JVC EM55FT everything ok but cannot find any channels
  • captainKKK
    • Sep 2018
    • 287
    Have done a reset. Can get the menu and when auto scanning for OTA channels is finds none of the 45 channels that my other TVs find. What to check first?
  • nomoresonys
    • 12116
    • U.S.
    Re: JVC EM55FT everything ok but cannot find any channels
    Did you try firmware update and or factory reset?
    • budwich
      • Jul 2015
      • 3097
      have you selected "antenna mode" in the menu (as opposed to cable).
      • captainKKK
        • Sep 2018
        • 287
        Thanks for your replies. I have reset the TV. Then scanned for channels using the "antenna" mode which is an outside antenna that works well for all my TVS. I have NOT done a firmware update b/c my ordered JVC remote has not arrived yet. I would love for this dumb TV to come back to life. Will update when the remote arrives. I may hook the computer to one of its HDMI and see what happens
        • budwich
          • Jul 2015
          • 3097
          that would be a good idea especially if you don't know the tv's history. Just to be sure we understand, can you post a picture of the menu that you used to set "antenna"?
          • captainKKK
            • Sep 2018
            • 287
            Got the remote control for it and same issue, no channels found. See pics. There are two different ways to scan for channels, using the attached outdoor OTA cable to the back of this TV, and specifying ANTENNA mode....neither find any channels.
            • budwich
              • Jul 2015
              • 3097
              have you got any "base video sources" (ie. cable box, vcr, video camera) that you can try inputting? do you get a different response if you choose "cable"? have you checked the input connector with a meter to see if is not shorted?
              • captainKKK
                • Sep 2018
                • 287
                Thx Budwich. I did try scanning using the "cable" and still no channels found. I did plug an active HDMI computer into two of its HDMI ports and got no response. No. I have not checked grd on the input, but will do so in the morning. I guess I'll have to crack this open and take a look.......?
                • budwich
                  • Jul 2015
                  • 3097
                  hold it... you plugged in a hdmi cable (and input a displayable signal ... dvd etc) and do not get a picture?
                  • captainKKK
                    • Sep 2018
                    • 287
                    This TV was NOT recognized by my computer, and thus did not show picture, so maybe the HDMI ports on the TV are bad? I am going to try other inputs in a bit and a different computer or output from another HDMI device.
                    • budwich
                      • Jul 2015
                      • 3097
                      ah.... it appears that your problem is wider than "no channels".... you likely have a significant main board problem that is impacting all inputs on that board. You should probably start checking voltages on the main board to see if any are missing.
                      Having said that, using an hdmi from a computer isn't the best way to test ports. This is because computers can easily set a resolution that is NOT supported by an external display and result in no picture. Get a cheap dvd player or otherwise to confirm operation of hdmi.
                      • captainKKK
                        • Sep 2018
                        • 287
                        thanks, a work in progress
                        • captainKKK
                          • Sep 2018
                          • 287
                          The Antenna connector center pin is not grounded. The PS has exactly the correct output voltage values. The PS main cap voltage is 320vdc, cap rated at 450. The main board's central processor is warm. All the caps on the PS and main boards appear physically perfect. BLs On. Menu display perfect. Music Menu displays full screen image. DVD play plugged into all three HDMI ports do not display anything. Cannot find firmware. Cannot get into the factory mode. Have done reset from the menu. Channels scanned finds no channels. Advice now?
                          • budwich
                            • Jul 2015
                            • 3097
                            well now you have "narrowed down" the problem.... :-) It is likely a problem with the main board which houses the inputs and conversions. The menus are generated internally and don't go thru much / any signal conversion / capture and the display basically works. You need to start checking voltages in and around the hdmi area especially 5v which is used in the protocol. When you try to select an hdmi input, what does the screen display? You can / should trace voltages coming from the PS to the main and into the main.
                            although hard to tell from the pictures, there appears to be some bulging of tops on some of the caps on the main board.... maybe.
                            • captainKKK
                              • Sep 2018
                              • 287
                              When I have a device plugged to the HDMI port and change to that port it says "Checking Signal" and then "No signal". I will check the top and bottom of the caps again. Too bad I cannot find any historical common faults on this model. Also, I talked to the previous owner and this was used as a kids plaything, plugging and unplugging lots of HDMI toys, so I am going to have a close look for a damaged HDMI connector..
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8117
                                figures... another MSD main IC.
                                • captainKKK
                                  • Sep 2018
                                  • 287
                                  Your are right. see pic and very small bump above the third row of letters, above the 1. What causes this, lightning strike or is this a high probability of more component failures on the tcon and PS boards? Can I replace the MSD?
                                  Can I use a different model board like I have a bad JVC mainboard JVC 3655-0852-0150 (3B). Can I use a JVC 3655-0852-0395 and or JVC 3655-0852-0395R, and or JVC 3655-0852-0150R replacement (R=roku?)
                                  • nomoresonys
                                    • 12116
                                    • U.S.
                                    • Vesko356
                                      by Vesko356
                                      08-11-2023, 03:27 AM
                                    • Sus256
                                      HISENSE 65E7KQ PRO - no boot
                                      by Sus256
                                      Hi all!
                                      HISENSE 65E7KQ PRO
                                      RSAG7.820.13512 - chassis
                                      MT9618BAATAB - cpu
                                      RSAG7.820.12059 - power
                                      HD650Y3U77 - panel
                                      KLM8G1GETF - emmc
                                      The TV does not turn on, the standby indicator is on. All voltages are present.
                                      Emms is dead. Not readable, not detected.
                                      Replaced emmc.
                                      But with another dump there is no launch
                                      Terminal log
                                      UART
                                      AC_ON
                                      RPMB key is not yet programmed
                                      HASH1_VERSION=0x00000000 64bit
                                      E-B
                                      FDE enabled
                                      layout pattern onebin by SAR7,0...
                                      06-01-2025, 02:11 AM
                                    • corrize
                                      Where to find a very small fpc connector 0.3mm between 2 pins ?
                                      by corrize
                                      Hello, I search this connector (oxydated).
                                      It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                                      I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                                      I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                                      Do you know how to find this connector please ? What is the exact name for find it ?
                                      08-06-2024, 05:25 PM
                                      Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
                                      by sam_sam_sam
                                      This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
                                      Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
                                      07-07-2024, 02:34 PM
                                    • r2digital
                                      Harmon Kardon AVR340 no sound on 4 channels
                                      by r2digital
                                      Hello, i had this amp sitting in the closet knowing that none of the channels were working. After taking it all apart i found 4 bulging main filter caps so i went ahead and replaced those with low ESR kmet caps. However after doing this it only restored sound to Surround L, Surround R, and Center channel. The main speaker fuse on the transformer F905/F906 keeps blowing so i decided to remove all of the transistor's on those 4 channels and measure them. All transistors appear to be in good working order(turned receiver on with none of them installed and fuse still blows). Checked dual emitter resistors...
                                      03-09-2024, 01:33 PM
