Can i test MLCC caps with multimeter?
  • Gasvan
    • Feb 2020
    • 17
    Would i be testing them in ohms
    • 31259
    Re: Can i test MLCC caps with multimeter?
    yes, and capacitance.
    but mostly just looking to see if they are shorted.
    • Gasvan
      • Feb 2020
      • 17
      Ty stj.. i have tested some that start at -13 ohms then start climbing to 500 900 ohms that normal
      • petehall347
        • Jan 2015
        • 4445
        • United Kingdom
        swap meter leads over and try again
          The cap may also be connected in parallel with caps, true test for capacitance will be testing off the board.
          • Gasvan
            • Feb 2020
            • 17
            Okay ty for the feedback very appreciated
            • Gasvan
              • Feb 2020
              • 17
              Hi everyone been testing the caps on the board between lcd and tcon board at 200k all measure around 200k almost but 2 of them that are close to the ribbon cable near tcon only measuring 2.2k the small one i circled on the right and the one circled on the left. Weird thing is that when i disconnect the ribbons coming from the tcon there values start going up to 200k like the others. What can be the problem?
              • R_J
                • Jun 2012
                • 9607
                All that means is there are other components on the t-con that are in parallel with those caps. this is common.
                You ask: "What can be the problem?" maybe tell US what the unit is and the problem you are trying to repair.
                  https://www.badcaps.net/forum/showthread.php?t=82657
                  OP never tell us the make or model of the unit working on, no pictures of the screenshot, and instead of doing the follow-up OP makes this new thread instead.
                  • Gasvan
                    • Feb 2020
                    • 17
                    Its a samsung un60f7100 this is what my screen looks like when hooked up to hdmi every thing is red and laggy faded
                    • Gasvan
                      • Feb 2020
                      • 17
                      Also bud this is my original post that i bumped three times with no replies my bad for opening other threads https://www.badcaps.net/forum/showthread.php?t=82502
                      • Gasvan
                        • Feb 2020
                        • 17
                        Also i changed the tcon with no change
