OptiPlex 7450 All In One bios
  • lasantha
    • Jul 2014
    • 1
    • srilanka
    helo gays
    i need dell optiplex OptiPlex 7450 All In One bios
    ples hep me
    • 21836
    Re: OptiPlex 7450 All In One bios
    Post your bios backup here .
    • appie1206
      • Oct 2016
      • 125
      • netherlands
      OptiPlex 7450 All-In-One bios file Needed
      Hello Friends
      Have corrupted biosfile can someone help me with a new one?
      Ive added the old ec and bios file
      Servicetag: FW1GGQ2
      Thanks in advance
      • appie1206
        • Oct 2016
        • 125
        • netherlands
        Hi smdflea can u help me with this one?
        • hoaca388
          Badcaps
          • Jan 2022
          • 12314
          Re: OptiPlex 7450 All-In-One bios file Needed
          Originally posted by appie1206
          Hello Friends
          Servicetag: FW1GGQ2
          Thanks in advance
          Service Tag: FW1GGQ2
          • appie1206
            • Oct 2016
            • 125
            • netherlands
            why 2 files? do i need to combine it?
            • hoaca388
              Badcaps
              • Jan 2022
              • 12314
              No, your device only matches one of those two files.
              • appie1206
                • Oct 2016
                • 125
                • netherlands
                It worked thanks
                • samian
                  • May 2023
                  • 4
                  • Poland
                  DELL OptiPlex 7450 All-In-One, need bios, clean ME
                  I've got a problem with my Dell AIO 7450. I'm stuck on a screen with error message: (A7) Me FW Downgrade Request MeSpiLock Failed. After a few seconds computer reboots again. I can only enter bios or boot menu. I can't even boot from USB, nothing.
                  I've tried all methods from Dell site, flashing bios through recovery (CTRL + ESC method) with many bioses versions but nothing helped.
                  I searched for ways to solve this problem and found a similar problem on the forum, which was solved by creating a bios with clean ME.
                  So I wanted to try to prepare such a bios by myself (with ME Firmware Cleaning Guide) but I can't get the bin from Dell exe bios. I've tried all the methods (python scripts, Dell_PFS_Extract, Dell_hdr, Dell_Image_Extract v2) and they only works on older dell bioses.
                  So, I am begging for help, please prepare a bios with me cleaned.
                  The original bios is in the attachment.
                  I can only flash bios with CTRL+ESC method with rcv file (I think it's an exe bios file but with different extension).
                  Regards
                    • 21836
                    Re: DELL OptiPlex 7450 All-In-One, need bios, clean ME
                    PFS Extract 4.9 -> https://www.badcaps.net/forum/showpo...95&postcount=6
                    • samian
                      • May 2023
                      • 4
                      • Poland
                      Thx SMDFlea,
                      PFS Extract 4.9 did the job, but there are many bin files in the unpacked folder, and this structure looks like the files that result from drag&drop a single bin file into the FIT. How can I load all these files into FIT so that I can build a new BIOS/EXE file after replacing the ME?
                        • 21836
                        Thx SMDFlea,
                        You might be able to bypass the ME error message by using the MECLR1 jumper,if the motherboard has one https://www.dell.com/community/Inspi...50/m-p/8323222 .If you can do that and boot into windows you can run the bios update exe (not the rcv,it doesn`t flash the ME firmware) .If you can`t do that then your only option is to buy an SPI programmer to make a backup for repairing or take it to a repair shop.
                        • samian
                          • May 2023
                          • 4
                          • Poland
                          Ok, but when I'm flashing through recovery flash mode (CTRL+ESC), on the last stage I get error: ME Firmware Update Failed. All previous stages are ok. Beacuse of that, I was wondering if there is any way to rebuild this RCV file.
                          • cravel
                            • Nov 2022
                            • 31
                            • philippines
                            good afternoon
                            please help me fix this issue
                            service tag 82DS9M2
                            • yooshimura
                              • Mar 2021
                              • 5
                              • morocco
                              need optiplex 7450 AIO BIOS . SERVICE TAG BWBJ902
                              • Reda123456
                                hi
                                • Jan 2022
                                • 89
                                • iraq
                                Hello people of badcaps, I got dell OptiPlex 7450 aio that shows error (A7) Me FW Downgrade Request MeSpiLock Failed for seconds and then the pc reboots and nothing else, i need urgent help the serial number is 4GPWCK2
                                  SMDFlea commented
                                  Editing a comment
                                  thread merged
                              • Reda123456
                                hi
                                • Jan 2022
                                • 89
                                • iraq
                                this is dump bios
                                • zmezm1995`
                                  • Nov 2020
                                  • 99
                                  • iraq
                                  hi need remove bios password from my pc dell optiplex OptiPlex 7450 All In One , what should i upload main or ec plz help
                                    SMDFlea commented
                                    Editing a comment
                                    upload main bios
                                  • 21836
                                  Originally posted by Reda123456
                                  this is dump bios
                                  Have you tried the bios at post 5
                                  • zmezm1995`
                                    • Nov 2020
                                    • 99
                                    • iraq
                                    Yes, I tried the same thing
                                    and this my dump
                                    • mrrubik
                                      Dell Optiplex 7010 micro bad BIOS flash?
                                      by mrrubik
                                      Hi folks,
                                      I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                      After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                      Steps I took:
                                      1. Read BIOS with CH341a, verified hash twice
                                      2. Patched
                                      12-23-2024, 04:11 PM
                                    • macabook
                                      by macabook
                                      🧩 Initial Issue
                                      07-24-2025, 02:17 PM
                                    • Vesko356
                                      by Vesko356
                                      08-11-2023, 03:27 AM
                                    • PicFren
                                      Optiplex 3070 Micro bios
                                      by PicFren
                                      Dell Optiplex 3070
                                      As explained in my introduction, after many years I finally bricked one computer updating the bios (power shortage).
                                      Brand : Dell
                                      Model : Optiplex 3070 Micro
                                      Motherboard : 02N3WF
                                      Service Tag : ****
                                      Chip BIOS model : MX25L25673GMI-08G
                                      I'm new at flashing bios directly so I bought a cheap CH341 dongle.
                                      I tried it on an old computer and I successfully read the bios from a MX25L128Z3F chip with the SOP8 Clip.
                                      The I tried to read the Optiplex 3070 chip BIOS to make a backup....
                                      10-19-2023, 11:06 AM
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
