Asus B85-E boot time is too long
  • Aliencomputres
    • Aug 2019
    • 218
    • România
    Hy all,
    Asus B85-E Too long bios post time-aprox.15-20 sec, but booting every time.Change ram,cpu,psu.
    Bios is up to date and cell battery is brand new.
    Thx in advance.
    • 22030
    Re: Asus B85-E boot time is too long
    Do you mean the B85M-E
    • piernov
      • Jan 2016
      • 4439
      • France
      You mean 15-20 seconds before showing any image? Or when showing BIOS image? Is it everytime you shut it down/turn back on (without disconnecting from the mains) or reboot?
      Tried reset CMOS?
      Tried with nothing except PSU/RAM/CPU connected to the board, outside the chassis?
      Tried to update BIOS again even if it's up to date?
      • Aliencomputres
        • Aug 2019
        • 218
        • România
        15-20 sec before showing bios image.It is everytime when shut down or restarting.
        Reset cmos ,rewrite bios with ez flash with B85M-E BIOS 3602.
        Mainboard its on thre table and have one stick of 4gb/1600 mhz and the cpu.
        Thx.
          • 22030
          Flash this bios with your programmer, not easy flash.
          • Aliencomputres
            • Aug 2019
            • 218
            • România
            Solved.
            Flash bios with programmer.
            Thx.
            • Arnoldso
              • Nov 2020
              • 1
              • México
              Anyone has the schematic for B85M-E ?
              • robante15
                • Nov 2020
                • 62
                • El Salvador
                Thanks this BIOS helped me to solve the problem of
                "USB Device Over Current Status Detected !!"
                I know that would be more of a physical problem than BIOS, but the truth is that the ports did not have any problem, they were in good condition, also clear the CMOS and nothing, but flashing the BIOS worked and already revived the Motherboard with that.
                • throwaway327
                  Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                  by throwaway327
                  ASUS ROG Ally X - (Handheld Gaming PC)
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                  I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                  06-18-2025, 05:52 PM
                • razor_amd
                  [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
                  by razor_amd
                  With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
                  For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
                  I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
                  This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
                  12-15-2020, 07:07 PM
                • futadmytro
                  Asus g713qm-es94 stuck on boot bios problem
                  by futadmytro
                  sn^M4NRKD02753616E
                  MB- g533-6050a3250201-MB-A03
                  Stuck on boot after ROG logo, did not enter to bios
                  In flash bios , laprop boot but have video issue
                  orig bios...
                  06-25-2025, 08:07 AM
                • kenkaniff
                  HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
                  by kenkaniff
                  Product Name: HP Pro x360 Fortis 11-inch G9
                  System BIOS: U94 Ver.01.08.00 10/06/2023
                  Serial Number: 5CG31946F5
                  SKU Number: 85W05EC#AK8
                  Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
                  This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
                  I needed to remove bios password...
                  10-01-2025, 04:32 AM
                • ferah831208
                  help with bios decompose for Asus s5506ma
                  by ferah831208
                  I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
                  08-24-2025, 05:35 PM
