Laptop panel has green tint & purple lines.
  • Johndill
    • Aug 2015
    • 314
    Hi, I have a laptop panel model LP173WF4 which has suddenly got a green/blue like tint and purple lines, You can see in the picture with MS Paint that it is not a white screen and you can compare to the white in the monitor in the background. Is this fixable & if so, what can I do? Thanks :-)
    It has been tested on a known good system & found to be a fault with the panel & not the system or cable.
  • Johndill
    • Aug 2015
    • 314
    Re: Laptop panel has green tint & purple lines.
    Bump.
      • 31316
      test it on something else.
      it's tempting to blame the panel, but i had a tv like that i fixed with a re-cap.
      • Johndill
        • Aug 2015
        • 314
        Hi, thanks for your reply, as stated in the original post, "It has been tested on a known good system & found to be a fault with the panel & not the system or cable." :-) Could it be a cap on the panels control board?
          • 31316
          it could be a cap or a chip - but your chances of doing hot-air rework on it without damaging the tab-bonds is slim.
          • Abu Sayeed
            • Mar 2020
            • 4
            • Bangladesh
            it could be a bad connector, plz check your connector bad or dissolder.
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • learnmore
              Samsung UE70TU7020K Which lines to tape on a bad panel
              by learnmore
              Hello Community,
              I'm working on a Samsung UE70TU7020K.
              It looks like a bad panel. There is only 1 FPC cable from the Tcon (built into mainboard) to the panel.
              I'm using a piece of tap a few mils (covers about 8-10 pins), at different locations and have had varying results but nothing that is remotely watchable (multiple lines across all the screen, half screen and total black out on screen). The buffer board is divided into 3 boards. I've disconnected the end board one at a time but each time the screen was totally black. I presume it's because the potential...
              03-15-2024, 03:01 PM
            • Anonmis
              Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
              by Anonmis
              Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
              The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
              12-01-2023, 04:31 PM
            • Raulnn
              Xiaomi L55M5-5ASP fine lines on the panel uniform
              by Raulnn
              Good afternoon! Does anyone know how to remove these lines? They are very fine lines at the bottom of the panel. I have 2 identical panels, and I have even thought that this brand has this lattice format, although I highly doubt it.
              The photo from the YouTube app is where it is best seen.
              thanks in advance....
              01-28-2024, 10:30 AM
            • arctor
              samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
              by arctor
              hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
              04-26-2025, 05:22 AM
