HP Probook 470 G5 DA0X8CMB6E0 BIOS X8C
  • dani981
    • Mar 2018
    • 89
    • Hungary
    Please help me.
    Not boot removable device, or hdd or ssd. Bios info or boot menu see device
    Not boot all device.What problem Bios?
  • bachir2004
    • Feb 2015
    • 439
    • maroc
    Re: HP Probook 470 G5 DA0X8CMB6E0 BIOS X8C
    bios version is Q85_010901 Rev.A.try this and report back.
    • dani981
      • Mar 2018
      • 89
      • Hungary
      First boot working alles ok. Secund boot not boot alles restart.
        • 21439
        Do you have your original bios backup .
        • dani981
          • Mar 2018
          • 89
          • Hungary
          No backup BIOS, unfortunately this is how it got to me
            • 21439
            Try this bios .
            Intel Management Engine (Consumer) v11.8.70.3626
            • dani981
              • Mar 2018
              • 89
              • Hungary
              Try this bios .
              Thank you very much
              Working
              • acid-noise2
                • Jul 2019
                • 3
                • France
                would it work if I was to flash the same model with this bin ?or do i need to submit my own dump ?
                • peste
                  • Dec 2016
                  • 13176
                  • ROMANIA
                  you can try, but before you make a copy, if nothing goes, put the bios backup here and someone will help you.
                  • acid-noise2
                    • Jul 2019
                    • 3
                    • France
                    Thank you, so far i'm still trying to read the chip and i'm helpless so far so i'll get back on the forum when i manage that
                    • Spider1211
                      • Oct 2019
                      • 532
                      • Mauritius
                      HP Probook 470 G5 BIOS request(repair or known good)
                      Hey guys, grateful if someone can check if the attached BIOS is not corrupted and/or provide a known good BIOS please.
                      Issue:
                      Laptop came in as not turning ON. I did a BIOS reset and laptop now has power but not booting.
                      When power adapter is connected, power key light comes on, goes off then comes on again. When it comes on again, there is 5 long blink on caps lock and numlock simultaneously. Once the 5 blinks stops, fan ramps up to full speed and stays there until device is forced off. No display and HDD does not spin.
                      What I tried so far:
                      1. Clean ME of original BIOS dump
                      2. Change ME version form 11.8.55.3510 to 11.8.70.3626 (consumer)
                      3. Tried BIOS from this thread: https://www.badcaps.net/forum/showthread.php?t=82574
                      Motherboard: X8C DA0X8CMB6E0 REV:E
                      There were some dead ants when I removed the black sticker but aside from a slightly corroded resistor near Touch Pad connector (already fixed) motherboard is spotless.
                      All voltage rails except CPU Vcore and GPU are present and stable. BIOS resistors are OK and data activity can be observed on DSO when powered ON.
                      Grateful for any help. Thank you!
                      • Spider1211
                        • Oct 2019
                        • 532
                        • Mauritius
                        Re: HP Probook 470 G5 BIOS request(repair or known good)
                        Bump. Anyone?
                        • mrwab
                          Banned
                          • Jan 2014
                          • 83
                          • morocco
                          Hello
                          try this and reply me
                          • Spider1211
                            • Oct 2019
                            • 532
                            • Mauritius
                            Thank you @mrwab but not working unfortunately. Still same issue.
                            • Spider1211
                              • Oct 2019
                              • 532
                              • Mauritius
                              Bump, anyone please?
                              • qayyum786
                                • Aug 2018
                                • 1935
                                • INDIA
                                try
                                • Spider1211
                                  • Oct 2019
                                  • 532
                                  • Mauritius
                                  No luck, still same.
                                  • basic
                                    • Oct 2017
                                    • 229
                                    • 86357289244
                                    Hp Probook 470 G5 -Bios needed
                                    hi friends
                                    i need for this model bios
                                    hp 470 G5
                                    DA0X8CMB6E0 REV:E
                                    THANKS IN ADVANCE
                                    • basic
                                      • Oct 2017
                                      • 229
                                      • 86357289244
                                      hp 470 g5 -repair bios files needed
                                      need repair this corrupted bios files
                                      • peste
                                        • Dec 2016
                                        • 13176
                                        • ROMANIA
                                        Re: hp 470 g5 -repair bios files needed
                                        try..
                                        • throwaway327
                                          Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                                          by throwaway327
                                          ASUS ROG Ally X - (Handheld Gaming PC)
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                                          I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                                          06-18-2025, 05:52 PM
                                        • ktcar214
                                          Need help for HP ProBook 445R G6 Secure boot key removal from BIOS dump
                                          by ktcar214
                                          Hello.
                                          I tried to add a custom secure boot key (for secure booting Linux) to my bios, but after this, my laptop bricked. After adding secure boot key (via PowerShell) and enabling secure boot my laptop turns on, shows HP logo, and after 5 seconds it turns off and on, and it repeats forever.
                                          My goal is to either turn off secure boot or remove my custom key from BIOS dump.
                                          I'll attach my bios dump (version R79_011700) from my bios chip 25b127dsig, my keys (PK/KEK/db), and bios dump from another HP ProBook 445R G6(I found it on this forum. URL: https://www.ba...
                                          12-07-2021, 08:57 AM
                                        • q2v5
                                          Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                                          by q2v5
                                          Lenovo T480s
                                          Model 20L8-S3TE00
                                          Board ET481-U10
                                          Chip MX25L12873F
                                          Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                                          2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                                          The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                                          08-15-2024, 10:40 PM
                                        • Neddsme
                                          Bios partially corrupted somehow and now warm boot doesn't work which is critical
                                          by Neddsme
                                          Hie.
                                          I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
                                          Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
                                          I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
                                          I managed to run Windows troubleshooting and...
                                          02-04-2022, 05:57 AM
                                        • Max029
                                          Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
                                          by Max029
                                          I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
                                          I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
                                          TY,
                                          08-18-2024, 08:28 PM
