Window XP Product Actvation Not Working
    • Jul 2011
    • 6057
    I using this windows XP computer right now
    I am using My-Pal to get on the internet which it seem to work OK on most website
    I can not update internet explore on Microsoft website either ( I tried to install it from thumb drive but it gave a error message that it dose not support the version of internet explorer that I have )
    Which that part I do not care about one way or the other
    I guess I will have to active it by phone unless someone know another way to do this
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Window XP Product Actvation Not Working
    I just use corporate editions for any remaining XP boxes. No activation.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      • Jul 2011
      • 6057
      Where do I find a copy of this
      thanks
      • RJARRRPCGP
        • Jul 2004
        • 6304
        You got the wrong installer for Internet Explorer, very likely. Note that you can't use later than version 8. (IE8)
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
          • Jul 2011
          • 6057
          I have version 5 on it right now
          I tried install version 7 and version 8 no go with either one
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            thanks
            I can give you a copy of the media, but you'll have to scare up a VLK....they're out there, probably not too hard to find.
            Team : 49813
            Join in!!
            Team Stats
            • Curious.George
              • Nov 2011
              • 2305
              • Unknown
              Sam doesn't indicate whether it is a "beige box" or a "brand name" computer. In the latter case, hunting down XP install media from that manufacturer will usually eliminate the need for activation (I have a folder of various media that I use for machines, here).
              [This is a big advantage to sticking with mainstream hardware -- no need to EVER go on-line]
              In some cases, you have to trick the media (HP likes to try to tie their media to specific models) to running.
              You can also modify a retail ISO to convert it to a manufacturer specific issue.
              And, of course, you can always hunt down keys for XP on-line.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                You've got a point....but VLK/Corporate edition negates it all anyway....
                Just out of curiosity.....does an x86 VLK for XP work with an x64 corporate media? I don't have XP64 Corporate media, but I know there was an edition......so if I tracked down this media, would my x86 XP keys work on it?
                Team : 49813
                Join in!!
                Team Stats
                  • Jul 2011
                  • 6057
                  I have looked for a recovery disk for this computer and not found one yet
                  IBM 8183
                  • kaboom
                    "Oh, Grouchy!"
                    • Jan 2011
                    • 2507
                    Code:
                    t7jqm-cx6bd-v2ddv-qryvx-pprtb
                    (All caps)
                    "pokemon go... to hell!"
                    EOL it...
                    All style and no substance.
                    guilty,guilty,guilty,guilty!
                    guilty of being cheap-made!
                      • Jul 2011
                      • 6057
                      Originally posted by kaboom
                      Code:
                      (All caps)
                      Incorrect product key
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16958
                        If it's a corporate key, you have to install using corporate media.
                        Team : 49813
                        Join in!!
                        Team Stats
                        • R_J
                          • Jun 2012
                          • 9578
                          What version of XP, look at system properties (right click My Computer, Properties) Post the first 8 digiits under Registered to:
                          XXXXX-YYY-*******-*****
                          Just post the X & Y
                          That key provided is for Pro-SP2-VLK
                            • Jul 2011
                            • 6057
                            Originally posted by r_j
                            what version of xp, look at system properties (right click my computer, properties) post the first 8 digiits under registered to:
                            Xxxxx-yyy-*******-*****
                            just post the x & y
                            76477-oem
                            • R_J
                              • Jun 2012
                              • 9578
                              76477-oem
                              That is XP Home Royalty OEM
                              Did the PC have a label on it with the CD key?
                              • Curious.George
                                • Nov 2011
                                • 2305
                                • Unknown
                                Yes. I've never installed a VLK here (though see below) as I want the ability to expose a machine to the outside world (e.g., this one) even if I don't ever do it. Using the OEM "self-activating" media means a machine can't tattle on me as having done something "shady".
                                [The OEM media are mass produced so unlikely that the install disk for THIS machine was different from the install disk that I actually used]
                                No idea. I suspect it wouldn't. For the same reason that install media for (e.g.) Home and Pro versions aren't compatible.
                                I set up a "lab" for a local nonprofit and used VLKs for XP and Office version <mumble> -- but, those were "legally" issued by MS to the nonprofit (there is a place where you can request licenses for nonprofit use). Technically, the VLKs were authorized for 20 copies -- which I had to just make a note of as I was building the machines -- but I don't know if the machines check with each other to verify that count is never exceeded.
                                  • Jul 2011
                                  • 6057
                                  Yes but it for a Windows XP professional which I do not have a copy but there are no device drivers for this version a least I have not found any
                                  I could not find an ISO version of it any way
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5042
                                    • US
                                    IE 5 was never on XP. Are you sure you don't have windows 2000?
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16958
                                      That's what I was thinking....I thought IE6 came with XP.
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • R_J
                                        • Jun 2012
                                        • 9578
                                        He reported 76477-oem which is XP Home Royalty OEM, So something ain't right
                                        • MMH3
                                          Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                                          by MMH3
                                          i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                                          Never ever i experienced problems with that.
                                          Now i have one 5050sff machine, where this jumper isnt working at all.
                                          I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                                          The history of the machine is that i used it in my office...
                                          03-23-2025, 09:28 PM
                                        • DynaxSC
                                          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                          by DynaxSC
                                          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                          The board is generally working now, all PCIe ports are working, Windows installs normally.
                                          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                          03-10-2025, 12:27 PM
                                        • obelix24
                                          Macbook Air 2020 (a2179) - touch id not working
                                          by obelix24
                                          Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                                          I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                                          02-09-2025, 12:57 PM
                                        • hopkok
                                          Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                                          by hopkok
                                          Hi masters, I need your help.
                                          I am working on Lenovo Legion 16ITHg6
                                          Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                                          INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                                          My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                                          AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                                          Power LED is not working as well, power button working well.
                                          UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                                          Motherboard...
                                          05-04-2025, 09:35 AM
                                        • bociub
                                          laptop freezes, usb 2.0 not working, usb 3.0 working
                                          by bociub
                                          Hi there,
                                          It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
                                          Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what...
                                          08-25-2024, 03:44 PM
