mec 16xx dump with info block
  • superhansi
    • Dec 2019
    • 4
    • VAE
    anyone can share a (256kb) MEC dump with info block? (containing SER#,CON#,USR#...) or share the SVP offset (e.g. for DXE mapped its 0x1F400)? With SVP would be great.
    thanks
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: mec 16xx dump with info block
    If you want to unlock lenovo, use the patch method instead.
    • superhansi
      • Dec 2019
      • 4
      • VAE
      doesnt work on t490 and above
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        Okay, thats where you should have started sadly I have no information on what you asked.
        I think there is a checksum aswell. So if you want to delete SVP, got to consider that aswell. But since I have not modified mec-s, I am not sure if it is important or even true
        Anyway, good luck with trying and let us know how it goes.
        • superhansi
          • Dec 2019
          • 4
          • VAE
          i only need a dump with this block, e.g. v**fix has but i dont wanna buy it...
          FYI: erasing+rewriting MEC to get rid of SVP works like a charm, unfortunately UUID,SN and such are "lost" due to the fact that this info block seems to be read protected in mec1663, with the offsets avail i could skip this block during erase/write and then I wouldnt need to rewrite it... so any dump should do thus i didnt mention T490 and later
          • xmasterboss
            • Apr 2014
            • 36
            • Romania
            Hy. I also have a T490s. Did you remove the chip or connected the programmer via wires to the motherboard? I can't find schematic or where the pins are. Also, did you succeed in removing SVP ?
            • Aditya11ttt
              Adi
              • Feb 2019
              • 192
              • India
              try this try to find jtag1 connector name on the board only space will be there without connector !!
              • xmasterboss
                • Apr 2014
                • 36
                • Romania
                Thanks. Did you find the MEC Dump you were looking for? even if it's for sale i will buy and share it with you.
                • zomi
                  • Nov 2011
                  • 513
                  On these if you replace the mec ic will that solve the password ?
                  remove ic and put another one in ?
                  Is that confirmed solution ?
                  • iTec
                    • Oct 2017
                    • 32
                    Do you know which or where is the RST#? It's a T490 with the MEC1663
                    Any help is really appreciated.
                    • black0hackers
                      • Jul 2020
                      • 369
                      Where is point to connect?
                      picture add of T490S
                      • AAAC
                        • Jan 2020
                        • 459
                        • Mexico
                        @black0hackers
                        Upload another picture of complete motherboard, as most of the JTAG signals may be already in a connector pads.
                        • So the JTAG signal wires will need to be soldered to this connector pads.
                        • You will need to move a very tiny PULL-UP resistor and make it a PULL-DOWN resistor to enable JTAG interface.
                        • Then you will need to locate RST# signal somewhere around MECxxxx chip by looking at schematic for this T490S, or by looking at another model schematic that uses the same MECxxxx chip part number (although I've read that this signal is not needed, someone with more JTAG experience may confirm/deny this).
                        • JOHNLAG7
                          • Nov 2014
                          • 20
                          • Greece
                          There is a photo t490 jtag1 and pins ,can someone draw the connection ?
                          • RethoricalCheese
                            • Mar 2013
                            • 1519
                            • Estonia
                            Looks like JTAG reset resistor is marked in red box. Move the resistor next to that capacitor on the empty pads.
                            I will test it tomorrow.
                            • RethoricalCheese
                              • Mar 2013
                              • 1519
                              • Estonia
                              The resistor in my last picture was indeed correct. I can read/write MEC now.
                              The problem is, looks like my SAS JIG (which doesnt have MEC1663 in support list) is not able to clear the write-only area for some reason. What programmer should be used?
                                • 22236
                                A Vertyanov jig or SVOD3
                                • AAAC
                                  • Jan 2020
                                  • 459
                                  • Mexico
                                  @RethoricalCheese
                                  In your last post you mention you can read/write MEC now, but you describe your problem as is not able to clear the write-only area... have you tried to disconnect all sources of energy for 2-3 minutes? seems like this area is temporarily copied to volatile memory too (ram), so removing energy for a couple of minutes will do the trick.
                                  After this you will have to use Lenovo UEFI Maintenance utility to write Model Number, Serial Number, TYPE and other data for ThinkPad to be left as it was before programming MEC chip.
                                  • RethoricalCheese
                                    • Mar 2013
                                    • 1519
                                    • Estonia
                                    Thanks, will try. Did not try removing power for more than a few seconds.
                                    • keczuk
                                      • Dec 2019
                                      • 84
                                      • WWW
                                      Hi
                                      I have question. I use svod3 for program this mec and when i read few times mec dump in hxd i see all dump are different. When i try write my clean ec dump i have error in veryfiication. Any idea how solve of my problem ?
                                      • AAAC
                                        • Jan 2020
                                        • 459
                                        • Mexico
                                        @keczuk
                                        Upload a picture of your setup. Have you added PULL-UP resistors to JTAG signals.
                                        At the time we did this one we couldn't find a schematic for T490, but X1 Carbon 6th Gen (T480s and others) have same MEC1663 EC/KBC chip so we used them as reference.
                                        • mkdj
                                          ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                                          by mkdj
                                          Dear all,
                                          I have a ASUS ZenBook UX480F with the following symptoms:
                                          I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                                          I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                                          10-19-2025, 04:41 AM
                                        • Habble7
                                          I need a BIOS dump for the Samsung S49CG934SU monitor
                                          by Habble7
                                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                          Suspected Cause:
                                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Mephysis
                                          DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                          by Mephysis
                                          Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                          I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                          03-27-2025, 02:34 AM
                                        • Citymin
                                          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                                          by Citymin
                                          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                                          The charging red LED lights up, but the charging screen doesn't show any indication.
                                          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                                          (I've tried removing the battery and resetting the device, but the issue persists.)
                                          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                                          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • hyperwood
                                          [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                          by hyperwood
                                          Hi everyone,
                                          I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                          The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                          I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                          āœ… What I need:
                                          • A working 2MB BIOS dump
                                          • Matching NM-E471 Rev. 2.0, e.g. JY575
                                          06-25-2025, 02:28 PM
