Altius AL5517UHDS intermittent loss of picture - self fixes
  • maxvalutech
    • Dec 2014
    • 804
    • australia
    Hi from Oz, some years since last posted. This set is 3 years old and had almost no use in that time. Brought it out of hibernation a month ago. Problem came up shortly after. Set is always turned off at pp when not being used. Turn it on and logo comes up then picture but after a few to around 15 minutes the picture start blinking irregularly for a time then go completely off, backlights remain on. Leave it and after 10 - 20 minutes picture will come back on and sometimes do the same thing again but then will stabilise and run normally for hours until switched off.
    I have pulled back off and checked the single combined board and tcon - no sign of any problem in caps etc. Pulled and cleaned all connections/ribbons to from tcon and changed picture settings in menu to standard with low noise and DLC off after doing a reset.
    This seemed to fix the problem as all normal then for 4 days until problem came back
    Now here's something strange - I can sometimes cause the set to sit up and act properly by giving it a firm slap on the back !
    Read somewhere that these sets are made in India, sold by Aldi in Ireland, and probably have other brand names. Info is non existent.
    I gave up working on sets about 3 years back and now no tools where I am not even a multimeter. So any ideas or experience on these sets ?
  • nomoresonys
    • 12306
    • U.S.
    Re: Altius AL5517UHDS intermittent loss of picture - self fixes
    Seems like a backlight circuit issue, possibly bad connection or bad led/s, could be why the slap clears it up temporarily.
    • maxvalutech
      • Dec 2014
      • 804
      • australia
      As mentioned in post the backlights stay on. I'm inclined to think dry joint but as all else works it would have to be in picture circuit only. Today set turned on blinking etc again after 10 mins picture then off, if left as is the picture will usually suddenly come on again within 30 mins and then stay on. Today i gave set a slap ana a stable picture immediately came on and stayed on for 3 hours then blinked again and went off coming back on after about 10 mins and normal again. Perhaps a component heating/cooling on the board or some voltage fluctuation. I do know the signal we receive is marginal particularly around 8.30 in the morning (this from previous TV) and I had some suspicion that the picture fluctuations may have triggered eeprom problem that then needed time to reset itself.
        Since the backlights stay on but no image on the screen, then you should verify if the 12VDC feeding the T-CON is still present or not when it acts up.
        • nomoresonys
          • 12306
          • U.S.
          My bad, I immediately forgot what I read, when I read it, think I got 2 threads mixed up.
          • nomoresonys
            • 12306
            • U.S.
            You may be on the right track, did you try a factory reset, firmware update?
            • R_J
              • Jun 2012
              • 9608
              When the picture goes out do you still have audio? Try taping areas of the board with an insulated stick, you might be able to narrow it down.
              • maxvalutech
                • Dec 2014
                • 804
                • australia
                Thanks people a couple of good suggestions there to follow up.
                • maxvalutech
                  • Dec 2014
                  • 804
                  • australia
                  Blinking getting more frequent but a slap fixes it straightaway so surely a dry joint.
                  • Tr0ll
                    by Tr0ll
                    Original T-con:
                    First replacement T-con:
                    10-07-2023, 07:48 PM
                  • JJAAMM
                    by JJAAMM
                    Problem
                    07-06-2023, 06:01 AM
                  • TR103
                    by TR103
                    - it keeps rebooting
                    01-22-2025, 04:12 PM
                  • Mgiffune
                    by Mgiffune
                    06-09-2024, 10:28 AM
                  • CyberPhoenix
                    Issue with picture quality of Sony bravia TV
                    by CyberPhoenix
                    Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                    01-22-2024, 02:08 AM
