PS3 Super Slim PSU
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    PS3 Super Slim PSU
    Hello, i have dead PS3 with no power. I check fuse and it is ok and i track furder and i find that bridge rectifier have 0V on DC, AC is ok 240V. I remove the (GBU608) rectifier and the value in diode mode are
    - to AC = 503
    - to AC = 503
    - to + = 930
    Is this ok reading? this 930?
    ...the quieter you become the more you are able to hear...
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Re: PS3 Super Slim PSU
    Oh i forgot to metion thet i have no Standby voltage, it is 0.05V
    • ngth82
      • Jul 2015
      • 541
      • Can you please post a picture of the top and bottom of the PS3 power supply?
      • What's the model number of this console?
      • Is this the one with the plastic top-load? If so, i can take the one i have apart and give you some good comparison data.
      -Thomas
      -Thomas
      I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
      • rtstorm
        • Feb 2012
        • 971
        • Croatia
        Here is the pic of PSU. Model is PS3 Super Slim CECH-4304A.
        The top load is model, the one that slide the lid for insert CD
        • ngth82
          • Jul 2015
          • 541
          Cool. I will get you a reply and some data this evening. Need to finish out the workday (at home) first...
          I'll double check the PS3 model that i have, but i know for sure it's the top load version that i have laying around. The original owner never picked it up and went MIA for the last 2 years. It's mine now i guess
          According to the PS3 devwiki, there are three main super slim versions:
          Super Slim (nor/eMMC)
          CECH-40xx
          CECH-42xx
          CECH-43xx
          https://www.psdevwiki.com/ps3/
          -Thomas
            • 31248
            what about + to AC readings?
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              + to AC reading is 502 and reverse is 0L
                • 31248
                then with 240vac on the input you should have about 340vdc on the output.
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  Yes, you are right. My first reading was wrong :-(
                  Any sugestion what should i check next?
                  • rtstorm
                    • Feb 2012
                    • 971
                    • Croatia
                    i check the reading on second fuse and i got 0.02V and on the IC all pins are 0.2V exepr pin #5 voltage is jumping from 0.2V to 5V
                      • 31248
                      it could be one of the small caps dried up inside
                      • ngth82
                        • Jul 2015
                        • 541
                        Whats the model of your power supply? it should be molded on to the bottom plastic piece. The one that i have is a ADP-160AR - it has a white 4 pin connector.
                        In any case, the common failures for the PS3 and PS4 supplies are the N channel FETs and diodes downstream. If you haven't already, i suggest checking the four 3-pin heatsinked parts for shorts.
                        In my supply, it's a K15A60U and a BYV29FX-600 diode close to the big 450V cap. You can use the DMM in continuity / beep mode for the N-FET, and in diode mode for the diode.
                        Next to the 12V output, there are two heatsinked components as well. For me, it's two STPS3045CT diodes wired in parallel.
                        I've fixed several PS4 and Xbox One supplies with failed FETS/Diodes.
                        -Thomas
                        • ngth82
                          • Jul 2015
                          • 541
                          What's the markings on that IC that you show in post #10?
                          -Thomas
                          • rtstorm
                            • Feb 2012
                            • 971
                            • Croatia
                            My board is N160A 002L
                            I check all FET's and diodes and they are ok, at first i thought that B3045G Switch Mode Power Rectifier was shorted becoust pin 1 and 3 was shorted. Then i remo it from board and it was ok. The false reading was becouse the 1 and 3 is connected to the primary of transformator. All other diodes and heatsink element show no short.
                            @ ngth82 - the IC is FS117
                              • Jul 2011
                              • 6069
                              FS117
                              This is not a good part number
                              • rtstorm
                                • Feb 2012
                                • 971
                                • Croatia
                                Here is the picture of component. I fount it on AliExpress
                                • ngth82
                                  • Jul 2015
                                  • 541
                                  I agree...
                                  BUT... if you look at the US version, my supply has a DNP013 by Fairchild Semi. ()
                                  Fairchild has a device FSL117 - note the addition of the L. (https://cdn.badcaps-static.com/pdfs/...5d406acc7c.pdf)
                                  Both are green-mode Fairchild power switches.
                                  I just can't find the package marking for the FSL117 - it's not in their datasheet. Maybe this is a good start... Pin out looks similar except pin 4 between the two devices.
                                  -Thomas
                                  • rtstorm
                                    • Feb 2012
                                    • 971
                                    • Croatia
                                    Yes, i think this is the same component. On my measuring i get 0V on all (exactly -0.8V) except on pin5 i get jumping volage from -2 to 6V. The datasheet say that pin 5 is STARTUP and pin 4 is V-IN
                                      • 31248
                                      jumping startup is usually a bad cap
                                      • ngth82
                                        • Jul 2015
                                        • 541
                                        I'd look at the cap too as STJ suggested if you haven't already. Got a cap meter?
                                        -Thomas
                                        • MORETTIGIAN
                                          Capacitor detached from PCB – RTX 2070 Super Founders Edition
                                          by MORETTIGIAN
                                          Title:
                                          Description:
                                          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                                          I did not notice it detaching, so I am unsure of its original location on the PCB.
                                          Procedure performed:
                                          - Removed backplate
                                          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                                          - Reapplied thermal compound
                                          - Reassembled card
                                          Observed behavior after reassembly:
                                          - GPU powers on and operates normally under...
                                          09-18-2025, 12:14 PM
                                        • Destroyer-Br
                                          [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                          by Destroyer-Br
                                          Hi everyone,
                                          I'm working on an Acer Nitro 5 unit with the following specs:
                                          • Motherboard: LA-J871P Rev: 1B
                                          • Model: Acer AN515-55-59MT
                                          • S/N: NHQ7JAL00403906A973400
                                          • SNID: 03902728734
                                          Initial Issue
                                          The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                          After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                          04-17-2025, 08:18 PM
                                          SHUTTLE XPC slim DX30 XPC slim J3355 Specification for Upgrade or Repair
                                          This specification for the SHUTTLE XPC slim DX30 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DX30 boardview and XPC slim DX30 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for SHUTTLE...
                                          09-12-2024, 03:30 PM
                                          SHUTTLE XPC slim Office DL1000EP XPC slim J4005 Specification for Upgrade or Repair
                                          This specification for the SHUTTLE XPC slim Office DL1000EP can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim Office DL1000EP boardview and XPC slim Office DL1000EP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 03:28 PM
                                          SHUTTLE XPC slim DH110SE XPC slim i5-7600 Specification for Upgrade or Repair
                                          This specification for the SHUTTLE XPC slim DH110SE can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC slim DH110SE boardview and XPC slim DH110SE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
