Help identifying capacitor rating
  • jeffer76
    • Sep 2011
    • 76
    • US
    I need help identifying this capacitor. Voltage and rating?'
    • 31218
    Re: Help identifying capacitor rating
    107 = 10 & 7 zero's
    so 100000000 = 100uf
    16 is the maximum voltage.
    K means +-10%
    they are tantalum.
    7x5mm is package type D,X,V or W depending on height.
      Originally posted by stj
      107 = 10 & 7 zero's
      K means +-10%
      they are tantalum.
      +1, and the bar is for positive terminal for this Tantalum cap, bar for lytics cap is for Negative terminal.
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
      • Prolog
        RTX 3080 FE Identifying capacitor
        by Prolog
        Hi people, I hope this is the correct spot to post this, I'm new to the forum.
        I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
        I hope these photos make it clear which component I am referring to:
        (yes, the soldering is a bit botched from removing the blown one, I know)
        I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
        12-01-2024, 08:27 PM
      • MORETTIGIAN
        Capacitor detached from PCB – RTX 2070 Super Founders Edition
        by MORETTIGIAN
        Title:
        Description:
        During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
        I did not notice it detaching, so I am unsure of its original location on the PCB.
        Procedure performed:
        - Removed backplate
        - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
        - Reapplied thermal compound
        - Reassembled card
        Observed behavior after reassembly:
        - GPU powers on and operates normally under...
        09-18-2025, 12:14 PM
      • Ambro
        Help identifying missing smd capacitor for HP elitebook 840 g3
        by Ambro
        In an unfortunate mishap while attempting to read from the bios chip, one of the smd capacitors took flight and disappeared.
        I'm not sure how crucial this smd capacitor is, but it was a brown possibly ceramic one with no notable markings on it anywhere.
        I've attached a picture of where it's located on the board.
        Does anyone have an HP elitebook 840 g3 who might be able to aid me identifying this component. I'm not sure how crucial it is, but didn't want to risk it.
        Thank you for any help you can provide....
        09-09-2023, 06:21 PM
      • Adenitz
        Explanation of capacitor rating
        by Adenitz
        I'm reading an article about the "capacitor plaque" in early 2000s and I have found one sentence I cannot understand.
        The normal lifespan of a non-solid electrolytic capacitor of consumer quality, typically rated at 2000 h/85 °C and operating at 40 °C, is roughly 6 years. It can be more than 10 years for a 1000 h/105 °C capacitor operating at 40 °C.
        What this 2000h or 1000h means? Why 1000h capacitors have longer life span?
        12-26-2022, 12:36 AM
