Dell 23" monitor model ST2310f inverter fault
  • angelos
    • Dec 2012
    • 562
    • South Africa
    Hi guys,
    I got in this set and i need some advice. There is an IC on a small upright board that solders into the power supply that drives the ballast transformer. The chip is marked AO3436 and has the shape of a rectangular 8 pin SMD I C. The chip is two mosfet transistors in one ic package. I get no info on this chip and neither a schematic online. I am not closeby to take photos because at that time i gave up trying to fix it. Does anybody in the forum know what i am talking about and can advise me on how to proceed. Its only a replacement chip that i need or maybe configure two n-channel mosfets to do the work.
    Regards
    Angelos
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • ed1i
    Dell Inspion 7610 bios chip
    by ed1i
    Hello, I'm looking for bios chip on the motherboard on Dell Inspiron 7610. Server tag: CS4MDL3. I found on the back on the motherboard chip named: Winbond 25Q256JVEQ. Is it the right bios chip for this motherboard? I need to flash new bios on the chip, because it's stuck in infinity reboots. Is it possible this chip to be read AsProgrammer 25Q256JV option and ch341a programmer?...
    01-16-2025, 02:14 PM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • al_b0sni
    Dell Optiplex 5000 8fc8 with chip W25Q128JVSN
    by al_b0sni
    Hey, i bought a Dell Optiplex 5000 8fc8 with chip W25Q128JVSN.
    I also used the CH341A programmer but my usb cable (i didnt attach it directly into the pc, i used a cable between) was corrupted. So i made a dump. Then i removed the password but unfortunately the dump had a loose contact so it was corrupted. And i've also overwrited the chip and now i dont have any dump anymore.
    Can someone help me? I am stuck since hours and i cannot find any bin file anywhere.
    I tried to extract the EXE for BIOS installation from dell and also the rcv file but i didn't manage to do that....
    06-18-2025, 03:42 PM
    Common SPI bios chip programming Questions and Answers
    by SMDFlea
    Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
    A: If you can`t read from it how do you expect to write to it ?.
    Q: Why is my bios chip unreadable ?.
    A: The programmer is faulty or has a worn or broken zif socket.
    The USB cable is frayed,connector pins worn or some other physical damage.
    Not enough amperage or voltage to power the programmer properly.
    Bad...
    09-02-2021, 04:40 PM
