How to safely handle a 75inch LCD panel ?
  • guix
    • May 2018
    • 25
    • France
    I have a Sony KD75XD8505, 75 inch edge-lit tv to repair, unfortunately one of the LED strip was damaged by liquid so I need to open it, but I'm affraid to break the panel since it's so big...
    I can do 55 or even 58 inch alone, by slowly sliding a big piece of cardboard (covered with cloth) under the panel, same for 65 inch but need another person to help.
    I've seen suction cups mounted on a rigid chassis but it's not cheap!
    What is your technique to safely move such big panels ?
  • brucetv
    • May 2015
    • 281
    • united states
    Re: How to safely handle a 75inch LCD panel ?
    I prefer to use a good set of suction cups for all sizes vs sliding anything underneath and risk scratching the back of the panel. Tolsen makes the perfect set because they give you plenty of hold power without worrying about too much suction and damaging the panel. Here in the States you can get them from shopjimmy.com ($17.49USD) per set plus shipping. Some panels will have a thin layer of adhesive two way tape holding the panel down so use a playing card to run around the edges and where there is adhesive leave the card in place so it won't re-adhere. Unlatch the suction cups once you have the panel pulled while your working on the led replacement to release the pressure and relatch when your ready to re-install. You can find some good video's on YouTube and also on shopjimmy.com on how this is done. Good luck and take your time.
    • nomoresonys
      • 12330
      • U.S.
      https://www.harborfreight.com/search?q=suction%20cup
      • nomoresonys
        • 12330
        • U.S.
        How much to ship to France is anyone's guess.
        • llonen
          • Sep 2014
          • 495
          • hampshire
          I don't have enough contiguous space in the lab to take in something that size for repair, if space was not an issue I would probably construct a flip / roll over jig.
          • brucetv
            • May 2015
            • 281
            • united states
            We had to change our backlight repair policy to see if we can safely pull the new Samsung Qled panels with the Bezeless design due to the panel being held in with adhesive strips like Sony likes to do. The minute Yuppie Scum goes to mount that Tv over his FIREPLACE with a ambient temperature about 100 degree F or more he'll see that panel adhesive give way and start bowing like this fool. When I saw that I refused the repair and ran as fast as I could. We won't do backlight repairs on any Tv that does not have a bezel to hold the panel in. Look at the angle this fool had on this Tv and with that much heat I'm surprised the panel is not sitting on his floor by now. 2 year old Tv. I feel sorry for him cause Samsung wouldn't do anything for him. I suggested to put it back on the stand and find a different location. I never recommend putting any Tv over a fireplace. But that's the way Yuppie Scum is designing these new Preppy Homes nowadays. Pitiful
            • howardc64
              LG 49UJ6500 LCD panel lighter band that goes away
              by howardc64
              49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
              Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
              02-19-2023, 12:13 AM
            • triplefour
              SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
              by triplefour
              TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
              tcon is built into mainboard.
              Only one cable goes to panel boards.
              there is a cable from one panel board to the other that links them.
              cost cutting measure that results in us having harder time to diagnose.
              removing the link to the second panel board allows TV to stay on with stable backlight but no image.
              used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
              07-28-2022, 07:59 PM
            • Storyteller12
              QN55Q60R Service Menu Panel Help
              by Storyteller12
              I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
              I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
              I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
              the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
              01-13-2024, 01:57 PM
            • maneatingmonkey
              Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
              by maneatingmonkey
              I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
              There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
              03-27-2024, 07:17 AM
            • howardc64
              Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
              by howardc64
              • Prior owner tried a replacement main board. No difference.
              • Samsung 2x red blinking standby LED = panel fault
              • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
              • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
              • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
              07-19-2025, 10:54 PM
