Marvell Gigabit controller stuck at 100Mbps
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    My NAS is a Windows 10 1909 64-bit PC running on an EVGA Z68 FTW motherboard which uses a Marvell 88E8057 network controller.
    The problem is that the network connection is stuck at 100Mbps. That really sucks when I'm trying to move large files around.
    I tried a few different network cables, I tried moving it from my Asus router to my Netgear switch (both of which are obviously gigabit).
    Driver version is 12.10.16.0 which was automatically installed by Windows. EVGA's website lists an older version than that. Marvell's website lists 12.10.17.3 but when I try to install it, it says "a newer version is already installed"
    Not sure what the next step is besides putting in a PCI-E NIC which I really don't feel like doing.
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Marvell Gigabit controller stuck at 100Mbps
    Did you try other cats? LOL.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • diif
      • Feb 2014
      • 6978
      • England
      It wouldn't bee the first time a Windows driver has screwed up an ethernet connection.
      Uninstall the Windows driver and install the one from the EVGA website.
      • RJARRRPCGP
        • Jul 2004
        • 6304
        I would be pissed and think of wiping the drive and reinstalling Windows.
        Especially Windows 10 with Windows Update errors.
        Arc A770 16 GB
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Yes, I borrowed my friends furry friend and tried to shove it in the second Ethernet port because the motherboard has too. Unfortunately, I got a hissing noise and some scratches, and my friend is now angry at me.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Did you try setting the speed to 1000Mbps manually?
            It's quite common to have auto negotiation issues with gigabit Ethernet.
            Intelligent switches and most NICs have some options to change to alleviate that
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Nope, in the drop down on windows I can't pick gig. Only 100 or autonegotiate.
                • 31137
                try a linux livedisk,
                try a new cable - check it has all 8 wires connected.
                100mb does not use all 8, 1000 does.
                if you still cant get it going, check the transformer on the motherboard and any asociated ceramic caps.
                if the chip cant detect all 8 lines it will not run at 1000.
                incidentally, most marvel chips can run a cable test and even have a built-in TDR function.
                try tracking down the software - i think asus used to supply it with the top-end athlon boards.
                  • 21417
                  Marvel have a DOS diag utility,and a Virtual cable tester . https://www.marvell.com/support/downloads.html
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16958
                    Cable would be my #1 suspect as well...I've ran into this a lot over the years.
                    <--- Badcaps.net Founder
                    Badcaps.net Services:
                    Motherboard Repair Services
                    http://folding.stanford.edu/
                    Team : 49813
                    Join in!!
                    Team Stats
                    • dragos2009
                      • Mar 2013
                      • 110
                      • Romania
                      i would sugest getting a q tip + IPA to clean the ethernet connector pins i had problem with connection cause of debris on the pins
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8285
                        maybe the pins are bent in the marvel Ethernet port? seen that and the actual port being worn out (from plugging in and out too many times). Other than that I guess drivers. Maybe a boot linux from a stick and retest.
                        • exy1
                          • Jan 2021
                          • 1
                          • US
                          simple way to test
                          1 just plug same cable to laptop and check speed ( don't change any setup)
                          if laptop works on 1gbps
                          2 boot from live cd from NAS ( Any win 10 live cd-dvd-USB works)
                          if not going on gbps check network port pins are straight and clean ( use alcohol and q-tips to clean it.
                          If Live cd works then some thing wrong set in network card drive advance settings.
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            Sorry, forgot to update, no solution, have tried all the physical cleaning and testing. Will try Linux at some point. Switched my Plex server/NAS to a different system solved the problem.
                            • stormanimal83
                              Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                              by stormanimal83
                              Hey....
                              Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                              my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                              01-18-2024, 02:15 PM
                            • Stunt
                              Hp Laptop Stuck on Hp protected by hp sure start screen
                              by Stunt
                              Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                              I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                              I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                              Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                              screen that's it and stuck there. I left it until the following day and i still...
                              09-02-2025, 01:51 PM
                            • master3112
                              ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                              by master3112
                              I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                              When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                              10-29-2024, 09:32 PM
                            • madan1
                              Cisco catalyst 2960c POE
                              by madan1
                              Hello everyone.
                              Got a catalyst 2960 from the usual scrapyard - ebay.
                              It is stuck in bootloop and the power supply is missing the 3.3v rail. (+12V, -53V, +3.3V)
                              Some green moisture crystallization on mainboard, which cleared very well with IPA and visually there is nothing rusted or gone.
                              Still working on the PSU to get the 3.3v rail back (waiting for parts), but for now I'm using an external buck converter board hooked up to the 12V rail ( by the way, the switch seems to be working with only 12V ).
                              The switch fails to boot due to the following POST error:...
                              12-19-2024, 09:34 AM
                            • Spikeman
                              Dell Precision 3440 support for CPU 11th gen
                              by Spikeman
                              Hi, since both the Dell Precision 3440 and the Precision 3450 have the same chipset W480.
                              I ask you if it is possible to add the correct microcodes for the Precision 3440.
                              I am adding the list of files that I have extracted from the Bios in order to help you understand if it is feasible.
                              Precision_3440_1.31.0.exe_extracted Precision_3450_1.31.0.exe_extracted
                              03-11-2025, 09:54 AM
