I need system driver for 8200 elite
    • Jul 2011
    • 6070
    HP website is screw up you can not find drivers windows 7 pro
    I know that Microsoft has stopped supporting as of 2-20-20
    HP website has taken them down already really
    I need to have the drivers so I can use this computer system
    Can anyone help with this problem
  • R_J
    • Jun 2012
    • 9633
    Re: I need system driver for 8200 elite
    I found them no problem: https://support.hp.com/ca-en/drivers...tor-pc/5037931
    HP site detects your OS, so you may need to select "Choose a different OS"
    You did'nt specify which elite 8200, so I picked the sff model, or windows 32 or 64 bit, this link is for windows 7 64bit
    • diif
      • Feb 2014
      • 6978
      • England
      Working here also. https://support.hp.com/gb-en/drivers...wer-pc/5037940 XP drivers are still available on their site if you want them.
        • Jul 2011
        • 6070
        I have to download the drivers to usb drive to install them because after I load Windows 7 pro Ethernet card has no device driver and can connect to internet
        It use to be that you could download the device driver from there website but it look like you can not do this anymore
        • R_J
          • Jun 2012
          • 9633
          It is quite normal for the OS install not to have the ethernet driver, I always use another pc to download it onto a usb stick before installing.
          There are 6 different drivers available. which model do you have? and which chipset does it use? intel,broadcom?
          They make windows 7 pro in 2 versions 32 bit and 64 bit, you need to know that also to get the correct driver.
          If you are having trouble downloading it, provide the information and I can download and post it here
            • Jul 2011
            • 6070
            I was able to finally able to get all of files the problem was with a long script error every time
            I would try there site but finally I was able get it to work
            • brethin
              • Dec 2008
              • 1907
              I have Windows 7 HP Restore Cds for the 8200, screw all that downloading.
                • Jul 2011
                • 6070
                Solved I need system driver for 8200 elite
                I got this computer where I work when they did a computer upgrade with out the hard drive ( recapped power supply new hard drive windows 7 pro installed ) Will not be hook to the internet unless I need a software update on my battery tester and even I might think twice even then
                I have this 8200 elite computer up and running with all drivers installed and my battery tester software installed and up and working now to put this cover back on the computer and put it in my office where I do my battery testing here is the web link for this project
                I have a partition on this computer just for testing results and the program itself I have a 1 TB hard drive .05 TB for the battery tester storage space do not think I will run of space any time soon
                https://www.badcaps.net/forum/showth...t=82224&page=3
                So I can STOP using this laptop computer that runs Windows 8.1 which drives me crazy with the app screen wanting to go to this screen with touch pad on the computer if I were to use a real mouse I would loose one USB port which I would need all three that it has
                Where as the 8200 elite computer has 8 USB ports I still have room for the usb mouse and the three battery tester units right now I only have 2 units but I am ordering another one so that I can monitor 12 volt BMS balancing protection boards and evaluative them I have a project that I would like to work on and make a battery pack for this project and few more that I have in mind doing in the near future
                  • Jul 2011
                  • 6070
                  I just bought this set of recovery disk on EBay
                  But I have them on a USB drive for now I personally like to more than one back that works
                  • R_J
                    • Jun 2012
                    • 9633
                    You may have tried contacting HP at a bad time and they were having issues.
                      • Jul 2011
                      • 6070
                      Probably it was better this morning but it still was having long script running time but not error out
                        • Jul 2011
                        • 6070
                        Here is a picture of my setup with computer / monitor/ battery tester and battery under test
                        Oh I did have to hook this computer up to internet so it could activate the product key and once it did that I disconnected it from the internet I have no anti virus software on this computer and I want to keep this way
                        I have about 6 IBM think center desktop computers similar but I have to recap a mother board to maybe get it working ( one note all the c-mos battery are all dead in each one them
                        But I was able to find a “ NEW “ mother board from the picture on EBay it looks new so we will see if this is the case or not
                          • Jul 2011
                          • 6070
                          As said earlier
                          I got the new mother board in and one of the caps on this board is a little bolted and raised top but board looks very new but I have not had time to mess with it
                          This capacitor is right where the front fans connectors are on this board (“KMG” ) series
                          I will replace this after I get this mother board to recognize the CD rom drive and the hard drive this mother board does not do this right way for some reason which I have not figured out why yet
                            • Jul 2011
                            • 6070
                            Now the 8200 elite computer works really good and very happy with the results
                            But I could shoot the moron who setup the way the product key activation is done if you do not have internet access at the time you install the operating system they hide the dam s**t really this is crap
                            It took me a while to find the activation screen to activate it
                            Windows website is even more crap they want you upgrade to Windows 10 really this some more crap
                            • R_J
                              • Jun 2012
                              • 9633
                              You mean the activate by phone? It is'nt fun but it works, If you saved all the numbers and you can enter them later if you reinstall. Now that is activated you can make a copy of the activation and keep it in case you need to reinstall again later.
                                • Jul 2011
                                • 6070
                                No I talking about the internet activation screen is very hard to find where it was I did finally figure out where it was hiding and finally got it activated
                                Because I got the screen that you are talking about but knew that there is activation screen but I done one in a very very long time
                                • R_J
                                  • Jun 2012
                                  • 9633
                                  If you right click Computer, and choose Properties, it should be on that screen "Change product key"
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5045
                                    • US
                                    sucks it only supports sandy bridge
                                      • Jul 2011
                                      • 6070
                                      Update on key product key activation
                                      This was a pain in the ass to find the activation screen
                                      But I did find it after some real searching
                                      Now I have everything working the was it suppose to work
                                        HP Compaq Elite 8200 Compaq Elite 8200 i5-2500 Specification for Upgrade or Repair
                                        This specification for the HP Compaq Elite 8200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite 8200 boardview and Compaq Elite 8200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-12-2024, 03:36 PM
                                        HP Compaq Elite 8200 USDT Compaq Elite 8200 i5-2400S Specification for Upgrade or Repair
                                        This specification for the HP Compaq Elite 8200 USDT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite 8200 USDT boardview and Compaq Elite 8200 USDT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-12-2024, 03:28 PM
                                        HP Compaq Elite 8200 SFF Compaq Elite 8200 i5-2400 Specification for Upgrade or Repair
                                        This specification for the HP Compaq Elite 8200 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite 8200 SFF boardview and Compaq Elite 8200 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        HP Compaq Elite 8200 A2K36ET Compaq Elite 8200 i3-2120 Specification for Upgrade or Repair
                                        This specification for the HP Compaq Elite 8200 A2K36ET can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite 8200 A2K36ET boardview and Compaq Elite 8200 A2K36ET schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
