speaking of car battery chargers...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    I suspect someday these car battery chargers will become as obsolete as vacuum tubes (since everyone would be driving electric cars that require power inputs rated in the kilowatts), but for now they still have their use.
    Traditionally chargers are big heavy transformers with diodes...a fairly dumb device. I still have one. However I suspect, just like wall warts, people are all switching to... lightweight switching power supplies.
    I recall seeing at WallyWorld they no longer have a line frequency transformer battery charger, and all were SMPS supplies now... are anyone still selling old fashioned transformer chargers?
    How about those starter/charger "50A 100A 200A" supplies designed to boost starting as well?
    • 31144
    Re: speaking of car battery chargers...
    they wont be obsolete because 12v batteries are also used on generators, plant equipment such as compressors etc and loads of other stuff.
    • diif
      • Feb 2014
      • 6978
      • England
      I have one of the lithium jump packs. Powerful enough to start a completely dead 3L V6 Touareg. It also has USB and adjustable voltages for charging/powering a laptop.
        Even elecric cars have 12v lead acid batteries.
        https://www.plugincars.com/why-do-el...er-129118.html
        Even TESLA uses lead acid batteries :
        https://forums.tesla.com/forum/forum...ithout-warning
        https://forums.tesla.com/forum/forum...r-start-my-car
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Don't tell me these aren't charged by the main pack...
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            But are they all SMPS now?
              • Jul 2011
              • 6057
              The ones I seen that have no real weight to them are for sure a SMPS board
              • Curious.George
                • Nov 2011
                • 2305
                • Unknown
                For some years, now, there has been a push to move to 48V systems in cars -- mainly to cut down on wire gauge (without also needing dramatically costlier semiconductors). Imagine the turbocharger being electrically driven (instead of off the camshaft).
                Though I still think they plan on retaining a 12V bus for things like interior lighting, instrumentation, etc.
                • petehall347
                  • Jan 2015
                  • 4430
                  • United Kingdom
                  turbo runs off exhaust gases
                  • Curious.George
                    • Nov 2011
                    • 2305
                    • Unknown
                    Depends on the design of the turbocharger.
                    A friend makes them (after-market) in his tool-and-die shop gearing up off the crankshaft so he can get it up to speed at relatively low RPMs (you have power despite revs). And, easy to retrofit to almost any vehicle.
                    The advantage of an *electric* turbocharger is you can get it up to speed before the engine is doing anything!
                      • 31144
                      https://www.youtube.com/watch?v=7a_J2X88fSE
                      there;s one
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • mkdj
                        ASUS X571 no power : battery issue?
                        by mkdj
                        Mark and model: ASUS X571
                        Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                        Tests already made:
                        - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                        - I have removed...
                        07-14-2025, 09:16 AM
                      • techfreak9356
                        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                        by techfreak9356
                        I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                        09-14-2023, 11:10 PM
                        ISL88739AHRZ ISL88739 Laptop Battery Charger Datasheet
                        The ISL88739 & ISL88739AHRZ are a highly versatile combo battery charger
                        configurable for operating as either a Hybrid Power Boost (HPB)
                        charger or a Narrow VDC (NVDC) charger, supporting 2-, 3-, or
                        4-cell batteries. Both configurations allow the battery to work with
                        the adapter together to supply the system load when it exceeds
                        the adapter capability, referred to as system Turbo mode. HPB
                        charger configuration reverse-boosts battery energy to the system
                        bus to help the adapter provide the system power in Turbo mode.
                        NVDC charger configuration...
                        11-05-2024, 03:28 PM
                      • ferah831208
                        Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                        by ferah831208
                        Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                        03-18-2025, 01:18 AM
