LG 43UK6300 - Audio & Backlight, but no Video
  • arbitarytwist
    • Nov 2016
    • 31
    I have a LG 43UK6300BUB that has Audo and Backlight.
    I am no TV expert, but have done some troubleshooting on TV's in the past.
    When i turn the TV on, i can hear audio and the backlight turns on, but there is no picture. Most of the trouble shooting videos i have seen, have a seperate main and T-Con board, but it seems like on this unit, the T-CON and Main board are the same.
    I have checked the voltages on the connector from the Power Supply and i seem to be getting 13V, 3V & 2V to the Main board. I tried disconnecting one panel cables at a time and still no video on either half of the TV.
    I haven't found anything obvious, but was trying to check the voltage to the display, but don't see any test ports, so would appreciate some help in troubleshooting.
    This TV is about 16 months old with a manufacture date of 08/2018.
    I have attached some pictures for reference.
  • arbitarytwist
    • Nov 2016
    • 31
    Re: LG 43UK6300 - Audio & Backlight, but no Video
    OK did some more looking around and seems like a burnt Transistor. I wasn't that pronounced, as in the original pics i posted, but i figured i try the oven bake and it made it more obvious. The behavior is the same as before the bake in.
    I have attached some closeup pics (before over bake as seen in Pic #2 in original post).
    How would i go about finding what the transistor and perhaps replace it. The two resistors above it when measured are around 70 Ohm each although there is some discoloration on one of them perhaps from the burnt transistor.
    The part # for this mother board is EBU64688103 and wondering if i use EBU64688102, will that work, or would that be a different firmware ?
    The complete model # for this TV is 43UK6300BUB.
      I would remove that Transistor and then check the resistance between Ground against all 3 empty pads of that Transistor to see if any one of them shows <50 Ohms.
      If not then put the cables between the main board and the LCD panel back in place and recheck the resistance again to see what it shows on all 3 pads.
      We want to make it is not short circuit in the LCD panel that causes the Transistor to burnt out.
      • arbitarytwist
        • Nov 2016
        • 31
        So i took some measurements with panel cables disconnected to ground and am getting 30 KOhm, 50 KOhm and 80 Ohms on the emitter (leg by the R1104). With the panel cables hooked up, there isn't much change.
        • arbitarytwist
          • Nov 2016
          • 31
          With the postage values do you concur there is no short ? How would I go about finding a replacement transistor. Can't find any part# on the old one.
          Is there anything else I could do to be 100% sure it's not the panel.
          • arbitarytwist
            • Nov 2016
            • 31
            So i did a bit more digging and following are the voltage readings i got
            OFF (V) ON (V)
            B 7.8V 10.5V
            E 7.8V 13 V
            C 0V 0V (No Transistor in Place)
            This makes me think its a PNP transistor. I am wondering what i can use as a transistor to make this work.
            • sintv
              • Feb 2015
              • 37
              • scotland
              Disconnect one of the screen cables and see what happens. Iv just scrapped a slightly older LG although it had a Tcon board. Symptom was no video but backlights and sound ok. When I removed one cable, picture came on half the screen.
              • arbitarytwist
                • Nov 2016
                • 31
                I tried that already. Makes no difference.
                • Jay Son
                  • Dec 2020
                  • 2
                  I have the same TV, I have the same problem.
                  I have sound, backlight, but no picture at all...I tried unplugging half the screen at a time as well, no change. I don't see anything physically wrong, how and where do I start?
                  • Hamie
                    • Apr 2014
                    • 1383
                    Don't bake your motherboard would be the first bit of advice.
                    Take a picture of the tv with the back cover removed so we can see how it connects to the screen.
                    • Hamie
                      • Apr 2014
                      • 1383
                      If your model doesn't use a tcon then the old method of unplugging half the screen may not work.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4301
                        • Italy - Milan
                        There is always a tcon in a lcd, here it is integrated to the main board even if i see too few chips near the dc dc section, so i ask a photo of the back of the mainboard. Silkscreens must be readable..
                        • Jay Son
                          • Dec 2020
                          • 2
                          Lol, I would never place my electronics in the oven 😂
                          My Tcon is integrated into my main board
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4301
                            • Italy - Milan
                            It's incredibile, the tcon part is almost invisible, i'm wondering where electronics wants to go an can go, but this smells to me like more unreliability... anyway i guess the fault is tcon, time to search for testpoints and the same old tipical tensions, unfortunately i see no named testpoints so i must edit the picture but i'm at hospital , i can't for now... but maybe between some days or a week.. who knows?...
                            • sordids999
                              • May 2013
                              • 2149
                              • uk
                              Did you manage to find the fault with this tv ?
                              • alfatv
                                • Sep 2020
                                • 353
                                I had similar problem, you can try scotch tape method. Obviously, burnt part needs to be replaced. Mainboards for these are cheap however.
                                • lcdrepair
                                  • Nov 2011
                                  • 3
                                  I just fixed one of these exact sets. The tcon is tab bonded to the lcd panel. I pulled one side from the mainboard . Turned on and same problem. Reconnected ribbon pulled other side and got half screen working perfect other half white. I used tape method. Scotch tape Covered 6 pins starting from pin1 on the ribbon that causes whole screen to blank. The whole screen came up looking fine. Is trial and error covering the right pins. Something is obviously failed and tape has bypassed issue for now lets see how long it lasts.
                                  • hopkok
                                    • Oct 2014
                                    • 178
                                    • Slovakia
                                    Hi, I have two TVs 43UK6300 and both have the same problem (sound,backlight, no picture), I did not find anything burned under scope, so no guess is, panel fault.
                                    • alfatv
                                      • Sep 2020
                                      • 353
                                      Did you read posts 16 and 17?
                                      • whatusername
                                        • Dec 2013
                                        • 456
                                        Why would you stop reporting on this with so many people having the same issue and no resolve as of yet. I have a 49sk8000 same exact issue. I replaced the main board and it worked for about 2 hours then died again same issue as before. Since then I have tried 3 more boards and a set of lvds cables and I still have the blank screen with backlight and sound. Is it gonna be the panel? Tv isn't even 2 years old yet
                                        • samson7point1@yahoo.com
                                          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                          by samson7point1@yahoo.com
                                          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                          The player processes the audio signal using two different reference frequencies. The "R"...
                                          04-30-2024, 11:22 AM
                                        • SolarFlare
                                          Mi TV 4 Pro-Samsung Panel LSC550FN20 - Video problem, backlight and Audio works fine.
                                          by SolarFlare
                                          My barely 3 year old TV has stopped displaying video, although the video output comes for a few seconds after turning ON which displays the manufacturers logo then shows the home screen (all this with some blue flicker) then the video goes blank and the screen is dark blue with the backlight on. The audio output works perfectly and the TV also takes in voice commands(smart TV).
                                          The TCON board has the following Chips -
                                          Samsung VTU63A0
                                          RT6939 - 2nos.
                                          and all these chips are getting real hot within a minute, I dont know if this is normal....
                                          06-26-2022, 08:58 AM
                                        • Max514
                                          Samsung UN55H8000 sound but no backlight no video
                                          by Max514
                                          Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                                          The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                                          I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                                          • Unplugging the main board cable at the power supply >>> backlights came on.
                                          • BLU_ON signal from the
                                          04-14-2022, 10:34 AM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
