ONE HELP ME WITH THIS PROBLEM....ASUS C202SA CHROMEBOOK TOUCHPAD NOT WORKING AFTER INSTALL WINDOWS 10 ..IT WAS ELAN TOUCHPAD..I DOWNLOAD A DRIVER BUT ITS NOT WORKING IT SAYS "WINDOWS FOUND DRIVERS FOR YOUR DEVICE BUT ENCOUNTERED ERROR.....THE HASH FOR THE FILE ISNOT PRESENT INTHE SPECIFIED CATALOG......."
                      07-06-2025, 07:22 AM
                    • jamesp
                      Asus TP412FA keyboard and touchpad not functioning
                      by jamesp
                      Hello guys,
                      need help, i have a laptop that i encountered having keyboard and touchpad not working, not immediately going to BIOS i already tried replacing even just the keyboard with a new one but still problem exists. now i only realized to checked it from bios to erase doubts. i found out both touchpad and keyboard are working only on BIOS but not on windows.
                      since i cant just reformat the said laptop, i tried installing MyAsus utility and updated my drivers , and windows update as well. i included updating the bios to latest 3.08 version. still kb and touchpad is working on bios...
                      08-18-2024, 11:02 AM
                      ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                      This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                      09-07-2024, 02:50 AM
                    • tranquility
                      Asus X515KA not booting. after flashing bios sometimes i come there. but then dead again
                      by tranquility
                      hallo,
                      i have an asus X515KA-EJ058W here.
                      just both leds white...he battery blinking without battery connected
                      consuming ~400mA and tries to start but nothing happens but fan spinning if cpu gets warm
                      if i hold the power button it shuts down and consumes ~30mA i cant spot anything getting warm with thermal....the ec/sio a liiiitle but this is maybe normal beacause it is working ?
                      power on again is possible but again 400mA then and no picture.
                      now the really strange
                      i flashed bios (some version i found on the internet) and resoldered....sometimes...
                      12-11-2024, 06:47 AM
                    • ShadowAi
                      ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                      by ShadowAi
                      Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                      Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                      After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                      03-15-2024, 10:46 AM
